查看: 656|回复: 0
[特价VPS] Servarica黑五KVM FAT 6 Slice VDS测试
发表于 2025-12-5 05:41:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
终于不是石头盘了哈哈哈哈哈
(去年黑五的那玩意说是NVME实际石头盘,体感感觉为INTEL SATA SSD系列,最高就读写600MB/s(1M))
今年终于不是石头了
配置如下:
  1. CPU - 6 cores Dedicated
  2. RAM - 24 GB
  3. NVMe - 1500 GB Disk
  4. Bandwidth - 250 mbps Unlimited (or)
  5. 10gbps upto 24TB then 10mbps unlimited
  6. 1 IPv4 Included
  7. Server Location Montreal, Canada
  8. $14/month
  1. 系统信息:
  3. Uptime     : 0 days, 0 hours, 12 minutes
  4. Processor  : AMD EPYC 7532 32-Core Processor
  5. CPU cores  : 6 [url=home.php?mod=space&uid=175]@[/url] 2395.498 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 23.5 GiB
  9. Swap       : 0.0 KiB
  10. Disk       : 1.4 TiB
  11. Distro     : Debian GNU/Linux 12 (bookworm)
  12. Kernel     : 6.1.0-41-cloud-amd64
  13. VM Type    : KVM
  14. IPv4/IPv6  : ✔ Online / ❌ Offline
  15. IPv4网络信息:
  16. ---------------------------------
  17. ISP        : Rica Web Services
  18. ASN        : AS26832 Rica Web Services
  19. Host       : Servarica
  20. Location   : Montreal, Quebec (QC)
  21. Country    : Canada
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 301.61 MB/s  (75.4k) | 3.61 GB/s    (56.4k)
  27. Write      | 302.40 MB/s  (75.6k) | 3.63 GB/s    (56.7k)
  28. Total      | 604.01 MB/s (151.0k) | 7.24 GB/s   (113.1k)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 4.58 GB/s     (8.9k) | 4.71 GB/s     (4.6k)
  33. Write      | 4.82 GB/s     (9.4k) | 5.03 GB/s     (4.9k)
  34. Total      | 9.40 GB/s    (18.3k) | 9.75 GB/s     (9.5k)
  35. iperf3 Network Speed Tests (IPv4):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  38. -----           | -----                     | ----            | ----            | ----
  39. Clouvider       | London, UK (10G)          | 1.22 Gbits/sec  | 1.72 Gbits/sec  | 77.0 ms
  40. Eranium         | Amsterdam, NL (100G)      | 1.72 Gbits/sec  | 2.21 Gbits/sec  | 83.9 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | 1.04 Gbits/sec  | 900 Mbits/sec   | 173 ms
  42. Leaseweb        | Singapore, SG (10G)       | 488 Mbits/sec   | 577 Mbits/sec   | 237 ms
  43. Clouvider       | Los Angeles, CA, US (10G) | busy            | 2.22 Gbits/sec  | 73.8 ms
  44. Leaseweb        | NYC, NY, US (10G)         | 5.70 Gbits/sec  | 6.09 Gbits/sec  | 10.0 ms
  45. Edgoo           | Sao Paulo, BR (1G)        | 1.40 Gbits/sec  | 1.55 Gbits/sec  | 118 ms
  46. -> 内存测试 (Fast Mode, 1-Pass @ 5sec)
  47. 单线程读取:          44232.91 MB/s
  48. 单线程写入:          19828.65 MB/s
  49. -> sysbench CPU测试 (Fast Mode, 1-Pass @ 5sec)
  50. 1核心(单核):          1628 Scores
  51. 6核心(全核):          9769 Scores
  52. GB6:
  53. ---------------------------------
  54. Test            | Value
  55.                 |
  56. Single Core     | 1403
  57. Multi Core      | 6103
GMT+8, 2025-12-24 23:38 , Processed in 0.075538 second(s), 9 queries , Gzip On, MemCache On.
