查看: 691|回复: 2
出OVH IE站 KS-LE-A 6T HDD内存+CPU中奖 顶配
发表于 2025-11-29 16:17:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出280元 月费:9.9欧   我的TG:szzc1227
  1. Fri Nov 21 01:58:03 UTC 2025
  2. Basic System Information:
  3. ---------------------------------
  4. Uptime     : 0 days, 9 hours, 55 minutes
  5. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  6. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 1600.000 MHz
  7. AES-NI     : ✔ Enabled
  8. VM-x/AMD-V : ✔ Enabled
  9. RAM        : 31.2 GiB
  10. Swap       : 1.5 GiB
  11. Disk       : 5.4 TiB
  12. Distro     : Debian GNU/Linux 12 (bookworm)
  13. Kernel     : 6.1.0-41-amd64
  14. VM Type    : NONE
  15. IPv4/IPv6  : ✔ Online / ✔ Online
  16. IPv6 Network Information:
  17. ---------------------------------
  18. ISP        : OVH SAS
  19. ASN        : AS16276 OVH SAS
  20. Host       : OVH SAS
  21. Location   : Roubaix, Hauts-de-France (HDF)
  22. Country    : France
  23. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  25. Block Size | 4k            (IOPS) | 64k           (IOPS)
  26.   ------   | ---            ----  | ----           ----
  27. Read       | 1.42 MB/s      (356) | 21.09 MB/s     (329)
  28. Write      | 1.45 MB/s      (362) | 21.60 MB/s     (337)
  29. Total      | 2.87 MB/s      (718) | 42.69 MB/s     (666)
  30.            |                      |
  31. Block Size | 512k          (IOPS) | 1m            (IOPS)
  33. Read       | 94.34 MB/s     (184) | 96.45 MB/s      (94)
  34. Write      | 99.35 MB/s     (194) | 102.88 MB/s    (100)
  35. Total      | 193.70 MB/s    (378) | 199.33 MB/s    (194)
  36. iperf3 Network Speed Tests (IPv4):
  37. ---------------------------------
  38. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  39. -----           | -----                     | ----            | ----            | ----
  40. Clouvider       | London, UK (10G)          | busy            | 325 Mbits/sec   | 6.54 ms
  41. Eranium         | Amsterdam, NL (100G)      | 424 Mbits/sec   | busy            | 5.96 ms
  42. Uztelecom       | Tashkent, UZ (10G)        | 370 Mbits/sec   | 633 Mbits/sec   | 98.9 ms
  43. Leaseweb        | Singapore, SG (10G)       | 278 Mbits/sec   | busy            | 163 ms
  44. Clouvider       | Los Angeles, CA, US (10G) | 259 Mbits/sec   | busy            | 141 ms
  45. Leaseweb        | NYC, NY, US (10G)         | 357 Mbits/sec   | busy            | 81.8 ms
  46. Edgoo           | Sao Paulo, BR (1G)        | 168 Mbits/sec   | 368 Mbits/sec   | 199 ms
  47. iperf3 Network Speed Tests (IPv6):
  48. ---------------------------------
  49. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  50. -----           | -----                     | ----            | ----            | ----
  51. Clouvider       | London, UK (10G)          | 426 Mbits/sec   | busy            | 6.28 ms
  52. Eranium         | Amsterdam, NL (100G)      | 424 Mbits/sec   | 924 Mbits/sec   | 6.01 ms
  53. Uztelecom       | Tashkent, UZ (10G)        | 369 Mbits/sec   | busy            | 98.7 ms
  54. Leaseweb        | Singapore, SG (10G)       | 303 Mbits/sec   | busy            | 163 ms
  55. Clouvider       | Los Angeles, CA, US (10G) | 286 Mbits/sec   | busy            | 141 ms
  56. Leaseweb        | NYC, NY, US (10G)         | busy            | busy            | 78.9 ms
