查看: 1017|回复: 0
colocrossing 给换了一块硬盘
发表于 2025-12-5 11:59:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
   年头更长 。。。。   就这样吧。。估计他们也没库存。
客服相应还是挺快得,没有啰嗦直接给换了。
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.57+deb13-amd64] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Intel 730 and DC S35x0/3610/3700 Series SSDs
Device Model:     INTEL SSDSC2BA012T4
Serial Number:    BTHV5494055L1P2PGN
LU WWN Device Id: 5 5cd2e4 04c165d05
Firmware Version: G2010140
User Capacity:    1,200,243,695,616 bytes [1.20 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 2.6, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Dec  5 11:52:42 2025 CST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0032   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       76903
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       10
170 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
174 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       7
175 Power_Loss_Cap_Test     0x0033   100   100   010    Pre-fail  Always       -       13220 (325 521)
183 SATA_Downshift_Count    0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0033   100   100   090    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
190 Temperature_Case        0x0022   071   071   000    Old_age   Always       -       29 (Min/Max 24/32)
192 Unsafe_Shutdown_Count   0x0032   100   100   000    Old_age   Always       -       7
194 Temperature_Internal    0x0022   100   100   000    Old_age   Always       -       29
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
225 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       5089969
226 Workld_Media_Wear_Indic 0x0032   100   100   000    Old_age   Always       -       2385
227 Workld_Host_Reads_Perc  0x0032   100   100   000    Old_age   Always       -       53
228 Workload_Minutes        0x0032   100   100   000    Old_age   Always       -       4614226
232 Available_Reservd_Space 0x0033   100   100   010    Pre-fail  Always       -       0
233 Media_Wearout_Indicator 0x0032   098   098   000    Old_age   Always       -       0
234 Thermal_Throttle        0x0032   100   100   000    Old_age   Always       -       0/0
241 Host_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       5089969
242 Host_Reads_32MiB        0x0032   100   100   000    Old_age   Always       -       5796529
243 NAND_Writes_32MiB       0x0032   100   100   000    Old_age   Always       -       28707892
发表于 2025-12-5 13:13:38 来自手机 | 只看该作者
继续让他换
发表于 2025-12-5 13:30:17 | 只看该作者
我就好奇为啥硬盘没坏要一直换,我小白一个
 楼主| 发表于 2025-12-5 14:27:30 | 只看该作者
我也是小白, 头一个硬盘是 消费级的。。。 写入快 200T 了   通电7年多。 有坏道。
容易嘎掉。  换的这个虽然年头长一点 没坏道 好歹是企业级的。
我装 PVE 头一块显示 磨损率 48%
发表于 2025-12-7 07:40:56 | 只看该作者
3500系列我记得是SLC的。嘎嘎耐用
GMT+8, 2026-4-14 15:31 , Processed in 0.060332 second(s), 10 queries , Gzip On, MemCache On.
