查看: 1251|回复: 15
收的坛子里A大的特价机,就是给力啊!
发表于 2012-9-16 20:05:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VPSWIND
  1. ========================================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.3)
  3.    System: localhost.localdomain: GNU/Linux
  4.    OS: GNU/Linux -- 3.2.0-24-virtual -- #37-Ubuntu SMP Wed Apr 25 12:51:49 UTC 2012
  5.    Machine: i686 (i386)
  6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  7.    CPU 0: Intel(R) Xeon(R) CPU E3-1270 V2 @ 3.50GHz (7000.0 bogomips)
  8.           Hyper-Threading, MMX, Physical Address Ext, SYSENTER/SYSEXIT
  9.    CPU 1: Intel(R) Xeon(R) CPU E3-1270 V2 @ 3.50GHz (7000.0 bogomips)
  10.           Hyper-Threading, MMX, Physical Address Ext, SYSENTER/SYSEXIT
  11.    19:00:43 up  1:07,  1 user,  load average: 0.11, 0.09, 0.12; runlevel 2
  12. ------------------------------------------------------------------------
  13. Benchmark Run: Sun Sep 16 2012 19:00:43 - 19:28:48
  14. 2 CPUs in system; running 1 parallel copy of tests
  15. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  16. Dhrystone 2 using register variables         116700.0   27492702.8   2355.8
  17. Double-Precision Whetstone                       55.0       3664.2    666.2
  18. Execl Throughput                                 43.0       1651.5    384.1
  19. File Copy 1024 bufsize 2000 maxblocks          3960.0     486992.9   1229.8
  20. File Copy 256 bufsize 500 maxblocks            1655.0     132817.5    802.5
  21. File Copy 4096 bufsize 8000 maxblocks          5800.0    1461857.4   2520.4
  22. Pipe Throughput                               12440.0     674129.2    541.9
  23. Pipe-based Context Switching                   4000.0      48101.7    120.3
  24. Process Creation                                126.0       3784.6    300.4
  25. Shell Scripts (1 concurrent)                     42.4       5410.3   1276.0
  26. Shell Scripts (8 concurrent)                      6.0        983.1   1638.5
  27. System Call Overhead                          15000.0     765913.4    510.6
  28.        ========
  29. System Benchmarks Index Score                                         749.3
  30. ------------------------------------------------------------------------
  31. Benchmark Run: Sun Sep 16 2012 19:28:48 - 19:56:54
  32. 2 CPUs in system; running 2 parallel copies of tests
  33. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  34. Dhrystone 2 using register variables         116700.0   51583567.6   4420.2
  35. Double-Precision Whetstone                       55.0       7216.4   1312.1
  36. Execl Throughput                                 43.0       3181.4    739.9
  37. File Copy 1024 bufsize 2000 maxblocks          3960.0     772376.3   1950.4
  38. File Copy 256 bufsize 500 maxblocks            1655.0     210638.7   1272.7
  39. File Copy 4096 bufsize 8000 maxblocks          5800.0    2453543.6   4230.2
  40. Pipe Throughput                               12440.0    1315228.1   1057.3
  41. Pipe-based Context Switching                   4000.0     124259.9    310.6
  42. Process Creation                                126.0       6744.3    535.3
  43. Shell Scripts (1 concurrent)                     42.4       7395.9   1744.3
  44. Shell Scripts (8 concurrent)                      6.0       1002.8   1671.4
  45. System Call Overhead                          15000.0    1428460.3    952.3
  46.        ========
  47. System Benchmarks Index Score                                        1293.8
  48. root@localhost:~/UnixBench#
Linode 512M的
  3.    System: localhost: GNU/Linux
  4.    OS: GNU/Linux -- 3.0.4-linode38 -- #1 SMP Thu Sep 22 14:59:08 EDT 2011