  57. Edgoo           | Sao Paulo, BR (1G)        | 212 Mbits/sec   | 39.0 Mbits/sec  | 198 ms
  58. Geekbench 6 Benchmark Test:
  59. ---------------------------------
  60. Test            | Value
  61.                 |
  62. Single Core     | 770
  63. Multi Core      | 2699
 楼主| 发表于 2025-11-29 16:18:59 | 只看该作者
  1. This is the choice of Steins;Gate
  2.   CPU 型号              Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  3.   CPU 核心              合计 4 核心,8 线程
  4.   CPU 状态              当前主频 1976.936 MHz
  5.   内存大小              31983 MB (16343 MB 已用)
  6.   交换分区              1535 MB (1521 MB 已用)
  7.   第一种硬盘            HGST_HUS724020ALA640        × 2
  8.   第二种硬盘            HGST_HUS726020ALA610        × 1
  9.   总硬盘大小            共 3 块硬盘,合计 5634.9 GB
  10.   服务器时间            2025-11-21 02:12:35
  11.   运行时间              0 days 10 hour 10 min
  12.   系统负载              1.68, 1.52, 1.43
  13.   虚拟化技术            No Virtualization Detected
  14.   IPv4 地址             5.39.xxx.xxx
  15.   IPv6 地址             2001:41d0:xxxx:xxxx
  16.   运营商                AS16276 OVH SAS
  17.   地理位置              FR, Hauts-de-France, Amiens
  18.   操作系统              Debian 12.12 bookworm (x86_64)
  19.   系统内核              6.1.0-41-amd64
  20.   TCP 加速              bbrz
  21.   当前脚本版本          1.4.1.1
  22.   顺序写入 (1st)        282 MB/s
  23.   顺序写入 (2nd)        212 MB/s
  24.   顺序写入 (3rd)        203 MB/s
  25.   顺序写入 (4th)        237 MB/s
  26.   顺序写入 (5th)        198 MB/s
  27.   顺序写入 (avg)        217.3 MB/s
 楼主| 发表于 2025-11-29 16:20:05 | 只看该作者
  1. Examining hard disk configuration ...
  2. HDD Device 0: /dev/sda
  3. HDD Model ID : HGST HUS726020ALA610
  4. HDD Serial No: K5GTWGBA
  5. HDD Revision : A5GNT920
  6. HDD Size : 1907729 MB
  7. Interface : S-ATA Gen3, 6 Gbps
  8. Temperature : 34 °C
  9. Highest Temp.: 64 °C
  10. Health : 100 %
  11. Performance : 100 %
  12. Power on time: 2103 days, 2 hours
  13. Est. lifetime: more than 100 days
  14. The hard disk status is PERFECT. Problematic or weak sectors were not found and there are no spin up or data transfer errors.
  15. No actions needed.
  16. HDD Device 1: /dev/sdb
  17. HDD Model ID : HGST HUS724020ALA640
  18. HDD Serial No: PN1134P6JLHVNS
  19. HDD Revision : MF6OABY0
  20. HDD Size : 1907729 MB
  21. Interface : S-ATA Gen3, 6 Gbps
  22. Temperature : 30 °C
  23. Highest Temp.: 64 °C
  24. Health : 100 %
  25. Performance : 100 %
  26. Power on time: 3910 days, 4 hours
  27. Est. lifetime: more than 100 days
  28. The hard disk status is PERFECT. Problematic or weak sectors were not found and there are no spin up or data transfer errors.
  29. No actions needed.
  30. HDD Device 2: /dev/sdc
  31. HDD Model ID : HGST HUS724020ALA640
  32. HDD Serial No: PN1161P6HULSGW
  33. HDD Revision : MF6OABY0
  34. HDD Size : 1907729 MB
  35. Interface : S-ATA Gen3, 6 Gbps
  36. Temperature : 34 °C
  37. Highest Temp.: 59 °C
  38. Health : 100 %
  39. Performance : 100 %
  40. Power on time: 3932 days, 19 hours
  41. Est. lifetime: more than 100 days
  42. The hard disk status is PERFECT. Problematic or weak sectors were not found and there are no spin up or data transfer errors.
  43. No actions needed.
GMT+8, 2026-4-24 02:42 , Processed in 0.069366 second(s), 9 queries , Gzip On, MemCache On.
