查看: 302|回复: 0
已出 明盘220 出一台OVH CA区 KS-2 硬盘大满贯 4x4T HDD 德国
发表于 2026-4-2 14:59:47 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
4.4到期
CPU型号:Intel(R) Xeon(R) CPU D-1541
CPU核心数: 8核16线程
内存:32G
硬盘:4x4T HDD (中奖)
网络:500M上、10下行(中奖),IPv4 v6均正常未被墙
流量:不限量
机房:CA区德国机房
续费:21.1刀
IPMI:带IPMI
CA/AISA区PUSH
站内信回复有延迟,可联系tg@IwasakiYouko
Basic System Info
CPU Model          : Intel(R) Xeon(R) CPU D-1541 @ 2.10GHz
CPU Cores          : 16 @ 1773.838 MHz
CPU Cache          : 12288 KB
AES-NI             : ✔ Enabled
VM-x/AMD-V         : ✔ Enabled
Total Disk         : 3.6 TB (1.1 GB Used)
Total RAM          : 31.2 GB (597.9 MB Used)
Total Swap         : 2.0 GB (0 Used)
System uptime      : 0 days, 0 hour 7 min
Load average       : 0.34, 0.37, 0.20
OS                 : Debian GNU/Linux 13
Arch               : x86_64 (64 Bit)
Kernel             : 6.12.74+deb13+1-amd64
Virtualization     : NONE
TCP Control        : cubic
Basic Network Info
Primary Network    : IPv6
IPv6 Access        : ✔ Online
IPv4 Access        : ✔ Online
ISP                : OVH SAS
ASN                : AS16276 OVH SAS
Host               : OVH GmbH
Location (IPv4)    : Frankfurt am Main, Hesse, DE
root@ns3090024:~# speedtest
   Speedtest by Ookla
      Server: moji - Paris (id: 62035)
         ISP: OVHcloud
Idle Latency:    10.49 ms   (jitter: 0.03ms, low: 10.46ms, high: 10.53ms)
    Download:  9211.95 Mbps (data used: 16.3 GB)
                 10.63 ms   (jitter: 0.21ms, low: 10.11ms, high: 11.70ms)
      Upload:   470.64 Mbps (data used: 554.8 MB)
                 10.27 ms   (jitter: 0.07ms, low: 10.11ms, high: 10.44ms)
Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/5d0f62ed-3b5b-4945-b30d-0c291ee15b1c
GMT+8, 2026-4-21 12:00 , Processed in 0.066282 second(s), 10 queries , Gzip On, MemCache On.
