查看: 1511|回复: 3
[不限流量] OVH KE-LE-B 法国SBG机房 顶配测试
发表于 2025-11-13 10:46:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  3. #                     v2025-04-20                    #
  6. Thu Nov 13 10:31:35 CST 2025
  7. Basic System Information:
  9. Uptime     : 8 days, 16 hours, 56 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1270 v6 [url=home.php?mod=space&uid=175]@[/url] 3.80GHz
  11. CPU cores  : 8 @ 4000.350 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 62.5 GiB
  15. Swap       : 33.0 GiB
  16. Disk       : 3.4 TiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-40-amd64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH
  26. Location   : Roubaix, Hauts-de-France (HDF)
  27. Country    : France
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  32. Read       | 647.01 MB/s (161.7k) | 1.64 GB/s    (25.6k)
  33. Write      | 648.72 MB/s (162.1k) | 1.65 GB/s    (25.8k)
  34. Total      | 1.29 GB/s   (323.9k) | 3.29 GB/s    (51.5k)
  38. Read       | 1.96 GB/s     (3.8k) | 2.17 GB/s     (2.1k)
  39. Write      | 2.07 GB/s     (4.0k) | 2.32 GB/s     (2.2k)
  40. Total      | 4.04 GB/s     (7.8k) | 4.49 GB/s     (4.3k)
  45. Clouvider       | London, UK (10G)          | 474 Mbits/sec   | 913 Mbits/sec   | 15.1 ms
  46. Eranium         | Amsterdam, NL (100G)      | 477 Mbits/sec   | 906 Mbits/sec   | 12.3 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | busy            | 823 Mbits/sec   | 91.9 ms
  48. Leaseweb        | Singapore, SG (10G)       | 377 Mbits/sec   | 737 Mbits/sec   | 174 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 439 Mbits/sec   | 853 Mbits/sec   | 144 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 451 Mbits/sec   | busy            | 84.1 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 412 Mbits/sec   | 832 Mbits/sec   | 208 ms
  52. iperf3 Network Speed Tests (IPv6):
  53. ---------------------------------
  54. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  55. -----           | -----                     | ----            | ----            | ----
