查看: 1350|回复: 3
[不限流量] OVH KS-LE-B 德国顶配 测试
发表于 2025-11-12 14:00:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ##
  2. Yet-Another-Bench-Script
  3. v2025-04-20
  4. https://github.com/masonr/yet-another-bench-script
  5. ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ##
  6. Tue Nov 4 20:58:28 CST 2025
  7. Basic System Information:
  8. Uptime : 0 days, 0 hours, 6 minutes
  9. Processor : Intel(R) Xeon(R) CPU E3-1270 v6 [url=home.php?mod=space&uid=175]@[/url] 3.80GHz
  10. CPU cores : 8 @ 3800.430 MHz
  11. AES-NI : ✔ Enabled
  12. VM-x/AMD-V : ✔ Enabled
  13. RAM : 62.5 GiB
  14. Swap : 2.0 GiB
  15. Disk : 3.4 TiB
  16. Distro : Debian GNU/Linux 12 (bookworm)
  17. Kernel : 6.8.12-16-pve
  18. VM Type : NONE
  19. IPv4/IPv6 : ✔ Online / ✔ Online
  20. IPv6 Network Information:
  21. ISP : OVH SAS
  22. ASN : AS16276 OVH SAS
  23. Host : OVH GmbH
  24. Location : Saarbrücken, Saarland (SL)
  25. Country : Germany
  26. Warning: Could not parse free space format for /: ''
  27. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
  28. Block Size | 4k (IOPS) | 64k (IOPS)
  29. ------ | --- ---- | ---- ----
  30. Read | 678.23 MB/s (169.5k) | 1.78 GB/s (27.8k)
  31. Write | 680.02 MB/s (170.0k) | 1.79 GB/s (28.0k)
  32. Total | 1.35 GB/s (339.5k) | 3.57 GB/s (55.9k)
  33. | |
  34. Block Size | 512k (IOPS) | 1m (IOPS)
  35. ------ | --- ---- | ---- ----
  36. Read | 1.76 GB/s (3.4k) | 1.84 GB/s (1.8k)
  37. Write | 1.85 GB/s (3.6k) | 1.97 GB/s (1.9k)
  38. Total | 3.61 GB/s (7.0k) | 3.81 GB/s (3.7k)
  39. iperf3 Network Speed Tests (IPv4):
  40. Provider        Location (Link)        Send Speed        Recv Speed        Ping
  41. Clouvider        London, UK (10G)        484 Mbits/sec        944 Mbits/sec        14.9 ms
  42. Eranium        Amsterdam, NL (100G)        497 Mbits/sec        946 Mbits/sec        8.48 ms
  43. Uztelecom        Tashkent, UZ (10G)        482 Mbits/sec        892 Mbits/sec        90.4 ms
  44. Leaseweb        Singapore, SG (10G)        408 Mbits/sec        544 Mbits/sec        161 ms
  45. Clouvider        Los Angeles, CA, US (10G)        445 Mbits/sec        571 Mbits/sec        148 ms
  46. Leaseweb        NYC, NY, US (10G)        454 Mbits/sec        814 Mbits/sec        91.3 ms
  47. Edgoo        Sao Paulo, BR (1G)        414 Mbits/sec        799 Mbits/sec        207 ms
  48. iperf3 Network Speed Tests (IPv6):
