查看: 1216|回复: 0
colocrossing 这SSD 年头 看着有点怕
发表于 2025-12-4 15:31:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
=== START OF INFORMATION SECTION ===
Model Family:     Samsung based SSDs
Device Model:     Samsung SSD 850 EVO 1TB
Serial Number:    S2RENX0H633829M
LU WWN Device Id: 5 002538 d41087494
Firmware Version: EMT02B6Q
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Dec  4 15:22:21 2025 CST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0033   099   099   010    Pre-fail  Always       -       5
  9 Power_On_Hours          0x0032   086   086   000    Old_age   Always       -       66416
12 Power_Cycle_Count       0x0032   098   098   000    Old_age   Always       -       1199
177 Wear_Leveling_Count     0x0013   052   052   000    Pre-fail  Always       -       1011
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   099   099   010    Pre-fail  Always       -       5
181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0013   099   099   010    Pre-fail  Always       -       5
187 Uncorrectable_Error_Cnt 0x0032   099   099   000    Old_age   Always       -       62
190 Airflow_Temperature_Cel 0x0032   072   053   000    Old_age   Always       -       28
195 ECC_Error_Rate          0x001a   199   199   000    Old_age   Always       -       62
199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
235 POR_Recovery_Count      0x0012   099   099   000    Old_age   Always       -       1194
241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       385594326865
发表于 2025-12-4 15:36:56 | 只看该作者
180TBW,但是850 EVO 1TB官方是150TBW
发表于 2025-12-4 16:05:44 | 只看该作者
咸鱼收点硬件给你换上,没事~
发表于 2025-12-4 16:09:26 | 只看该作者
这家的机器我全扔了,硬盘全是这种古董盘,用着随时炸的感觉,比ovh还老很多
发表于 2025-12-4 16:11:24 来自手机 | 只看该作者
直接工单联系请求换一块
发表于 2025-12-4 16:28:08 | 只看该作者
 楼主| 发表于 2025-12-4 16:47:23 | 只看该作者
sss 发表于 2025-12-4 16:09
这家的机器我全扔了,硬盘全是这种古董盘,用着随时炸的感觉,比ovh还老很多 ...
我 ovh 还是 通电一年多得  企业级SSD 。。。。 写入只有 15T
发表于 2025-12-4 19:46:33 来自手机 | 只看该作者
chinamobile5g 发表于 2025-12-4 16:11
直接工单联系请求换一块
联系更换硬盘要人工费50刀,用炸免费更换新硬盘。
 楼主| 发表于 2025-12-5 10:46:54 | 只看该作者
联系客服了,没说收费得事, 硬盘换了一块。  查了下型号 2015年上市得。。 正在装系统。
上一块 装了 PVE 。。。 磨损率显示 50% 了
GMT+8, 2026-4-15 07:19 , Processed in 0.059253 second(s), 11 queries , Gzip On, MemCache On.