  56. Clouvider       | London, UK (10G)          | 473 Mbits/sec   | 928 Mbits/sec   | 15.2 ms
  57. Eranium         | Amsterdam, NL (100G)      | 475 Mbits/sec   | 929 Mbits/sec   | 12.3 ms
  58. Uztelecom       | Tashkent, UZ (10G)        | 449 Mbits/sec   | 878 Mbits/sec   | 91.9 ms
  59. Leaseweb        | Singapore, SG (10G)       | 393 Mbits/sec   | 769 Mbits/sec   | 165 ms
  60. Clouvider       | Los Angeles, CA, US (10G) | 426 Mbits/sec   | 843 Mbits/sec   | 144 ms
  61. Leaseweb        | NYC, NY, US (10G)         | 443 Mbits/sec   | 816 Mbits/sec   | 84.1 ms
  62. Edgoo           | Sao Paulo, BR (1G)        | 370 Mbits/sec   | 792 Mbits/sec   | 208 ms
  63. Geekbench 6 Benchmark Test:
  64. ---------------------------------
  65. Test            | Value
  66.                 |
  67. Single Core     | 1355
  68. Multi Core      | 4421
  69. Full Test       | https://browser.geekbench.com/v6/cpu/15004333
 楼主| 发表于 2025-11-13 10:47:47 | 只看该作者
  1. Hard Disk Sentinel for LINUX console 0.19c.9986 (c) 2021 info@hdsentinel.com
  2. Start with -r [reportfile] to save data to report, -h for help
  3. Examining hard disk configuration ...
  4. HDD Device  0: /dev/nvme0
  5. HDD Model ID : INTEL SSDPF2KX019T1O
  6. HDD Serial No: BTAX253400F61P9BGN
  7. HDD Revision : 9CV10490
  8. HDD Size     : 0 MB
  9. Interface    : NVMe
  10. Temperature  : 32 °C
  11. Highest Temp.: 32 °C
  12. Health       : 100 %
  13. Performance  : 100 %
  14. Power on time: 110 days, 5 hours
  15. Est. lifetime: more than 1000 days
  16. Total written: 12.83 TB
  17.   The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
  18.   The health is determined by SSD specific S.M.A.R.T. attribute(s):  Available Spare (Percent), Percentage Used
  19.     No actions needed.
  20. HDD Device  1: /dev/nvme1
  21. HDD Model ID : INTEL SSDPF2KX019T1O
  22. HDD Serial No: BTAX253400F31P9BGN
  23. HDD Revision : 9CV10490
  24. HDD Size     : 0 MB
  25. Interface    : NVMe
  26. Temperature  : 32 °C
  27. Highest Temp.: 32 °C
  28. Health       : 100 %
  29. Performance  : 100 %
  30. Power on time: 110 days, 5 hours
  31. Est. lifetime: more than 1000 days
  32. Total written: 12.65 TB
  33.   The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
  34.   The health is determined by SSD specific S.M.A.R.T. attribute(s):  Available Spare (Percent), Percentage Used
  35.     No actions needed.
 楼主| 发表于 2025-11-13 10:48:46 | 只看该作者
  1.   CPU 型号              Intel(R) Xeon(R) CPU E3-1270 v6 [url=home.php?mod=space&uid=175]@[/url] 3.80GHz
  2.   CPU 核心              合计 4 核心,8 线程
  3.   CPU 状态              当前主频 4021.086 MHz
  4.   内存大小              63988 MB (46656 MB 已用)
  5.   交换分区              33791 MB (3982 MB 已用)
  6.   第 1 块硬盘           通电 2645 小时,型号 INTEL SSDPF2KX019T1O
  7.   第 2 块硬盘           通电 2645 小时,型号 INTEL SSDPF2KX019T1O
  8.   硬盘大小              3586.5 GB
  9.   服务器时间            2025-11-13 10:47:10
  10.   运行时间              8 days 17 hour 12 min
  11.   系统负载              1.32, 2.14, 1.72
  12.   虚拟化技术            No Virtualization Detected
  13.   IPv4 地址             54.38.xxx.xxx
  14.   IPv6 地址             2001:41d0:xxxx:xxxx
  15.   运营商                AS16276 OVH SAS
  16.   地理位置              FR, Grand Est, Strasbourg
  17.   操作系统              Debian 12.12 bookworm (x86_64)
  18.   系统内核              6.1.0-40-amd64
  19.   TCP 加速              bbrz
  20.   当前脚本版本          1.4.1.1
  21.   顺序写入 (1st)        1500 MB/s
  22.   顺序写入 (2nd)        1500 MB/s
  23.   顺序写入 (3rd)        1500 MB/s
  24.   顺序写入 (4th)        1400 MB/s
  25.   顺序写入 (5th)        1500 MB/s
  26.   顺序写入 (avg)        1500.0 MB/s
发表于 2025-11-13 10:55:35 | 只看该作者
老哥这是用什么脚本测的,求分享
 楼主| 发表于 2025-11-13 12:19:48 来自手机 | 只看该作者
杜甫测试带宽:  curl -sL https://yabs.sh | bash  杜甫测试通电时间:  wget -q https://github.com/Aniverse/A/raw/i/a && bash a  杜甫测试写入量:  wget -c https://www.hdsentinel.com/hdslin/hdsentinel-019c-x64.gz gunzip  hdsentinel-019c-x64.gz  chmod 755  hdsentinel-019c-x64  ./hdsentinel-019c-x64
GMT+8, 2026-4-24 09:20 , Processed in 0.059104 second(s), 10 queries , Gzip On, MemCache On.
