查看: 1253|回复: 0
[美国VPS] 【已出】出2台ovh ks-mystery和1台ccs 洛杉矶i7/1tsdd
发表于 2025-11-23 23:10:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ovh E3-1270 v6/32G/4t NVME. 前几天800收的,800出。
ovh E5-1650 v3/64G/8t HDD。 1000收的,我不知道当前市价,可以按市价卖。
ccs i7 6700k /32G/1T SSD 1350收的,1000出。带原邮出。
ovh都在ie区
  1. Basic System Information:
  3. Uptime     : 15 days, 21 hours, 14 minutes
  4. Processor  : Intel(R) Xeon(R) CPU E3-1270 v6 @3.80GHz
  5. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 800.000 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 31.0 GiB
  9. Swap       : 0.0 KiB
  10. Disk       : 3.5 TiB
  11. Distro     : Ubuntu 24.04.3 LTS
  12. Kernel     : 6.8.0-86-generic
  13. VM Type    : NONE
  14. IPv4/IPv6  : ✔ Online / ✔ Online
  15. IPv6 Network Information:
  16. ---------------------------------
  17. ISP        : OVH SAS
  18. ASN        : AS16276 OVH SAS
  19. Host       : OVH
  20. Location   : Gravelines, Hauts-de-France (HDF)
  21. Country    : France
  22. Warning: Could not parse free space format for /: ''
  23. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  25. Block Size | 4k            (IOPS) | 64k           (IOPS)
  26.   ------   | ---            ----  | ----           ----
  27. Read       | 669.77 MB/s (167.4k) | 1.65 GB/s    (25.8k)
  28. Write      | 671.54 MB/s (167.8k) | 1.66 GB/s    (25.9k)
  29. Total      | 1.34 GB/s   (335.3k) | 3.31 GB/s    (51.8k)
  30.            |                      |
  31. Block Size | 512k          (IOPS) | 1m            (IOPS)
  33. Read       | 1.56 GB/s     (3.0k) | 1.67 GB/s     (1.6k)
  34. Write      | 1.64 GB/s     (3.2k) | 1.78 GB/s     (1.7k)
  35. Total      | 3.21 GB/s     (6.2k) | 3.45 GB/s     (3.3k)
  36. iperf3 Network Speed Tests (IPv4):
  37. ---------------------------------
  38. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  39. -----           | -----                     | ----            | ----            | ----
  40. Clouvider       | London, UK (10G)          | 495 Mbits/sec   | 940 Mbits/sec   | 3.83 ms
  41. Eranium         | Amsterdam, NL (100G)      | 482 Mbits/sec   | 939 Mbits/sec   | 9.00 ms
  42. Uztelecom       | Tashkent, UZ (10G)        | 418 Mbits/sec   | 854 Mbits/sec   | 102 ms
  43. Leaseweb        | Singapore, SG (10G)       | 393 Mbits/sec   | 702 Mbits/sec   | 164 ms
  44. Clouvider       | Los Angeles, CA, US (10G) | 441 Mbits/sec   | 852 Mbits/sec   | 143 ms
  45. Leaseweb        | NYC, NY, US (10G)         | 455 Mbits/sec   | 847 Mbits/sec   | 76.3 ms
  46. Edgoo           | Sao Paulo, BR (1G)        | 345 Mbits/sec   | 805 Mbits/sec   | 197 ms
  47. iperf3 Network Speed Tests (IPv6):
  48. ---------------------------------
  49. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  50. -----           | -----                     | ----            | ----            | ----
  51. Clouvider       | London, UK (10G)          | 489 Mbits/sec   | 928 Mbits/sec   | 20.6 ms
  52. Eranium         | Amsterdam, NL (100G)      | 487 Mbits/sec   | 926 Mbits/sec   | 8.98 ms
  53. Uztelecom       | Tashkent, UZ (10G)        | 414 Mbits/sec   | 871 Mbits/sec   | 102 ms
  54. Leaseweb        | Singapore, SG (10G)       | 420 Mbits/sec   | 721 Mbits/sec   | --
  55. Clouvider       | Los Angeles, CA, US (10G) | 420 Mbits/sec   | 830 Mbits/sec   | 143 ms
  56. Leaseweb        | NYC, NY, US (10G)         | 464 Mbits/sec   | 808 Mbits/sec   | 76.2 ms
