12
返回列表 发新帖
楼主: LMVPS
[Windows VPS] 求Ping,又加分啊
发表于 2012-8-28 18:19:54 | 只看该作者
C:\> ping 103.246.114.1
Pinging 103.246.114.1 with 32 bytes of data:
Reply from 103.246.114.1: bytes=32 time=79ms TTL=46
Reply from 103.246.114.1: bytes=32 time=81ms TTL=46
Reply from 103.246.114.1: bytes=32 time=86ms TTL=46
Ping statistics for 103.246.114.1:
    Minimum = 79ms, Maximum = 86ms, Average = 83ms
C:\>
山东移动wifi
参与人数 1威望 +1 收起 理由
LMVPS + 1 赞一个!
发表于 2012-8-28 18:24:26 | 只看该作者
http://www.thegigabit.com
带宽和香港一样.. 2M起步
正在 Ping 103.246.114.1 具有 32 字节的数据:
来自 103.246.114.1 的回复: 字节=32 时间=18ms TTL=54
来自 103.246.114.1 的回复: 字节=32 时间=19ms TTL=54
来自 103.246.114.1 的回复: 字节=32 时间=31ms TTL=54
来自 103.246.114.1 的回复: 字节=32 时间=20ms TTL=54
参与人数 1威望 +1 收起 理由
LMVPS + 1 赞一个!
发表于 2012-8-28 18:25:46 | 只看该作者
马来西亚的,带宽多少?
湖南电信 21MS
发表于 2012-8-28 18:33:56 | 只看该作者
                                     56ms  电信        ——来自全球MJJ交流论坛客户端
参与人数 1威望 +1 收起 理由
LMVPS + 1 赞一个!
发表于 2012-8-28 19:13:29 | 只看该作者
since@since:~$ ping 103.246.114.1
PING 103.246.114.1 (103.246.114.1) 56(84) bytes of data.
64 bytes from 103.246.114.1: icmp_req=1 ttl=52 time=265 ms
64 bytes from 103.246.114.1: icmp_req=2 ttl=52 time=263 ms
64 bytes from 103.246.114.1: icmp_req=3 ttl=52 time=266 ms
64 bytes from 103.246.114.1: icmp_req=4 ttl=52 time=271 ms
64 bytes from 103.246.114.1: icmp_req=5 ttl=52 time=262 ms
64 bytes from 103.246.114.1: icmp_req=6 ttl=52 time=262 ms
64 bytes from 103.246.114.1: icmp_req=7 ttl=52 time=262 ms
64 bytes from 103.246.114.1: icmp_req=8 ttl=52 time=262 ms
64 bytes from 103.246.114.1: icmp_req=9 ttl=52 time=275 ms
64 bytes from 103.246.114.1: icmp_req=10 ttl=52 time=265 ms
64 bytes from 103.246.114.1: icmp_req=11 ttl=52 time=262 ms
64 bytes from 103.246.114.1: icmp_req=12 ttl=52 time=263 ms
64 bytes from 103.246.114.1: icmp_req=13 ttl=52 time=263 ms
64 bytes from 103.246.114.1: icmp_req=14 ttl=52 time=262 ms
^C
--- 103.246.114.1 ping statistics ---
14 packets transmitted, 14 received, 0% packet loss, time 13002ms
rtt min/avg/max/mdev = 262.094/264.828/275.640/3.898 ms
since@since:~$ traceroute 103.246.114.1
The program 'traceroute' can be found in the following packages:
* inetutils-traceroute
* traceroute
Try: sudo apt-get install <selected package>
since@since:~$ sudo apt-get install traceroute
[sudo] password for since:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  python-virtkey libmtp9 gir1.2-rb-3.0 gir1.2-gstreamer-0.10 python-pyatspi2 python-mako gir1.2-ubuntuoneui-3.0 libdmapsharing-3.0-2 rhythmbox-data
  libdiscid0 libmtp-runtime libgpod-common python-louis liblouis-data python-speechd librhythmbox-core5 libgpod4 python-brlapi liblouis2
  gir1.2-gst-plugins-base-0.10 gir1.2-atspi-2.0 libubuntuoneui-3.0-1 libmtp-common media-player-info python-markupsafe libmusicbrainz3-6
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
  traceroute
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 53.1 kB of archives.
