查看: 1166|回复: 6
cloudcone是真特么的
发表于 2026-3-25 16:41:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
真特么的,我没法说了,就是个草台班子。
今天发现我部署在cc的博客打不开了,登录了cc的网站管理后台才发现:
  1. Due to the recent hypervisor outage incident, your VPS must be reinstalled before it can be brought back into service. Once reinstalled, you may restore any available backups and resume normal operations. If you have re-installed after seeing this message, you may ignore this notice.
查了下邮件没有给我发过这通知,倒是有另外一台vps过期要删除的通知邮件,就是离谱。
 楼主| 发表于 2026-3-25 16:46:56 | 只看该作者
https://app.cloudcone.com/incident-346624
  1. Dear Client,
  2. We're reaching out with an important update regarding a recent incident that affected your VPS (Virtual Private Server) in LA, USA.
  3. What We First Observed
  4. Our team was initially alerted when our monitoring systems detected that several virtual machines had lost network connectivity.
  5. We confirmed that multiple host nodes were compromised and that the disks of the affected VMs had been corrupted. Our engineering teams immediately isolated the impacted servers and began a detailed analysis.
  6. We attempted data recovery through multiple methods, including examining raw block devices, reconstructing partition tables, and searching for intact filesystems. Unfortunately, these recovery attempts were unsuccessful.
发表于 2026-3-25 16:55:29 | 只看该作者
中毒不是很久前的事情了吗
发表于 2026-3-25 17:14:16 | 只看该作者
一个多月前的事情了
发表于 2026-3-25 17:15:39 | 只看该作者
重要的东西还是做好备份吧
GMT+8, 2026-4-23 06:59 , Processed in 0.069730 second(s), 8 queries , Gzip On, MemCache On.
