查看: 5244|回复: 13
[Windows VPS] 谁的阿里云?
发表于 2012-10-5 01:46:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
快来认领。。。
  1. 2012-10-0X 01:16:44 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62108: 535 Incorrect authentication data (set_id=webmaster)
  2. 2012-10-05 01:16:44 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62109: 535 Incorrect authentication data (set_id=webmaster)
  3. 2012-10-05 01:16:46 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62108: 535 Incorrect authentication data (set_id=webmaster)
  4. 2012-10-05 01:16:46 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62109: 535 Incorrect authentication data (set_id=webmaster)
  5. 2012-10-05 01:16:48 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62108: 535 Incorrect authentication data (set_id=webmaster)
  6. 2012-10-05 01:16:48 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62109: 535 Incorrect authentication data (set_id=webmaster)
  7. 2012-10-05 01:16:50 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62109: 535 Incorrect authentication data (set_id=webmaster)
  8. 2012-10-05 01:16:50 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62108: 535 Incorrect authentication data (set_id=webmaster)
  9. 2012-10-05 01:16:52 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62108: 535 Incorrect authentication data (set_id=webmaster)
  10. 2012-10-05 01:16:52 dovecot_login authenticator failed for (XL-20120609CTGA) [110.76.47.136]:62109: 535 Incorrect authentication data (set_id=webmaster)
参与人数 1威望 +20 收起 理由
smyz + 20 咩咩
发表于 2012-10-5 01:46:59 | 只看该作者
就是有蛋疼帝 唉
发表于 2012-10-5 01:48:25 | 只看该作者
真相?~~~
发表于 2012-10-5 01:52:01 | 只看该作者
     我尾巴的        ——来自呶呶防御鸡
发表于 2012-10-5 01:56:13 | 只看该作者
不是我的
发表于 2012-10-5 01:57:29 | 只看该作者
咩咩被性骚扰啦?
发表于 2012-10-5 01:58:01 | 只看该作者
kokgog速度出来招了吧
发表于 2012-10-5 02:04:47 | 只看该作者
kokgog速度出来招了吧
发表于 2012-10-5 02:15:11 | 只看该作者
楼下的
发表于 2012-10-5 02:19:20 | 只看该作者
GMT+8, 2026-4-29 01:31 , Processed in 0.091250 second(s), 13 queries , Gzip On, MemCache On.
