查看: 4056|回复: 21
typecho 1.3已发布
发表于 2026-1-20 15:35:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
github 官方仓库:https://github.com/typecho/typecho/
typecho 官方:https://typecho.org/download
What's Changed
fix: adding checkbox options after theme initialization cannot be saved. by @liaocp666 in #1591
Fix typo by @Lanfei in #1612
Fixed ajax prompt message by @sy-records in #1605
fix the source to get content type by @joyqi in #1622
fix: Fix #1597 by @Losses in #1598
增加邮箱也可以登陆的提示 by @jrotty in #1631
Fix null argument issue by @sy-records in #1633
fix #1635 by @joyqi in #1636
gettext for installation comment by @insomnux in #1643
v1.3.0 by @joyqi in #1661
Fix installation failure by @sy-records in #1664
Merge pull request branch automatically by @joyqi in #1669
删除多余无用js by @jrotty in #1668
Dev by @joyqi in #1670
修复“在查看某一分类或标签时无**确生成分页链接” by @libxzr in #1673
fix #1674 by @joyqi in #1676
fix style error for code by @sy-records in #1677
fix #1671 by @joyqi in #1678
fix #1679 by @joyqi in #1680
update theme classic-22 by @fenbox in #1682
Remove useless code by @sy-records in #1683
Optimize applySlug by @sy-records in #1684
More efficient string comparison by @joyqi in #1685
Fix unable to preview revisions by @libxzr in #1687
update theme classic-22 color schema by @fenbox in #1689
fix undefined array key by @joyqi in #1688
Fix/classic 22 by @fenbox in #1690
Fix unable to show attachment parent in manage-medias by @libxzr in #1693
fix attachment handle by @joyqi in #1696
fix trim error by @sy-records in #1697
Fix/classic 22 by @fenbox in #1698
update issue template by @fenbox in #1700
fix: choose the correct key when setting widget value by @joyqi in #1702
fix: getHeader for Content-Type & Content-Length by @imkero in #1703
Fix/classic22 by @fenbox in #1708
fix: xmlrpc message args by @joyqi in #1714
fix: remove special chars by @joyqi in #1716
fix: remove unnecessary DOCTYPE tags by @joyqi in #1715
Upgrade actions/checkout to v4 by @sy-records in #1718
Remove comment link if status is not approved by @joyqi in #1712
Limit build execution by @sy-records in #1723
Fix assign null to property Widget\Archive:archiveKeywords by @sy-records in #1738
Fix missing get date by @sy-records in #1740
update picocss to 2.0 by @fenbox in #1751
fix: nav menu active style by @fenbox in #1752
Fix missing WidgetException error message by @sy-records in #1730
Fix TypeError: Typed property Typecho\Feed:subTitle must be string by @sy-records in #1779
Fix timezone error in XmlRpc by @kraity in #1758
Require PHP 7.4.0 or higher by @sy-records in #1785
Update Login.php by @ZShijun in #1804
Fix sendPingHandle warning by @sy-records in #1808
Fix: fix preg_match parameter#2 $subject is null deprecated issue by @mrchipset in #1798
Fix manage comments failed by @sy-records in #1838
fix #1816 by @joyqi in #1839
fix #1830 by @joyqi in #1841
Fix/1754 by @joyqi in #1842
fix #1843 by @joyqi in #1844
Fix #1846 by @sy-records in #1847
fix typo "稍侯" to "稍候" by @PomeloOfficial in #1850
Remove debug output from category selection in Archive widget by @sy-records in #1852
Fix missing nameExists and mailExists by @sy-records in #1854
Add MariaDB to README.md by @robertsilen in #1827
Feat/improve styles by @joyqi in #1868
feat: validate via regexp by @joyqi in #1877
Update canonical link condition by @sy-records in #1881
fix #1882 by @joyqi in #1883
Fix explicitly declare nullable type for $rules parameter by @sy-records in #1908
Add 'NOT' to query keywords by @sy-records in #1903
Fix login failed when username contains @ by @sy-records in #1894
Support connect to mysql using socket by @sy-records in #1749
修复 PDO::MYSQL_ATTR_USE_BUFFERED_QUERY 的弃用警告 by @xa1st in #1922
修复 PHP 8.5 中 curl_close() 弃用警告 by @Copilot in #1924
$this->getTheme请求第二个参数为多余无用参数 by @jrotty in #1920
Fix XSS vulnerability in comment URL field by improving input filtering by @Copilot in #1933
New Contributors
@liaocp666 made their first contribution in #1591
@Losses made their first contribution in #1598
@libxzr made their first contribution in #1673
@imkero made their first contribution in #1703
@ZShijun made their first contribution in #1804
@mrchipset made their first contribution in #1798
@PomeloOfficial made their first contribution in #1850
@robertsilen made their first contribution in #1827
@xa1st made their first contribution in #1922
@Copilot made their first contribution in #1924
Full Changelog: v1.2.1...v1.3.0
发表于 2026-1-20 15:39:35 | 只看该作者
现在都是 pages 的天下了,php已经开始走下坡路了
发表于 2026-1-20 15:41:09 | 只看该作者
支持一下,请问有什么好的模板吗?
发表于 2026-1-20 15:41:56 | 只看该作者
多少年没更新了。。
发表于 2026-1-20 15:42:51 | 只看该作者
应该是已经凉了,现在是AI的天下,几分钟写一个博客。
 楼主| 发表于 2026-1-20 15:47:36 | 只看该作者
MSN 发表于 2026-1-20 15:41
支持一下,请问有什么好的模板吗?
https://oneblog.net/oneblog
发表于 2026-1-20 17:09:21 | 只看该作者
已经换 hexo 了
发表于 2026-1-20 17:14:55 | 只看该作者
现在还有人写博客吗?
发表于 2026-1-20 22:07:31 | 只看该作者
真凉了
发表于 2026-1-21 20:28:31 | 只看该作者
我擦 居然更新了?
GMT+8, 2026-5-4 16:46 , Processed in 0.071794 second(s), 11 queries , Gzip On, MemCache On.
