查看: 4162|回复: 6
有用debian去安装LNMP0.4成功的吗?
发表于 2010-4-9 13:18:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DiaHosting VPS 的,有用debian去安装LNMP0.4成功的吗?
 楼主| 发表于 2010-4-9 13:20:39 | 只看该作者
选用debian 32位的,一直折腾不成功;
CentOS 32位就很顺利,郁闷。
发表于 2010-4-9 17:28:25 | 只看该作者
是下载的今天的包吗?
 楼主| 发表于 2010-4-9 21:16:11 | 只看该作者
是的,刚才重新安装了,是最新更新版本;
MYSQL还是不成功,报错为:
MySQL manager or server PID file could not be found! failed!
Starting MySQL.Manager of pid-file quit without updating file. failed!
查看日志,报示为:
100409 20:56:35 mysqld_safe Starting mysqld daemon with databases from /usr/local/mysql/var
100409 20:56:35 [Warning] The syntax '--skip-locking' is deprecated and will be removed in a future release. Please use --skip-external-locking instead.
100409 20:56:35 [ERROR] Can't start server : Bind on unix socket: Permission denied
100409 20:56:35 [ERROR] Do you already have another mysqld server running on socket: /tmp/mysql.sock ?
100409 20:56:35 [ERROR] Aborting
100409 20:56:35 [Note] /usr/local/mysql/libexec/mysqld: Shutdown complete
发表于 2010-4-9 22:01:12 | 只看该作者
发表于 2010-4-10 00:28:15 | 只看该作者
没尝试过呢
 楼主| 发表于 2010-4-10 09:00:56 | 只看该作者
查了系统环境为:
# cat /proc/version
Linux version 2.6.26-2-xen-686 (Debian 2.6.26-19lenny2) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 SMP Wed Nov 4 23:23:33 UTC 2009
GMT+8, 2026-4-18 20:36 , Processed in 0.059889 second(s), 10 queries , Gzip On, MemCache On.
