查看: 1059|回复: 1
【已出】出一台ovh ie区 KS-LE-B 1270 v6
发表于 2025-11-15 15:24:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
32G 2x450 nvme  法国机房 续费11.8刀每月
RT: 站内交易,直接PM和红包码+欧洲区ID
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2025-05-08
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : Intel(R) Xeon(R) CPU E3-1270 v6 [url=home.php?mod=space&uid=175]@[/url] 3.80GHz
  6. CPU Cores          : 8 [url=home.php?mod=space&uid=175]@[/url] 1198.896 MHz
  7. CPU Cache          : 8192 KB
  8. AES-NI             : ✓ Enabled
  9. VM-x/AMD-V         : ✓ Enabled
  10. Total Disk         : 411.9 GB (1.8 GB Used)
  11. Total Mem          : 31.0 GB (587.8 MB Used)
  12. Total Swap         : 1024.0 MB (0 Used)
  13. System uptime      : 5 days, 7 hour 37 min
  14. Load average       : 0.00, 0.00, 0.00
  15. OS                 : Debian GNU/Linux 12
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 6.1.0-40-amd64
  18. TCP CC             : cubic
  19. Virtualization     : Dedicated
  20. IPv4/IPv6          : ✓ Online / ✓ Online
  21. Organization       : AS16276 OVH SAS
  22. Location           : Gravelines / FR
  23. Region             : Hauts-de-France
  24. ----------------------------------------------------------------------
  25. I/O Speed(1st run) : 513 MB/s
  26. I/O Speed(2nd run) : 512 MB/s
  27. I/O Speed(3rd run) : 513 MB/s
  28. I/O Speed(average) : 512.7 MB/s
  29. ----------------------------------------------------------------------
  30. Node Name        Upload Speed      Download Speed      Latency
  31. Speedtest.net    282.14 Mbps       929.90 Mbps         4.81 ms
  32. Paris, FR        282.10 Mbps       926.45 Mbps         4.92 ms
  33. Amsterdam, NL    18.39 Mbps        940.73 Mbps         10.72 ms
  34. Shanghai, CN     0.89 Mbps         693.11 Mbps         350.60 ms
  35. Hong Kong, CN    283.92 Mbps       910.53 Mbps         170.77 ms
  36. Singapore, SG    40.14 Mbps        410.71 Mbps         322.77 ms
  37. Tokyo, JP        265.21 Mbps       867.89 Mbps         264.60 ms
  38. ----------------------------------------------------------------------
  39. Finished in        : 3 min 20 sec
  40. Timestamp          : 2025-11-13 23:19:06 UTC
  41. ----------------------------------------------------------------------
  短链:
    https://paste.spiritlhl.net/#/show/FfVGw.txt
    http://hpaste.spiritlhl.net/#/show/FfVGw.txt
  每项测试基准见: https://bash.spiritlhl.net/ecsguide[/code]
发表于 2025-11-15 16:13:57 | 只看该作者
是可以直接push?还是该邮箱
 楼主| 发表于 2025-11-15 21:36:45 | 只看该作者
鼠标 发表于 2025-11-15 16:13
是可以直接push?还是该邮箱
欧洲区账号直接push
GMT+8, 2026-4-29 00:25 , Processed in 0.064841 second(s), 10 queries , Gzip On, MemCache On.
