查看: 1043|回复: 2
[特价VPS] Chunkserve 上新了,性价比非常高的配置
发表于 2026-3-14 13:33:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VPS 优惠套餐对比 (LET Yearly Deals)
套餐名称        年付价格 (USD)        CPU 核心 (Xeon)        内存 (RAM)        硬盘 (Enterprise SSD)        带宽/流量        每日备份
Deal 1        $11.99        3 vCore        3 GB        25 GB        2Gbps / 10TB        ✅ 有
Deal 2        $9.99        1 vCore        3 GB        40 GB        2Gbps / 10TB        ❌ 无
Deal 3        $20.99        4 vCore        8 GB        50 GB        2Gbps / 20TB        ✅ 有
共同参数:
控制面板: Virtualizor Panel
IP 地址: 1 x IPv4
处理器型号: Intel Xeon E5-2695v4、Intel(R) Xeon(R) Gold 6138 (4) @ 2.00 GHz(Deal 3 款)
库存很少,只释放了 20 台。Deal 3 款已出 5 台了。
xeon-yearly-deal-3-at-let
https://billing.chunkserve.com/aff.php?pid=61&aff=166
xeon-yearly-deal-2-at-let
https://billing.chunkserve.com/aff.php?pid=56&aff=166
xeon-yearly-deal-at-let
https://billing.chunkserve.com/aff.php?pid=55&aff=166
  1.         _,met$$$$$gg.          root@nl-5
  2.      ,g$$$$$$$$$$$$$$$P.       --------------
  3.    ,g$$P""       """Y$$.".     OS: Debian GNU/Linux 13 (trixie) x86_64
  4.   ,$$P'              `$$$.     Host: KVM/QEMU Standard PC (i440FX + PIIX, 1996) (pc-i440fx-9.2)
  5. ',$$P       ,ggs.     `$$b:    Kernel: Linux 6.12.74+deb13+1-amd64
  6. `d$$'     ,$P"'   .    $$$     Uptime: 9 hours, 31 mins
  7. $$P      d$'     ,    $$P     Packages: 630 (dpkg)
  8. $$:      $$.   -    ,d$$'     Shell: bash 5.2.37
  9. $$;      Y$b._   _,d$P'       Display (QEMU Monitor): 1280x800 @ 75 Hz in 15"
  10. Y$$.    `.`"Y$$$$P"'          Cursor: Adwaita
  11. `$$b      "-.__               Terminal: /dev/pts/0
  12.   `Y$$b                        CPU: Intel(R) Xeon(R) Gold 6138 (4) @ 2.00 GHz
  13.    `Y$$.                       GPU: Unknown Device 1111 (VGA compatible)
  14.      `$$b.                     Memory: 442.48 MiB / 7.76 GiB (6%)
  15.        `Y$$b.                  Swap: Disabled
  16.          `"Y$b._               Disk (/): 2.91 GiB / 49.10 GiB (6%) - ext4
  17.              `""""             Local IP (eth0): *.*.*.*/24
  18.                                Locale: en_US.UTF-8
发表于 2026-3-14 14:52:36 | 只看该作者
垃圾小鷄就不要推了,有人不在續費自然放出。
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2026-01-31
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : Intel(R) Xeon(R) CPU E5-2690 v4 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz
  6. CPU Cores          : 4 @ 2596.988 MHz
  7. CPU Cache          : 16384 KB
  8. AES-NI             : ✓ Enabled
  9. VM-x/AMD-V         : ✓ Enabled
  10. Total Disk         : 49.0 GB (3.4 GB Used)
  11. Total RAM          : 7.8 GB (545.1 MB Used)
  12. Total Swap         : 2.6 GB (0 KB Used)
  13. System Uptime      : 32 days, 0 hour 43 min
  14. Load Average       : 0.00, 0.00, 0.00
  15. OS                 : Debian GNU/Linux 13 (trixie)
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 6.12.57+deb13-amd64
  18. TCP Congestion Ctrl: cubic
  19. Virtualization     : KVM
  20. IPv4/IPv6          : ✓ Online / ✓ Online
  21. Organization       : AS214481 Wojciech Czapkowicz
  22. Location           : Amsterdam / NL
  23. Region             : North Holland
  24. ----------------------------------------------------------------------
  25. I/O Speed(1st run) : 262 MB/s
  26. I/O Speed(2nd run) : 631 MB/s
  27. I/O Speed(3rd run) : 704 MB/s
