查看: 6085|回复: 5
Backorder 问题!!
发表于 2009-6-10 07:14:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我要买的域名 godaddy 显示 Backorder
我一定可以买到吗?
我查了一下资料
whois server version 2.0
domain names in the .com and .net domains can now be registered
with many different competing registrars. go to http://www.internic.net
for detailed information.
domain name: 这个不公开.com
registrar: dstr acquisition pa i, llc dba domainbank.com
whois server: rs.domainbank.net
referral url: http://www.domainbank.net
name server: ns1.sedoparking.com
name server: ns2.sedoparking.com
status: clientdeleteprohibited
status: clienttransferprohibited
status: clientupdateprohibited
updated date: 22-may-2009
creation date: 17-jul-1997
expiration date: 16-jul-2009
>>> last update of whois database: tue, 09 jun 2009 23:07:14 utc <<<
notice: the expiration date displayed in this record is the date the
registrar's sponsorship of the domain name registration in the registry is
currently set to expire. this date does not necessarily reflect the expiration
date of the domain name registrant's agreement with the sponsoring
registrar. users may consult the sponsoring registrar's whois database to
view the registrar's reported date of expiration for this registration.
terms of use: you are not authorized to access or query our whois
database through the use of electronic processes that are high-volume and
automated except as reasonably necessary to register domain names or
modify existing registrations; the data in verisign global registry
services' ("verisign") whois database is provided by verisign for
information purposes only, and to assist persons in obtaining information
about or related to a domain name registration record. verisign does not
guarantee its accuracy. by submitting a whois query, you agree to abide
by the following terms of use: you agree that you may use this data only
for lawful purposes and that under no circumstances will you use this data
to: (1) allow, enable, or otherwise support the transmission of mass
unsolicited, commercial advertising or solicitations via e-mail, telephone,
or facsimile; or (2) enable high volume, automated, electronic processes
that apply to verisign (or its computer systems). the compilation,
repackaging, dissemination or other use of this data is expressly
prohibited without the prior written consent of verisign. you agree not to
use electronic processes that are automated and high-volume to access or
query the whois database except as reasonably necessary to register
domain names or modify existing registrations. verisign reserves the right
to restrict your access to the whois database in its sole discretion to ensure
operational stability. verisign may restrict or terminate your access to the
whois database for failure to abide by these terms of use. verisign
reserves the right to modify these terms at any time.
the registry database contains only .com, .net, .edu domains and
registrars.
[rs.domainbank.net]
the information in this whois database is provided for the sole
purpose of assisting you in obtaining information about domain
name registration records. this information is available "as is,"
and we do not guarantee its accuracy. by submitting a whois
query, you agree that you will use this data only for lawful
purposes and that, under no circumstances will you use this data
to: (1) enable high volume, automated, electronic processes that
stress or load this whois database system providing you this
information; or (2) allow,enable, or otherwise support the
transmission of mass, unsolicited, commercial advertising or
solicitations via facsimile, electronic mail, or by telephone to
entitites other than your own existing customers. the
compilation, repackaging, dissemination or other use of this data
is expressly prohibited without prior written consent from this
company. we reserve the right to modify these terms at any
time. by submitting an inquiry, you agree to these terms of usage
and limitations of warranty. please limit your queries to 10 per
minute and one connection.
domain services provided by:
domain bank, support@domainbank.com
http:///www.domainbank.com
registrant:
peoples net services ltd.
lower ground studios
london, london nw3 5na
gb
registrar: domainbank
created on: 17-jul-97
expires on: 16-jul-09
last updated on: 22-may-09
administrative contact:
rosen, sam sam@peoplesnet.net
gb
2079166000
technical contact:
gb
2079164000
domain servers in listed order:
ns1.sedoparking.com
ns2.sedoparking.com
end of whois information
发表于 2009-6-10 08:34:58 | 只看该作者
回复 1# 的帖子
这个域名 今年7月16号到期,如果没有其他人抢注的话你还是有机会得到,另外也看域名主人是否续费了。
如果是很多人关注的域名的话,godaddy的抢注成功率不大好,pool enom的抢注的成功率比较大。
 楼主| 发表于 2009-6-10 10:16:45 | 只看该作者
哎!!都不知道怎么办啊!!如果他续费了 那不就等于再等一年吗?
 楼主| 发表于 2009-6-10 10:17:28 | 只看该作者
还有一个域名 我查了 是godaddy 自己注册的 也是18.99 这样买 成功率高点吗?
发表于 2009-6-10 10:43:51 | 只看该作者
回复 3# 的帖子
抢注就是这样,没有100%保证的。
发表于 2009-6-10 10:44:27 | 只看该作者
回复 4# 的帖子
如果是godaddy注册的域名,godaddy抢注成功率会更高些。
GMT+8, 2026-4-25 12:50 , Processed in 0.059732 second(s), 10 queries , Gzip On, MemCache On.
