查看: 781|回复: 6
灵车飘逸系列
发表于 2025-8-7 20:20:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
购买地址(年付29.9)
https://charityhost.org/account/store/nodeseek-specials
  1. Processor  : AMD Ryzen 9 7950X3D 16-Core Processor
  2. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 4191.988 MHz
  3. AES-NI     : ✔ Enabled
  4. VM-x/AMD-V : ✔ Enabled
  5. RAM        : 7.8 GiB
  6. Swap       : 0.0 KiB
  7. Disk       : 245.9 GiB
  8. Distro     : Debian GNU/Linux 12 (bookworm)
  9. Kernel     : 6.1.0-31-amd64
  10. VM Type    : KVM
  11. IPv4/IPv6  : ✔ Online / ✔ Online
  12. IPv6 Network Information:
  13. ---------------------------------
  14. ISP        : The Optimal Link Corp / Oplink.net
  15. ASN        : AS40156 The Optimal Link Corporation
  16. Host       : NeoTechAdmin LLC
  17. Location   : Spring, Texas (TX)
  18. Country    : United States
  19. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  20. ---------------------------------
  21. Block Size | 4k            (IOPS) | 64k           (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 267.07 MB/s  (66.7k) | 2.22 GB/s    (34.8k)
  24. Write      | 267.77 MB/s  (66.9k) | 2.23 GB/s    (34.9k)
  25. Total      | 534.85 MB/s (133.7k) | 4.46 GB/s    (69.7k)
  26.            |                      |
  27. Block Size | 512k          (IOPS) | 1m            (IOPS)
  28.   ------   | ---            ----  | ----           ----
  29. Read       | 1.61 GB/s     (3.1k) | 1.76 GB/s     (1.7k)
  30. Write      | 1.69 GB/s     (3.3k) | 1.87 GB/s     (1.8k)
  31. Total      | 3.31 GB/s     (6.4k) | 3.63 GB/s     (3.5k)
  32. iperf3 Network Speed Tests (IPv4):
  33. ---------------------------------
  34. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  35. -----           | -----                     | ----            | ----            | ----
  36. Clouvider       | London, UK (10G)          | 669 Mbits/sec   | 794 Mbits/sec   | 104 ms
  37. Eranium         | Amsterdam, NL (100G)      | 821 Mbits/sec   | 789 Mbits/sec   | 118 ms
  38. Uztelecom       | Tashkent, UZ (10G)        | 726 Mbits/sec   | 700 Mbits/sec   | 207 ms
  39. Leaseweb        | Singapore, SG (10G)       | 690 Mbits/sec   | 675 Mbits/sec   | 207 ms
  40. Clouvider       | Los Angeles, CA, US (10G) | 884 Mbits/sec   | 499 Mbits/sec   | 40.3 ms
  41. Leaseweb        | NYC, NY, US (10G)         | 883 Mbits/sec   | 826 Mbits/sec   | 38.8 ms
  42. Edgoo           | Sao Paulo, BR (1G)        | 786 Mbits/sec   | 798 Mbits/sec   | 144 ms
  43. iperf3 Network Speed Tests (IPv6):
  44. ---------------------------------
  45. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  46. -----           | -----                     | ----            | ----            | ----
  47. Clouvider       | London, UK (10G)          | 689 Mbits/sec   | 793 Mbits/sec   | 104 ms
  48. Eranium         | Amsterdam, NL (100G)      | 815 Mbits/sec   | 791 Mbits/sec   | 118 ms
  49. Uztelecom       | Tashkent, UZ (10G)        | 722 Mbits/sec   | 713 Mbits/sec   | 206 ms
  50. Leaseweb        | Singapore, SG (10G)       | 692 Mbits/sec   | 705 Mbits/sec   | 207 ms
  51. Clouvider       | Los Angeles, CA, US (10G) | 883 Mbits/sec   | 755 Mbits/sec   | 36.7 ms
  52. Leaseweb        | NYC, NY, US (10G)         | 878 Mbits/sec   | 789 Mbits/sec   | 38.7 ms
  53. Edgoo           | Sao Paulo, BR (1G)        | 784 Mbits/sec   | 533 Mbits/sec   | 144 ms
  54. Geekbench 6 Benchmark Test:
  55. ---------------------------------
  56. Test            | Value
  57.                 |
  58. Single Core     | 2575
  59. Multi Core      | 4568
  60. Full Test       | https://browser.geekbench.com/v6/cpu/13211824
看着还有2个,喜欢冲灵车的可以冲一下。
发表于 2025-8-7 20:44:10 | 只看该作者
不敢冲。楼下继续
https://host.charity/
发表于 2025-8-7 20:52
发表于 2025-8-7 20:39:10 | 只看该作者
29块还是29刀,要是29刀真不敢上车
发表于 2025-8-7 20:50:00 | 只看该作者
nodeseek-specials 还是人傻钱多好哇
 楼主| 发表于 2025-8-8 10:47:33 | 只看该作者
不说那就是刀了。
GMT+8, 2025-12-24 17:03 , Processed in 0.164771 second(s), 15 queries , Gzip On, MemCache On.