  57. Edgoo           | Sao Paulo, BR (1G)        | 400 Mbits/sec   | 748 Mbits/sec   | 197 ms
  3. Uptime     : 151 days, 19 hours, 3 minutes
  4. Processor  : Intel(R) Xeon(R) CPU E5-1650 v3 [url=home.php?mod=space&uid=175]@[/url] 3.50GHz
  5. CPU cores  : 12 @ 2400.000 MHz
  8. RAM        : 62.7 GiB
  9. Swap       : 2.0 GiB
  10. Disk       : 7.2 TiB
  11. Distro     : Ubuntu 22.04.5 LTS
  12. Kernel     : 5.15.0-141-generic
  13. VM Type    : NONE
  17. ISP        : OVH SAS
  19. Host       : OVH
  20. Location   : Roubaix, Hauts-de-France (HDF)
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  23. ---------------------------------
  24. Block Size | 4k            (IOPS) | 64k           (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 1.86 MB/s      (467) | 28.63 MB/s     (447)
  27. Write      | 1.89 MB/s      (473) | 29.01 MB/s     (453)
  28. Total      | 3.76 MB/s      (940) | 57.65 MB/s     (900)
  29.            |                      |
  30. Block Size | 512k          (IOPS) | 1m            (IOPS)
  32. Read       | 129.93 MB/s    (253) | 129.14 MB/s    (126)
  33. Write      | 136.84 MB/s    (267) | 137.74 MB/s    (134)
  34. Total      | 266.77 MB/s    (520) | 266.89 MB/s    (260)
  35. iperf3 Network Speed Tests (IPv4):
  36. ---------------------------------
  37. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  38. -----           | -----                     | ----            | ----            | ----
  39. Clouvider       | London, UK (10G)          | 294 Mbits/sec   | 936 Mbits/sec   | 3.81 ms
  40. Eranium         | Amsterdam, NL (100G)      | 293 Mbits/sec   | 931 Mbits/sec   | 8.94 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | 262 Mbits/sec   | 849 Mbits/sec   | 99.9 ms
  42. Leaseweb        | Singapore, SG (10G)       | 243 Mbits/sec   | 427 Mbits/sec   | 164 ms
  3. Uptime     : 119 days, 18 hours, 56 minutes
  4. Processor  : Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
  5. CPU cores  : 8 @ 1600.211 MHz
  8. RAM        : 31.3 GiB
  9. Swap       : 0.0 KiB
  10. Disk       : 915.8 GiB
  12. Kernel     : 6.8.0-64-generic
  13. VM Type    : NO
  14. IPv4/IPv6  : ✔ Online / ❌ Offline
  15. IPv4 Network Information:
  17. ISP        : HostPapa
  18. ASN        : AS36352 HostPapa
  19. Host       : ColoCrossing
  20. Location   : Los Angeles, California (CA)
  21. Country    : United States
  22. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2):
  26. Read       | 183.73 MB/s  (45.9k) | 236.29 MB/s   (3.6k)
  27. Write      | 184.21 MB/s  (46.0k) | 237.53 MB/s   (3.7k)
  28. Total      | 367.95 MB/s  (91.9k) | 473.82 MB/s   (7.4k)
  29.            |                      |
  32. Read       | 245.39 MB/s    (479) | 238.40 MB/s    (232)
  33. Write      | 258.42 MB/s    (504) | 254.28 MB/s    (248)
  34. Total      | 503.81 MB/s    (983) | 492.69 MB/s    (480)
  39. Clouvider       | London, UK (10G)          | 835 Mbits/sec   | 353 Mbits/sec   | 146 ms
  40. Eranium         | Amsterdam, NL (100G)      | 841 Mbits/sec   | 628 Mbits/sec   | 148 ms
  41. Uztelecom       | Tashkent, UZ (10G)        | 621 Mbits/sec   | 262 Mbits/sec   | 232 ms
  42. Leaseweb        | Singapore, SG (10G)       | 332 Mbits/sec   | 610 Mbits/sec   | --
  43. Edgoo           | Sao Paulo, BR (1G)        | 793 Mbits/sec   | 249 Mbits/sec   | 169 ms
GMT+8, 2026-4-15 14:06 , Processed in 0.063646 second(s), 10 queries , Gzip On, MemCache On.