After this operation, 162 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ precise/universe traceroute amd64 1:2.0.18-1 [53.1 kB]
Fetched 53.1 kB in 0s (241 kB/s)
Selecting previously unselected package traceroute.
(Reading database ... 150044 files and directories currently installed.)
Unpacking traceroute (from .../traceroute_1%3a2.0.18-1_amd64.deb) ...
Processing triggers for man-db ...
Setting up traceroute (1:2.0.18-1) ...
update-alternatives: using /usr/bin/traceroute.db to provide /usr/bin/traceroute (traceroute) in auto mode.
update-alternatives: using /usr/bin/lft.db to provide /usr/bin/lft (lft) in auto mode.
update-alternatives: using /usr/bin/traceproto.db to provide /usr/bin/traceproto (traceproto) in auto mode.
update-alternatives: using /usr/sbin/tcptraceroute.db to provide /usr/sbin/tcptraceroute (tcptraceroute) in auto mode.
traceroute to 103.246.114.1 (103.246.114.1), 30 hops max, 60 byte packets
1  DD-WRT (192.168.1.1)  0.909 ms  1.725 ms  2.049 ms
2  pubwp.comcast.net (50.195.63.254)  8.979 ms  9.131 ms  9.222 ms
3  73.218.92.1 (73.218.92.1)  13.653 ms  14.446 ms  18.854 ms
4  te-7-2-ur01.lawrence.ma.boston.comcast.net (68.85.140.137)  19.015 ms  19.198 ms  19.554 ms
5  be-66-ar01.needham.ma.boston.comcast.net (68.85.69.73)  22.205 ms  26.456 ms  26.571 ms
6  he-2-9-0-0-cr01.newyork.ny.ibone.comcast.net (68.86.90.57)  37.956 ms  28.772 ms  26.671 ms
7  pos-0-2-0-0-pe01.111eighthave.ny.ibone.comcast.net (68.86.87.226)  24.021 ms  24.857 ms  25.002 ms
8  tenge2-4.br01.nyc01.pccwbtn.net (63.218.9.1)  23.032 ms  18.826 ms  23.006 ms
9  63-218-240-250.static.pccwglobal.net (63.218.240.250)  271.537 ms  271.895 ms  272.891 ms
10  103.246.114.1 (103.246.114.1)  273.363 ms  273.448 ms  262.705 ms
since@since:~$
美国comcast
发表于 2012-8-28 19:32:31 来自手机 | 只看该作者
export PATH=/data/local/binPATH
app_49@android:/ $ export PATH=/data/local/binPATH
app_49@android:/ $ ping -c 7 103.246.114.1
64 bytes from 103.246.114.1: icmp_seq=1 ttl=55 time=918 ms
64 bytes from 103.246.114.1: icmp_seq=2 ttl=55 time=113 ms
64 bytes from 103.246.114.1: icmp_seq=3 ttl=55 time=125 ms
64 bytes from 103.246.114.1: icmp_seq=4 ttl=55 time=190 ms
64 bytes from 103.246.114.1: icmp_seq=5 ttl=55 time=123 ms
64 bytes from 103.246.114.1: icmp_seq=6 ttl=55 time=128 ms
64 bytes from 103.246.114.1: icmp_seq=7 ttl=55 time=132 ms
7 packets transmitted, 7 received, 0% packet loss, time 6005ms
rtt min/avg/max/mdev = 113.525/247.309/918.029/274.811 ms
app_49@android:/ $
发表于 2012-8-28 19:35:14 | 只看该作者
来自 103.246.114.1 的回复: 字节=32 时间=96ms TTL=50
来自 103.246.114.1 的回复: 字节=32 时间=118ms TTL=50
来自 103.246.114.1 的回复: 字节=32 时间=105ms TTL=50
来自 103.246.114.1 的回复: 字节=32 时间=108ms TTL=50
103.246.114.1 的 Ping 统计信息:
往返行程的估计时间(以毫秒为单位):
    最短 = 96ms,最长 = 118ms,平均 = 106ms
联通
GMT+8, 2026-4-18 19:32 , Processed in 0.062269 second(s), 10 queries , Gzip On, MemCache On.