  49. Provider        Location (Link)        Send Speed        Recv Speed        Ping
  50. Clouvider        London, UK (10G)        464 Mbits/sec        907 Mbits/sec        14.9 ms
  51. Eranium        Amsterdam, NL (100G)        busy        913 Mbits/sec        8.71 ms
  52. Uztelecom        Tashkent, UZ (10G)        433 Mbits/sec        busy        90.2 ms
  53. Leaseweb        Singapore, SG (10G)        406 Mbits/sec        busy        161 ms
  54. Clouvider        Los Angeles, CA, US (10G)        389 Mbits/sec        627 Mbits/sec        148 ms
  55. Leaseweb        NYC, NY, US (10G)        206 Mbits/sec        busy        91.0 ms
  56. Edgoo        Sao Paulo, BR (1G)        359 Mbits/sec        763 Mbits/sec        207 ms
  57. Geekbench 6 Benchmark Test:
  58. Test | Value
  59. |
  60. Single Core | 1324
  61. Multi Core | 4725
  62. Full Test | https://browser.geekbench.com/v6/cpu/14843504
 楼主| 发表于 2025-11-12 14:01:31 | 只看该作者
  1. Hard Disk Sentinel for LINUX console 0.19c.9986 (c) 2021 info@hdsentinel.com
  2. Start with -r [reportfile] to save data to report, -h for help
  3. Examining hard disk configuration ...
  4. HDD Device  0: /dev/nvme0
  5. HDD Model ID : SAMSUNG MZQLB1T9HAJR-0000
  6. HDD Serial No: S439NA0NA02796
  7. HDD Revision : EDA5702Q
  8. HDD Size     : 1831420 MB
  9. Interface    : NVMe
  10. Temperature  : 31 °C
  11. Highest Temp.: 31 °C
  12. Health       : 98 %
  13. Performance  : 100 %
  14. Power on time: 1468 days, 0 hours
  15. Est. lifetime: more than 342 days
  16. Total written: 316.24 TB
  17.   The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
  18.   The health is determined by SSD specific S.M.A.R.T. attribute(s):  Available Spare (Percent), Percentage Used
  19.     No actions needed.
  20. HDD Device  1: /dev/nvme1
  21. HDD Model ID : SAMSUNG MZQLB1T9HAJR-0000
  22. HDD Serial No: S439NA0NA02141
  23. HDD Revision : EDA5702Q
  24. HDD Size     : 1831420 MB
  25. Interface    : NVMe
  26. Temperature  : 30 °C
  27. Highest Temp.: 30 °C
  28. Health       : 98 %
  29. Performance  : 100 %
  30. Power on time: 1468 days, 0 hours
  31. Est. lifetime: more than 342 days
  32. Total written: 317.32 TB
  33.   The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
  34.   The health is determined by SSD specific S.M.A.R.T. attribute(s):  Available Spare (Percent), Percentage Used
  35.     No actions needed.
 楼主| 发表于 2025-11-12 14:02:38 | 只看该作者
  1.   CPU 型号              Intel(R) Xeon(R) CPU E3-1270 v6 [url=home.php?mod=space&uid=175]@[/url] 3.80GHz
  2.   CPU 核心              合计 4 核心,8 线程
  3.   CPU 状态              当前主频 4001.264 MHz
  4.   内存大小              63991 MB (55414 MB 已用)
  5.   交换分区              30719 MB (2004 MB 已用)
  6.   第 1 块硬盘           通电 35232 小时,型号 SAMSUNG MZQLB1T9HAJR-00007
  7.   第 2 块硬盘           通电 35232 小时,型号 SAMSUNG MZQLB1T9HAJR-00007
  8.   硬盘大小              3602.2 GB
  9.   服务器时间            2025-11-12 14:02:17
  10.   运行时间              7 days 17 hour 10 min
  11.   系统负载              0.16, 0.29, 0.33
  12.   虚拟化技术            No Virtualization Detected
  13.   IPv4 地址             51.75.xxx.xxx
  14.   IPv6 地址             2001:41d0:xxxx:xxxx
  15.   运营商                AS16276 OVH SAS
  16.   地理位置              DE, Hesse, Frankfurt am Main
  17.   操作系统              Debian 12.12 bookworm (x86_64)
  18.   系统内核              6.8.12-16-pve
  19.   TCP 加速              bbr
  20.   当前脚本版本          1.4.1.1
  21.   顺序写入 (1st)        1700 MB/s
  22.   顺序写入 (2nd)        1700 MB/s
  23.   顺序写入 (3rd)        1700 MB/s
  24.   顺序写入 (4th)        1700 MB/s
  25.   顺序写入 (5th)        1700 MB/s
  26.   顺序写入 (avg)        1700.0 MB/s
 楼主| 发表于 2025-11-12 18:25:29 来自手机 | 只看该作者
德国顶配  只此一台
GMT+8, 2026-4-24 02:38 , Processed in 0.059111 second(s), 10 queries , Gzip On, MemCache On.