  7.    CPU 0: Intel(R) Xeon(R) CPU L5520 @ 2.27GHz (4522.0 bogomips)
  9.    CPU 1: Intel(R) Xeon(R) CPU L5520 @ 2.27GHz (4522.0 bogomips)
  11.    CPU 2: Intel(R) Xeon(R) CPU L5520 @ 2.27GHz (4522.0 bogomips)
  12.           Hyper-Threading, MMX, Physical Address Ext
  13.    CPU 3: Intel(R) Xeon(R) CPU L5520 @ 2.27GHz (4522.0 bogomips)
  14.           Hyper-Threading, MMX, Physical Address Ext
  15.    17:50:45 up 1 min,  1 user,  load average: 0.43, 0.17, 0.06; runlevel 2
  16. ------------------------------------------------------------------------
  17. Benchmark Run: Tue Jan 10 2012 17:50:45 - 18:18:36
  18. 4 CPUs in system; running 1 parallel copy of tests
  19. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  20. Dhrystone 2 using register variables         116700.0   11848585.0   1015.3
  21. Double-Precision Whetstone                       55.0       2318.9    421.6
  22. Execl Throughput                                 43.0       1011.3    235.2
  23. File Copy 1024 bufsize 2000 maxblocks          3960.0     247752.1    625.6
  24. File Copy 256 bufsize 500 maxblocks            1655.0      68500.0    413.9
  25. File Copy 4096 bufsize 8000 maxblocks          5800.0     744126.7   1283.0
  26. Pipe Throughput                               12440.0     403162.1    324.1
  27. Pipe-based Context Switching                   4000.0      27045.1     67.6
  28. Process Creation                                126.0       1926.6    152.9
  29. Shell Scripts (1 concurrent)                     42.4       2796.7    659.6
  30. Shell Scripts (8 concurrent)                      6.0        911.1   1518.5
  31. System Call Overhead                          15000.0     433939.4    289.3
  32.        ========
  33. System Benchmarks Index Score                                         422.6
  34. ------------------------------------------------------------------------
  35. Benchmark Run: Tue Jan 10 2012 18:18:36 - 18:46:42
  36. 4 CPUs in system; running 4 parallel copies of tests
  37. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  38. Dhrystone 2 using register variables         116700.0   46689041.3   4000.8
  39. Double-Precision Whetstone                       55.0       9625.3   1750.1
  40. Execl Throughput                                 43.0       4039.6    939.4
  41. File Copy 1024 bufsize 2000 maxblocks          3960.0     316725.0    799.8
  42. File Copy 256 bufsize 500 maxblocks            1655.0      86839.0    524.7
  43. File Copy 4096 bufsize 8000 maxblocks          5800.0    1039901.3   1792.9
  44. Pipe Throughput                               12440.0    1648646.3   1325.3
  45. Pipe-based Context Switching                   4000.0     175330.2    438.3
  46. Process Creation                                126.0       6817.6    541.1
  47. Shell Scripts (1 concurrent)                     42.4       7714.3   1819.4
  48. Shell Scripts (8 concurrent)                      6.0       1019.0   1698.4
  49. System Call Overhead                          15000.0    1615286.5   1076.9
  50.        ========
  51. System Benchmarks Index Score                                        1146.8
  52. root@localhost:~/UnixBench#
发表于 2012-9-16 20:08:22 | 只看该作者
楼上的MJJ
发表于 2012-9-16 20:10:30 | 只看该作者
你每跑一次分,谢总的JJ就疼一次。
发表于 2012-9-16 20:06:34 | 只看该作者
楼下给力的啊
发表于 2012-9-16 20:07:13 | 只看该作者
楼上的MJJ
发表于 2012-9-16 20:17:39 | 只看该作者
楼上说的是我的楼下
发表于 2012-9-16 20:18:21 | 只看该作者
发表于 2012-9-16 20:18:59 | 只看该作者
楼上的MJJ
发表于 2012-9-16 20:21:11 | 只看该作者
发表于 2012-9-16 20:28:01 | 只看该作者
MJJ的跑分 無聊透頂 搞壞服務器。。。。
GMT+8, 2026-5-5 19:01 , Processed in 0.199743 second(s), 12 queries , Gzip On, MemCache On.
