查看: 3091|回复: 9
[疑问] 接到巴斯的警告。。空的巴斯vps
发表于 2010-4-17 12:08:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
nnd  空的vps也有人搞。。
Hello,
It appears that someone on one of your hosts attempted to break in to one of my hosts. I've attached the relevant log entries below, all times are in US/Central. Please investigate and take appropriate action...
Thanks!
Pat
Apr 16 14:19:59 notanut sshd[16392]: Did not receive identification string from 66.197.184.224
Apr 16 14:24:42 notanut sshd[17924]: Invalid user user from 66.197.184.224
Apr 16 14:24:42 notanut sshd[17924]: reverse mapping checking getaddrinfo for 66-197-184-224.hostnoc.net failed - POSSIBLE BREAK-IN ATTEMPT!
Apr 16 14:24:42 notanut sshd[17925]: Received disconnect from 66.197.184.224: 11: Bye Bye
Apr 16 14:24:43 notanut sshd[17926]: Invalid user test from 66.197.184.224
Apr 16 14:24:43 notanut sshd[17926]: reverse mapping checking getaddrinfo for 66-197-184-224.hostnoc.net failed - POSSIBLE BREAK-IN ATTEMPT!
Apr 16 14:24:43 notanut sshd[17927]: Received disconnect from 66.197.184.224: 11: Bye Bye
Apr 16 14:24:43 notanut sshd[17928]: Invalid user guest from 66.197.184.224
Apr 16 14:24:43 notanut sshd[17928]: reverse mapping checking getaddrinfo for 66-197-184-224.hostnoc.net failed - POSSIBLE BREAK-IN ATTEMPT!
Apr 16 14:24:43 notanut sshd[17929]: Received disconnect from 66.197.184.224: 11: Bye Bye
Apr 16 14:24:44 notanut sshd[17930]: Invalid user oracle from 66.197.184.224
Apr 16 14:24:44 notanut sshd[17930]: reverse mapping checking getaddrinfo for 66-197-184-224.hostnoc.net failed - POSSIBLE BREAK-IN ATTEMPT!
Apr 16 14:24:44 notanut sshd[17931]: Received disconnect from 66.197.184.224: 11: Bye Bye
Apr 16 14:24:45 notanut sshd[17932]: reverse mapping checking getaddrinfo for 66-197-184-224.hostnoc.net failed - POSSIBLE BREAK-IN ATTEMPT!
Apr 16 14:24:45 notanut sshd[17933]: Received disconnect from 66.197.184.224: 11: Bye Bye
发表于 2010-4-17 12:10:43 | 只看该作者
太幽默了....
发表于 2010-4-17 12:15:37 | 只看该作者
发表于 2010-4-17 12:15:55 | 只看该作者
像你這麼拉風的男人..沒人要的女人都被人搞的
发表于 2010-4-17 12:22:21 | 只看该作者
发表于 2010-4-17 12:54:02 | 只看该作者
呵呵,不会是以前用这个ip的人和谁有仇吧?
发表于 2010-4-17 13:01:16 | 只看该作者
 楼主| 发表于 2010-4-17 13:15:10 | 只看该作者
改了SSH端口。。。估计谁无聊穷举呢~
发表于 2010-4-17 13:46:40 | 只看该作者
巴斯还挺负责的
发表于 2010-4-17 14:06:29 | 只看该作者
装软件ban他们
GMT+8, 2026-4-30 20:02 , Processed in 0.064986 second(s), 10 queries , Gzip On, MemCache On.
