查看: 1231|回复: 8
SOLUSVM 财务面板换网络。。。
发表于 2012-9-4 22:20:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. Dear 、。。。。。
  2. Over the next 24 hours our client area (Billing System) will be moved over to a new network. During the switch over, connections to soluslabs.com may be intermittent and you may not be able to gain access to our system. This should not affect your SolusVM license or install, however if your license is less than 24 hours old you may need to clear the DNS cache on the master for the license to update correctly.
  3. Clearing DNS Cache
  4. On another note our external ticket system is currently unavailable and the internal ticket system inside our client area is being temporarily used for support. If you have not received a reply from a ticket you submitted at support.soluslabs.com we urge you to re-submit it via our temporary support system.
  5. Thank you for your understanding & continued support
  6. Regards
  7. Soluslabs Ltd
发表于 2012-9-4 22:24:35 | 只看该作者
全球资讯论坛
发表于 2012-9-4 22:24:39 | 只看该作者
solusvm目前的状态 很鸡肋
发表于 2012-9-4 22:25:47 来自手机 | 只看该作者
发表于 2012-9-4 22:28:58 | 只看该作者
发表于 2012-9-4 22:30:51 | 只看该作者
 楼主| 发表于 2012-9-4 22:37:31 | 只看该作者
star826 发表于 2012-9-4 22:30
这你也关注
收到邮件了。。。
发表于 2012-9-4 22:47:08 | 只看该作者
smyz 发表于 2012-9-4 22:24
全球资讯论坛
发表于 2012-9-4 22:55:19 | 只看该作者
Captain 发表于 2012-9-4 22:47
CP妹子 生意可好
GMT+8, 2026-4-16 14:12 , Processed in 0.153356 second(s), 13 queries , Gzip On, MemCache On.
