查看: 774|回复: 2
[交易VPS] 【出】SolidVps洛杉矶4核Amd年付15刀
发表于 2026-4-4 00:16:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 6 minutes
  4. Processor  : AMD EPYC 7713 64-Core Processor
  5. CPU cores  : 4 @1996.247 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 1.9 GiB
  9. Swap       : 0.0 KiB
  10. Disk       : 50.9 GiB
  11. Distro     : Debian GNU/Linux 13 (trixie)
  12. Kernel     : 6.12.73+deb13-cloud-amd64
  13. VM Type    : KVM
  14. IPv4/IPv6  : ✔ Online / ✔ Online
  15. IPv6 Network Information:
  16. ---------------------------------
  17. ISP        : Solid Systems LLC
  18. ASN        : AS399275 Solid Systems LLC
  19. Host       : Solid Systems LLC
  20. Location   : Los Angeles, California (CA)
  21. Country    : United States
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 167.06 MB/s  (41.7k) | 2.24 GB/s    (35.1k)
  27. Write      | 167.51 MB/s  (41.8k) | 2.26 GB/s    (35.3k)
  28. Total      | 334.57 MB/s  (83.6k) | 4.51 GB/s    (70.4k)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 5.36 GB/s    (10.4k) | 6.48 GB/s     (6.3k)
  33. Write      | 5.64 GB/s    (11.0k) | 6.91 GB/s     (6.7k)
  34. Total      | 11.00 GB/s   (21.5k) | 13.40 GB/s   (13.0k)
  35. Geekbench 5 Benchmark Test:
  36. ---------------------------------
  37. Test            | Value
  38.                 |
  39. Single Core     | 945
  40. Multi Core      | 3420
  41. Full Test       | https://browser.geekbench.com/v5/cpu/24221806
  1.    Speedtest by Ookla
  2.       Server: GeoLinks - Los Angeles, CA (id: 60433)
  3.          ISP: SOLiD
  4. Idle Latency:     0.42 ms   (jitter: 0.03ms, low: 0.40ms, high: 0.44ms)
  5.     Download:  4497.77 Mbps (data used: 7.0 GB)
  6.                   0.70 ms   (jitter: 0.61ms, low: 0.42ms, high: 5.54ms)
  7.       Upload:  4591.21 Mbps (data used: 6.2 GB)
  8.                   0.80 ms   (jitter: 0.73ms, low: 0.48ms, high: 4.90ms)
  9. Packet Loss:     0.0%
  10.   Result URL: https://www.speedtest.net/result/c/bf56ebd2-8107-4b50-9a5b-9b3fcab6dd06
SolidVps 美国 洛杉矶
配置:
        4核cpu,AMD EPYC 7713
        2g内存
        50g硬盘
        8000g流量/月
        ipv4+ipv6
        5Gbps带宽
续费价格,15刀/年(永久锁定价,不是每年涨5%的)
到期时间,26年11月28日
明盘350,带邮箱
TG联系Brunuh2Ville2
https://t.me/Brunuh2Ville2
发表于 2026-4-4 00:37:28 来自手机 | 只看该作者
溢价有点高 有意
 楼主| 发表于 2026-4-4 00:42:47 | 只看该作者
tai 发表于 2026-4-4 00:37
溢价有点高 有意
RackNerd第三波,2核Ryzen/2g内存/30g硬盘,cpu多核跑分一样,比solid这个机少了20g硬盘,上个月在隔壁也卖的350
GMT+8, 2026-4-16 15:53 , Processed in 0.056770 second(s), 8 queries , Gzip On, MemCache On.
