查看: 938|回复: 2
[交易VPS] 【已出】Rackoona美国Utah无限流量有Windows
发表于 2026-4-4 01:48:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
已出
感谢大佬
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 10 minutes
  4. Processor  : AMD EPYC 7713 64-Core Processor
  5. CPU cores  : 2 @2000.004 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 3.8 GiB
  9. Swap       : 0.0 KiB
  10. Disk       : 39.9 GiB
  11. Distro     : Debian GNU/Linux 13 (trixie)
  12. Kernel     : 6.12.73+deb13-cloud-amd64
  13. VM Type    : KVM
  14. IPv4/IPv6  : ✔ Online / ❌ Offline
  15. IPv4 Network Information:
  16. ---------------------------------
  17. ISP        : Vantiva USA Shared Services Inc.
  18. ASN        : AS213186 Yanoor Islam Khan
  19. Location   : Buffalo, New York (NY)
  20. Country    : United States
  21. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2):
  23. Block Size | 4k            (IOPS) | 64k           (IOPS)
  24.   ------   | ---            ----  | ----           ----
  25. Read       | 197.95 MB/s  (49.4k) | 2.55 GB/s    (39.8k)
  26. Write      | 198.47 MB/s  (49.6k) | 2.56 GB/s    (40.0k)
  27. Total      | 396.43 MB/s  (99.1k) | 5.11 GB/s    (79.9k)
  28.            |                      |
  29. Block Size | 512k          (IOPS) | 1m            (IOPS)
  30.   ------   | ---            ----  | ----           ----
  31. Read       | 4.11 GB/s     (8.0k) | 3.71 GB/s     (3.6k)
  32. Write      | 4.32 GB/s     (8.4k) | 3.95 GB/s     (3.8k)
  33. Total      | 8.43 GB/s    (16.4k) | 7.66 GB/s     (7.4k)
  34. Geekbench 5 Benchmark Test:
  35. ---------------------------------
  36. Test            | Value
  37.                 |
  38. Single Core     | 777
  39. Multi Core      | 1392
  40. Full Test       | https://browser.geekbench.com/v5/cpu/24221861
  1.    Speedtest by Ookla
  2.       Server: Vyve Broadband - Abilene, KS (id: 31889)
  3.          ISP: Aystor
  4. Idle Latency:    20.92 ms   (jitter: 0.06ms, low: 20.86ms, high: 20.99ms)
  5.     Download:  5136.87 Mbps (data used: 6.3 GB)
  6.                  26.02 ms   (jitter: 1.62ms, low: 21.14ms, high: 45.60ms)
  7.       Upload:  6353.95 Mbps (data used: 8.9 GB)
  8.                  21.04 ms   (jitter: 7.97ms, low: 20.36ms, high: 275.49ms)
  9. Packet Loss:     0.0%
  10.   Result URL: https://www.speedtest.net/result/c/8c65180f-69cc-4e66-86ac-4cb36593a1df
Rackoona
美国 Utah 犹他州
测试ip:157.254.223.1
有Windows系统
官方提供Windows Server 2019/2022/2025,也可自行DD
配置:
        2核cpu
        4g内存
        40g硬盘
        5Gbps带宽
        无限流量
续费价格,20刀/年
到期时间,26年11月26日
账号有5刀余额,可以抵扣账单
明盘200,带邮箱
TG联系Brunuh2Ville2
https://t.me/Brunuh2Ville2
发表于 2026-4-4 09:56:52 | 只看该作者
130有意收了,出吗?
 楼主| 发表于 2026-4-4 10:25:06 | 只看该作者
三不 发表于 2026-4-4 09:56
130有意收了,出吗?
200出
GMT+8, 2026-4-16 15:54 , Processed in 0.059634 second(s), 9 queries , Gzip On, MemCache On.
