查看: 946|回复: 1
[美国VPS] 已出600出BHS区 KS-LE-B E3-1230v6+32G+2X2T NVME
发表于 2025-11-9 15:15:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IE区PUSH
机型:KS-LE-B
续费月租9.9欧
│ ═══ /dev/nvme0n1 ═══
│   Basic Info:  1.7T SAMSUNG MZQLB1T9HAJR-00007
│   SMART状态: PASSED
│   通电时间: 29,715 hours
│   Data Transfer Statistics:
│     总读取量: 24.52 TB
│     总写入量: 251.11 TB
│   温度: 36°C
│   已使用耐久度: 3%
│   可用备用块: 100%
│   关键警告: 0x00
│   健康状态: 97%
│ ═══ /dev/nvme1n1 ═══
│   SMART状态: PASSED
│   通电时间: 22,740 hours
│     总读取量: 388.14 TB
│     总写入量: 1.02 PB
│   温度: 36°C
│   已使用耐久度: 7%
│   可用备用块: 100%
│   关键警告: 0x00
│   健康状态: 93%
Uptime     : 0 days, 2 hours, 34 minutes
Processor  : Intel(R) Xeon(R) CPU E3-1230 v6 @ 3.50GHz
CPU cores  : 8 @ 3334.277 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 31.0 GiB
Swap       : 0.0 KiB
Disk       : 3.4 TiB
Distro     : Debian GNU/Linux 12 (bookworm)
Kernel     : 6.1.0-40-amd64
VM Type    : NONE
IPv4/IPv6  : ✔ Online / ✔ Online
IPv6 Network Information:
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH Hosting, Inc.
Country    : Canada
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md2):
Read       | 698.82 MB/s (174.7k) | 1.81 GB/s    (28.3k)
Write      | 700.67 MB/s (175.1k) | 1.82 GB/s    (28.4k)
Total      | 1.39 GB/s   (349.8k) | 3.63 GB/s    (56.8k)
Read       | 1.84 GB/s     (3.5k) | 1.82 GB/s     (1.7k)
Write      | 1.93 GB/s     (3.7k) | 1.94 GB/s     (1.8k)
Total      | 3.77 GB/s     (7.3k) | 3.76 GB/s     (3.6k)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 423 Mbits/sec   | 899 Mbits/sec   | 75.4 ms
Eranium         | Amsterdam, NL (100G)      | 419 Mbits/sec   | 787 Mbits/sec   | 95.8 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | 555 Mbits/sec   | 181 ms
Leaseweb        | Singapore, SG (10G)       | 391 Mbits/sec   | 616 Mbits/sec   | 233 ms
Clouvider       | Los Angeles, CA, US (10G) | 454 Mbits/sec   | 903 Mbits/sec   | 68.4 ms
Leaseweb        | NYC, NY, US (10G)         | 494 Mbits/sec   | 938 Mbits/sec   | 10.6 ms
Edgoo           | Sao Paulo, BR (1G)        | 425 Mbits/sec   | 796 Mbits/sec   | 143 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 433 Mbits/sec   | 889 Mbits/sec   | 75.6 ms
Eranium         | Amsterdam, NL (100G)      | 404 Mbits/sec   | 796 Mbits/sec   | 95.8 ms
Uztelecom       | Tashkent, UZ (10G)        | 414 Mbits/sec   | 815 Mbits/sec   | 181 ms
Leaseweb        | Singapore, SG (10G)       | 398 Mbits/sec   | 327 Mbits/sec   | --
Clouvider       | Los Angeles, CA, US (10G) | 440 Mbits/sec   | 893 Mbits/sec   | 68.3 ms
Leaseweb        | NYC, NY, US (10G)         | 487 Mbits/sec   | 925 Mbits/sec   | 10.3 ms
Edgoo           | Sao Paulo, BR (1G)        | 414 Mbits/sec   | 842 Mbits/sec   | 143 ms
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 1124
Multi Core      | 4419
Full Test       | https://browser.geekbench.com/v5/cpu/23890296
发表于 2025-11-11 20:12:39 | 只看该作者
绑定,不太好卖。
发表于 2025-11-12 09:24:39 | 只看该作者
好机,可惜没账号
GMT+8, 2026-4-24 09:20 , Processed in 0.069841 second(s), 8 queries , Gzip On, MemCache On.
