查看: 5058|回复: 14
buyvm的一个Support,人直接傻了
发表于 2012-10-3 23:09:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求大神解释,BUYVM也用了很久了,今天所有的vps全挂,就因为这个IP,不知道怎么了
This ticket is notification that your service with us (209.141.53.30) has been terminated, and your account suspended, for the following TOS/AUP infractions:
- SEO Spam
Your service has been discovered to be linked to the Vincent Chan ROSKO spam network As this is a very serious TOS/AUP violation, the offending service has been terminated. No data or compensation will be made available. Any remaining services on your account have also been suspended, and a TOS/AUP Violation Fine (Invoice 52650) added to your account. This invoice must be paid in full before any remaining service may be reactivated, or further services purchased. Please be aware that failure to settle this fine within 48 hours will result in complete account termination, and you will not be permitted any further services with us.
Logs of the abuse follow:
209.141.53.30/32 is listed on the SBL as being assigned to, being under the control of, or being otherwise connected with a known spam operation listed on the ROKSO database as: Vincent Chan gang
ns1.easynetworkrx365.com A 209.141.53.30
ns2.discountsbestrx724.com A 209.141.53.30
Aldryic C'boäs, Frantech Staff
[Email/MSN] cboas@frantech.ca
[IRC] irc.frantech.ca / #frantech
我的回复:
我并没有发送垃圾邮件,请检查.
第二封
http://www.spamhaus.org/sbl/query/SBL158813
我什么也没干。。。求各位大神帮忙解决~
意思是这个IP被黑客入侵为Vincent Chan gang的DNS了么?
发表于 2012-10-3 23:10:25 | 只看该作者
又一个悲剧了
参与人数 1威望 +5 收起 理由
炎羽 + 5 多谢回复!
发表于 2012-10-3 23:10:52 | 只看该作者
欧耶  蛋疼的LZ
参与人数 1威望 +5 收起 理由
炎羽 + 5 多谢回复!
发表于 2012-10-3 23:12:36 | 只看该作者
怎么头像都尼玛这么霸气都是会动滴
参与人数 1威望 +5 收起 理由
炎羽 + 5 多谢回复!
发表于 2012-10-3 23:16:00 | 只看该作者
spam
buyvm处事  只要一个帐号有问题 里面暂停所有vps
参与人数 1威望 +5 收起 理由
炎羽 + 5 多谢回复!
发表于 2012-10-3 23:17:08 | 只看该作者
不是你发的不等于你的IP没有发,要么交钱要么走人,BUYVM这家平时都不怎么讲道理,碰到这种事不狠宰你一刀不会罢休的
参与人数 1威望 +5 收起 理由
炎羽 + 5 多谢回复!
发表于 2012-10-3 23:17:36 来自手机 | 只看该作者
发表于 2012-10-3 23:20:10 | 只看该作者
不买这家 太不讲道理
参与人数 1威望 +5 收起 理由
炎羽 + 5 多谢回复!
发表于 2012-10-3 23:20:49 | 只看该作者
难道是骗钱的鬼把戏
参与人数 1威望 +5 收起 理由
炎羽 + 5 多谢回复!求解决之道!
发表于 2012-10-3 23:24:46 来自手机 | 只看该作者
太严格了
参与人数 1威望 +5 收起 理由
炎羽 + 5 多谢回复!求解决之道!
GMT+8, 2026-4-23 01:12 , Processed in 0.144663 second(s), 13 queries , Gzip On, MemCache On.
