查看: 1413|回复: 0
axushost 黑五 €5/yr yabs
发表于 2025-11-29 01:41:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
let上的新商家
1 vCore 2 GB DDR4 ECC Memory 20 GB SSD Storage 40 TB Bandwidth @ 10G Port
  3. #                     v2025-04-20                    #
  6. Fri Nov 28 05:17:49 PM GMT 2025
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 4 minutes
  10. Processor  : Intel Xeon Processor (Skylake, IBRS)
  11. CPU cores  : 1 [url=home.php?mod=space&uid=175]@[/url] 1795.781 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 1.9 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 19.9 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-9-amd64
  19. VM Type    : KVM
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : AxusHost B.V.
  24. ASN        : AS214668 AxusHost B.V.
  25. Host       : AxusHost B.V
  26. Location   : Uithoorn, North Holland (NH)
  27. Country    : The Netherlands
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
  32. Read       | 154.68 MB/s  (38.6k) | 1.61 GB/s    (25.1k)
  33. Write      | 155.08 MB/s  (38.7k) | 1.61 GB/s    (25.3k)
  34. Total      | 309.77 MB/s  (77.4k) | 3.23 GB/s    (50.4k)
  38. Read       | 1.95 GB/s     (3.8k) | 1.79 GB/s     (1.7k)
  39. Write      | 2.05 GB/s     (4.0k) | 1.91 GB/s     (1.8k)
  40. Total      | 4.00 GB/s     (7.8k) | 3.70 GB/s     (3.6k)
  45. Clouvider       | London, UK (10G)          | 8.13 Gbits/sec  | 7.94 Gbits/sec  | 6.18 ms
  46. Eranium         | Amsterdam, NL (100G)      | 9.39 Gbits/sec  | 9.41 Gbits/sec  | 0.417 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 2.06 Gbits/sec  | 2.04 Gbits/sec  | 89.5 ms
  48. Leaseweb        | Singapore, SG (10G)       | busy            | 1.11 Gbits/sec  | 161 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 1.17 Gbits/sec  | 1.39 Gbits/sec  | 129 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 2.07 Gbits/sec  | 2.38 Gbits/sec  | 83.5 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 1.11 Gbits/sec  | 934 Mbits/sec   | 194 ms
  52. Geekbench 6 Benchmark Test:
  53. ---------------------------------
  54. Test            | Value
  55.                 |
  56. Single Core     | 639
  57. Multi Core      | 639
  58. Full Test       | https://browser.geekbench.com/v6/cpu/15282603
  59. YABS completed in 19 min 29 sec
发表于 2025-11-29 02:06:48 来自手机 | 只看该作者
居然被抢到了,好像一共就没几台,就是这商家什么都没见卖啊,有点怕
 楼主| 发表于 2025-11-29 02:08:25 | 只看该作者
属于是情绪价值大于使用价值
GMT+8, 2026-5-1 19:27 , Processed in 0.062860 second(s), 10 queries , Gzip On, MemCache On.
