查看: 964|回复: 0
出ccs 8t大盘鸡
发表于 2025-8-29 13:20:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
洛杉矶流量40T,年付179刀,剩余11个月左右,剩余价值+50出。
这次上新好像没有双路机器
配置跑分如图
  3. #                     v2025-04-20                    #
  6. 2025年 07月 25日 星期五 12:22:41 CST
  7. Basic System Information:
  9. Uptime     : 0 days, 1 hours, 20 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E5-2620 0 [url=home.php?mod=space&uid=175]@[/url] 2.00GHz
  11. CPU cores  : 24 [url=home.php?mod=space&uid=175]@[/url] 1200.000 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 62.9 GiB
  15. Swap       : 975.0 MiB
  16. Disk       : 7.2 TiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-37-amd64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : HostPapa
  24. ASN        : AS36352 HostPapa
  25. Host       : HostPapa
  26. Location   : Los Angeles, California (CA)
  27. Country    : United States
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2):
  32. Read       | 1.81 MB/s      (453) | 13.03 MB/s     (203)
  33. Write      | 1.83 MB/s      (459) | 13.66 MB/s     (213)
  34. Total      | 3.64 MB/s      (912) | 26.69 MB/s     (416)
  38. Read       | 48.76 MB/s      (95) | 72.38 MB/s      (70)
  39. Write      | 51.64 MB/s     (100) | 77.20 MB/s      (75)
  40. Total      | 100.41 MB/s    (195) | 149.59 MB/s    (145)
  45. Clouvider       | London, UK (10G)          | 819 Mbits/sec   | 194 Mbits/sec   | 132 ms
  46. Eranium         | Amsterdam, NL (100G)      | 835 Mbits/sec   | 568 Mbits/sec   | 146 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 542 Mbits/sec   | 267 Mbits/sec   | 235 ms
  48. Leaseweb        | Singapore, SG (10G)       | 774 Mbits/sec   | 624 Mbits/sec   | 174 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 939 Mbits/sec   | 941 Mbits/sec   | 0.456 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 895 Mbits/sec   | 668 Mbits/sec   | 63.7 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 752 Mbits/sec   | 324 Mbits/sec   | 177 ms
  52. Geekbench 5 Benchmark Test:
  53. ---------------------------------
  54. Test            | Value
  55.                 |
  56. Single Core     | 568
  57. Multi Core      | 6406
  58. Full Test       | https://browser.geekbench.com/v5/cpu/23688247
发表于 2025-8-29 13:58:45 | 只看该作者
用不到,绑定
发表于 2025-8-29 15:51:53 | 只看该作者
能不能加 ssd 硬盘?
发表于 2025-8-29 18:13:51 来自手机 | 只看该作者
只要给钱,无所不能哈
GMT+8, 2026-4-28 06:33 , Processed in 0.056996 second(s), 9 queries , Gzip On, MemCache On.
