CeraNetworks网络延迟测速工具IP归属甄别
查看: 6136|回复: 2
FDC 丹佛机房7月1日新增2个载波
发表于 2009-6-14 11:57:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
官网:
we are shooting for July 1st to add 2 new carriers
announcement will be made in next few days about who the additional carriers will be
发表于 2009-6-15 22:38:46 | 只看该作者
载波是干什么的,是不是代理?
 楼主| 发表于 2009-6-15 23:09:26 | 只看该作者
回复 2# 的帖子
What is Carrier Neutral Colocation?
Carrier Neutral colocation is a type of colocation which bases the colocation center around many internet service providers as opposed to just one or two. This means that the data may travel over any one of a number of internet service providers, ensuring that if any one of them is down or having trouble the data will still get through. This offers many advantages over using a single ISP.
什么是不确定性载波协同定位?
不确定性载波协同定位是协同定位的一种,它主张多个ISP服务商建立统一的协同定位中心,而不是单一的服务器服务。这意味着数据可以通过多个ISP服务商传输,即时其中一个ISP服务商出问题,其他的服务商也会接续他的服务来继续传输数据,不会造成数据的损失和中断。他相比单一ISP,有很多的优势。
The first advantage is obvious: if one ISP goes down, or is having problems, or is otherwise unable to provide service, servers may be switched to another, although of course new fees and contracts will need to be negotiated. Additionally, this means that if a company has an existing contract with an existing internet service provider, all they need to do is bring their existing servers into the facility. The carrier neutral colocation can then simply connect that server into the same network and continue service as-is, in the new location.
Carrier neutral colocation is very important for a company that has an existing relationship with an ISP they are very happy with. Carrier neutral colocation allows for them to continue their existing business contracts without having to negotiate new terms, while still permitting them to keep their own servers. They also gain the benefits of server colocation, which include increased stability and security.
Carrier neutral colocation is also excellent for a company that is not happy with its current ISP and wishes to change carriers. Because the colocation centre is carrier neutral, the customer is free to shop around among carriers and find the one with the best rate. They are not constricted in which service they choose, and they can lock in a good contract with the best server. This, along with the other advantages mentioned above, is why the best colocation centres are carrier neutral.
GMT+8, 2026-4-13 11:25 , Processed in 0.060404 second(s), 9 queries , Gzip On, MemCache On.