  28. I/O Speed(average) : 532.3 MB/s
  29. ----------------------------------------------------------------------
  30. Node Name        Upload Speed      Download Speed      Latency
  31. Speedtest.net    948.70 Mbps       802.11 Mbps         0.83 ms
  32. Los Angeles, US  850.24 Mbps       2731.07 Mbps        131.06 ms
  33. Dallas, US       789.79 Mbps       2055.19 Mbps        110.22 ms
  34. Montreal, CA     324.23 Mbps       1016.80 Mbps        90.60 ms
  35. Paris, FR        7596.17 Mbps      4146.85 Mbps        9.22 ms
  36. Amsterdam, NL    4753.53 Mbps      5549.38 Mbps        7.56 ms
  37. Suzhou, CN       437.41 Mbps       1563.28 Mbps        235.60 ms
  38. Ningbo, CN       0.39 Mbps         1154.60 Mbps        248.48 ms
  39. Hong Kong, CN    3.06 Mbps         4.28 Mbps           176.22 ms
  40. Singapore, SG    177.14 Mbps       779.57 Mbps         335.15 ms
  41. **ei, CN       448.64 Mbps       2434.64 Mbps        251.28 ms
  42. Tokyo, JP        545.82 Mbps       2309.49 Mbps        212.78 ms
  43. ----------------------------------------------------------------------
  44. Finished in        : 5 min 55 sec
  45. Timestamp          : 2026-03-14 06:57:17 UTC
  46. ----------------------------------------------------------------------
 楼主| 发表于 2026-3-14 15:20:21 | 只看该作者
  5. CPU Model          : Intel(R) Xeon(R) Gold 6138 CPU [url=home.php?mod=space&uid=175]@[/url] 2.00GHz
  6. CPU Cores          : 4 @ 1995.311 MHz
  10. Total Disk         : 49.1 GB (3.0 GB Used)
  11. Total RAM          : 7.8 GB (467.5 MB Used)
  12. System Uptime      : 0 days, 11 hour 19 min
  13. Load Average       : 0.00, 0.00, 0.00
  14. OS                 : Debian GNU/Linux 13 (trixie)
  15. Arch               : x86_64 (64 Bit)
  16. Kernel             : 6.12.74+deb13+1-amd64
  17. TCP Congestion Ctrl: bbr
  18. Virtualization     : KVM
  19. IPv4/IPv6          : ✓ Online / ✓ Online
  20. Organization       : AS214481 Wojciech Czapkowicz
  21. Location           : Amsterdam / NL
  22. Region             : North Holland
  23. ----------------------------------------------------------------------
  24. I/O Speed(1st run) : 386 MB/s
  25. I/O Speed(2nd run) : 709 MB/s
  26. I/O Speed(3rd run) : 767 MB/s
  27. I/O Speed(average) : 620.7 MB/s
  28. ----------------------------------------------------------------------
  29. Node Name        Upload Speed      Download Speed      Latency
  30. Speedtest.net    2031.72 Mbps      1826.72 Mbps        0.60 ms
  31. Los Angeles, US  626.76 Mbps       1901.96 Mbps        131.03 ms
  32. Dallas, US       747.93 Mbps       1688.21 Mbps        111.07 ms
  33. Montreal, CA     845.64 Mbps       715.92 Mbps         111.16 ms
  34. Paris, FR        2032.15 Mbps      1859.39 Mbps        9.36 ms
  35. Amsterdam, NL    2042.31 Mbps      1874.68 Mbps        6.24 ms
  36. Suzhou, CN       339.06 Mbps       1011.79 Mbps        251.73 ms
  37. Ningbo, CN       16.73 Mbps        1107.44 Mbps        232.37 ms
  38. Hong Kong, CN    3.61 Mbps         4.66 Mbps           171.77 ms
  39. ^C
  40. The script has been terminated. Cleaning up files...
是全部售完来上新的。不过感觉他们技术菜,部署后网络不稳定,IP 被别的机子占用了,出现 IP 冲突的情况。
不过,我是看上它内存够大,跑个 gitlab runner 之类的拿来编译应该不错,另外就是欧洲线路干净些,能连 grok / gemini / chatgpt。colocrossing 没法连。
GMT+8, 2026-4-26 00:00 , Processed in 0.065082 second(s), 9 queries , Gzip On, MemCache On.
