查看: 1952|回复: 6
PHP Warning
发表于 2012-9-18 20:58:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PHP Warning:  phpinfo():                                It is not safe to rely on the system's timezone settings. You are *required* to use                                the date.timezone setting or the date_default_timezone_set() function. In case you u                               sed any of those methods and you are still getting this warning, you most likely mis                               spelled the timezone identifier. We selected the timezone 'UTC' for now, but please                                set date.timezone to select your timezone. in /var/www/html/index.php on line 2
[Tue Sep 18 12:53:33 2012] [notice] caught SIGTERM, shutting down
发表于 2012-9-18 20:59:07 | 只看该作者
好像是时区的问题啊
发表于 2012-9-18 20:59:15 | 只看该作者
php.ini
发表于 2012-9-18 20:59:36 | 只看该作者
布吉岛
发表于 2012-9-18 20:59:50 | 只看该作者
删除
发表于 2012-9-18 21:07:52 | 只看该作者
不懂
发表于 2012-9-18 21:13:16 | 只看该作者
球科普
GMT+8, 2026-4-21 09:50 , Processed in 0.185715 second(s), 13 queries , Gzip On, MemCache On.
