查看: 1536|回复: 2
[不限流量] 【已出】出一台月付9.9欧的OVH KS-LE-1
发表于 2025-9-7 21:55:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
【已出】
CPU: E3-1245 V2
内存: 32G
硬盘: 2×960GB SSD (安装的PVE, yabs仅显示之一)
V4:上 300Mbps 下 1Gbps
每月一号已出账单到10.1,总价450,PUSH出,
站内联系~
 楼主| 发表于 2025-9-7 21:56:32 | 只看该作者
curl -sL yabs.sh | bash
Yet-Another-Bench-Script
v2025-04-20
https://github.com/masonr/yet-another-bench-script
Sun Sep 7 13:03:59 UTC 2025
Basic System Information:
Uptime : 134 days, 4 hours, 18 minutes
Processor : Intel(R) Xeon(R) CPU E3-1245 V2 @ 3.40GHz
CPU cores : 8 @ 3689.815 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM : 31.2 GiB
Swap : 1024.0 MiB
Disk : 877.9 GiB
Distro : Debian GNU/Linux 12 (bookworm)
Kernel : 6.8.12-5-pve
VM Type : NONE
IPv4/IPv6 : ✔ Online / ✔ Online
IPv6 Network Information:
ISP : OVH SAS
ASN : AS16276 OVH SAS
Host : OVH SAS
Country : France
Warning: Could not parse free space format for /: ''
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2):
Block Size | 4k (IOPS) | 64k (IOPS)
Read | 167.21 MB/s (41.8k) | 215.14 MB/s (3.3k)
Write | 167.65 MB/s (41.9k) | 216.27 MB/s (3.3k)
Total | 334.87 MB/s (83.7k) | 431.42 MB/s (6.7k)
Block Size | 512k (IOPS) | 1m (IOPS)
Read | 211.89 MB/s (413) | 239.22 MB/s (233)
Write | 223.15 MB/s (435) | 255.15 MB/s (249)
Total | 435.04 MB/s (848) | 494.37 MB/s (482)
Provider        Location (Link)        Send Speed        Recv Speed        Ping
Clouvider        London, UK (10G)        288 Mbits/sec        515 Mbits/sec        3.85 ms
Eranium        Amsterdam, NL (100G)        287 Mbits/sec        937 Mbits/sec        118 ms
Uztelecom        Tashkent, UZ (10G)        213 Mbits/sec        211 Mbits/sec        99.8 ms
Leaseweb        Singapore, SG (10G)        127 Mbits/sec        309 Mbits/sec        162 ms
Clouvider        Los Angeles, CA, US (10G)        212 Mbits/sec        118 Mbits/sec        141 ms
Leaseweb        NYC, NY, US (10G)        253 Mbits/sec        338 Mbits/sec        75.9 ms
Edgoo        Sao Paulo, BR (1G)        155 Mbits/sec        338 Mbits/sec        215 ms
iperf3 Network Speed Tests (IPv6):
Clouvider        London, UK (10G)        283 Mbits/sec        483 Mbits/sec        3.88 ms
Eranium        Amsterdam, NL (100G)        219 Mbits/sec        542 Mbits/sec        118 ms
Uztelecom        Tashkent, UZ (10G)        busy        222 Mbits/sec        99.7 ms
Leaseweb        Singapore, SG (10G)        150 Mbits/sec        301 Mbits/sec        162 ms
Clouvider        Los Angeles, CA, US (10G)        144 Mbits/sec        187 Mbits/sec        141 ms
Leaseweb        NYC, NY, US (10G)        248 Mbits/sec        364 Mbits/sec        75.7 ms
Edgoo        Sao Paulo, BR (1G)        163 Mbits/sec        320 Mbits/sec        211 ms
Geekbench 6 Benchmark Test:
Test | Value
Single Core | 721
Multi Core | 2369
Full Test | https://browser.geekbench.com/v6/cpu/13697380
YABS completed in 17 min 39 sec
 楼主| 发表于 2025-9-7 22:15:14 | 只看该作者
有个情况说一下, 因为怕ovh涨价,之前确认了下一年的commitment,12个月但一直是月付9.9欧,我刚才看了下无法取消这个commitment:
You are currently committed to your ns3365682.ip-37-187-.eu commitment until 1 June 2026.
我理解push会保留这个commitment
发表于 2025-9-8 01:48:55 来自手机 | 只看该作者
收一台ks2 加拿大
GMT+8, 2026-4-19 02:51 , Processed in 0.065198 second(s), 10 queries , Gzip On, MemCache On.
