查看: 781|回复: 0
有大佬搭建TrinityCore Master版本的吗?客户端一直连不上
发表于 2025-11-1 18:54:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TrinityCore Master 11.2.5.63906编译无错,
已经更新realmlist为正确的IP:192.168.1.100
Worldserver和bnetserver均启动成功无报错,
由于手头上没有63906的魔兽客户端,只有下载了最新的11.2.5.64154客户端
wtf port已经更新为192.168.1.100
但用Arctium登陆器 登录一直是you have been disconnected
为什么呢?怎么解决??谢谢!
WLK3.3.5我是启动正常的,就是这个Master版本连不上
root@TrinityCore:~# /opt/wow/server/bin/bnetserver --config /opt/wow/server/etc/bnetserver.conf
TrinityCore rev. 0b4f02c00212 2025-10-31 13:49:07 +0100 (master branch) (Linux, x86_64, RelWithDebInfo, Static) (bnetserver)
<Ctrl-C> to stop.
______                       __
/\__  _\       __          __/\ \__
\/_/\ \/ _ __ /\_\    ___ /\_\ \, _\  __  __
   \ \ \/\`'__\/\ \ /' _ `\/\ \ \ \/ /\ \/\ \
    \ \ \ \ \/ \ \ \/\ \/\ \ \ \ \ \_\ \ \_\ \
     \ \_\ \_\  \ \_\ \_\ \_\ \_\ \__\\/`____ \
      \/_/\/_/   \/_/\/_/\/_/\/_/\/__/ `/___/> \
                                 C O R E  /\___/
http://TrinityCore.org                    \/__/
Using configuration file /opt/wow/server/etc/bnetserver.conf.
Using SSL version: OpenSSL 3.0.17 1 Jul 2025 (library: OpenSSL 3.0.17 1 Jul 2025)
Using Boost version: 1.74.0
Automatic database updates are disabled for all databases!
Opening DatabasePool 'auth'. Asynchronous connections: 1, synchronous connections: 1.
MySQL client library: 8.4.7
MySQL server ver: 8.4.7
Connected to MySQL database at 127.0.0.1
DatabasePool 'auth' opened successfully. 2 total connections running.
Started auth database connection pool.
Loading IP Location Database...
Registered new handler for GET /bnetserver/login/
Registered new handler for GET /bnetserver/gameAccounts/
Registered new handler for GET /bnetserver/portal/
Registered new handler for POST /bnetserver/login/
Registered new handler for POST /bnetserver/login/srp/
Registered new handler for POST /bnetserver/refreshLoginTicket/
Added realm "Trinity" at 192.168.1.100 127.0.0.1 (port 8085).
GMT+8, 2026-1-11 15:54 , Processed in 0.068008 second(s), 9 queries , Gzip On, MemCache On.
