查看: 6335|回复: 11
[lighttpd] 请高人指点下,datashack服务器怎么突然停了?
发表于 2012-10-6 13:29:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
datashack昨天发来邮件
标题:Traffic affecting network -74.91.22.199
邮件内容:Single IP null routed for having a negative impact on our network
PS:网站装的CP.流量巨大.每天几百G.. 他的邮件内容也太剪短咯!怎么回邮件啊?才买了几天
附上另个whmcs邮件提示
Hello mjj (MJJ),
This is a WHMCS Security Alert. If you use WHMCS this is very important and you should act on the below ASAP.
We have become aware of a security issue that exists in the third party Boleto
module included in WHMCS releases. This can potentially be used to exploit a
WHMCS installation.
If you do not use the Boleto module, then the quickest and easiest solution is
to simply delete the /modules/gateways/boleto/ folder entirely after which you
will not be at risk.
Alternatively if you do use the module, you can download and apply the patch to
your installation here: http://www.whmcs.com/members/dl.php?type=d&id=138
This issue affects all WHMCS versions.
If you have any questions or need any assistance, please do not hesitate to
contact us. We apologize for the inconvenience.
Kind Regards,
The Velocity Central Support Team
参与人数 1威望 +1 收起 理由
аdmin + 1 莫激动
发表于 2012-10-6 13:46:33 | 只看该作者
发表于 2012-10-6 13:54:25 | 只看该作者
20T的机器不会只因为每天几百G就封IP的,除非是骗人的
发表于 2012-10-6 13:55:49 | 只看该作者
膜拜楼主,什么网站能够牛逼到影响整个机房的网络
 楼主| 发表于 2012-10-6 14:06:14 | 只看该作者
想像也是的.20T 照这个速度也用不完啊..
基本20M/S
 楼主| 发表于 2012-10-6 14:12:21 | 只看该作者
当然是下载站了,呵呵
发表于 2012-10-6 14:12:40 | 只看该作者
基本20M/S
会不会发包啊  我整天跑10-50M 都没事
 楼主| 发表于 2012-10-6 14:13:42 | 只看该作者
有可能是被入侵了..
发表于 2012-10-6 14:17:31 | 只看该作者
毛血旺 发表于 2012-10-6 14:13
有可能是被入侵了..
杯具啊  哈哈
发表于 2012-10-6 14:22:37 | 只看该作者
淡定
GMT+8, 2026-4-21 13:18 , Processed in 0.069697 second(s), 13 queries , Gzip On, MemCache On.
