查看: 1234|回复: 9
乌龟壳说我挖矿,怎么破?
发表于 2025-7-2 17:22:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Oracle Cloud Infrastructure Customer,
Oracle Cloud Infrastructure (OCI) has received notice of or detected unusual and potentially harmful activity originating from your tenancy.
Abuse Details: Crypto or Cyber-Currency Coin-Mining Activity
Action Required: Under your agreement with Oracle, you are responsible for the maintenance and security of this resource. You may wish to inspect the resource(s) for compromise or misconfiguration and mitigate the indicated issues. If the activity continues beyond the Disable By date provided in the details column, or Oracle determines that there is a significant threat to the functionality, security, integrity, or availability of our services, your resource(s) may be disabled.
我系统都重新安装了,过了几天就又收到邮件
发表于 2025-7-2 19:59:39 | 只看该作者
你不装探针看鸡鸡占用情况的吗
发表于 2025-7-2 17:25:27 | 只看该作者
发表于 2025-7-2 17:32:01 | 只看该作者
实际情况是啥
 楼主| 发表于 2025-7-2 17:42:13 | 只看该作者
只用于FQ,里面啥也没装
发表于 2025-7-2 17:43:25 | 只看该作者
别用一键脚本
 楼主| 发表于 2025-7-2 17:48:04 | 只看该作者
pstree -a 的结果:
systemd
  |-accounts-daemon
  |   `-2*[{accounts-daemon}]
  |-agent
  |   |-gomon
  |   |   `-8*[{gomon}]
  |   |-oci-wlp
  |   |   `-8*[{oci-wlp}]
  |   `-7*[{agent}]
  |-agetty -o -p -- \\u --keep-baud 115200,38400,9600 ttyS0 vt220
  |-agetty -o -p -- \\u --noclear tty1 linux
  |-atd -f
  |-cron -f
  |-dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
  |-irqbalance --foreground
  |   `-{irqbalance}
  |-lvmetad -f
  |-lxcfs /var/lib/lxcfs/
  |   `-6*[{lxcfs}]
  |-networkd-dispat /usr/bin/networkd-dispatcher --run-startup-triggers
  |   `-{networkd-dispat}
  |-polkitd --no-debug
  |   `-2*[{polkitd}]
  |-rpcbind -f -w
  |-rsyslogd -n
  |   `-3*[{rsyslogd}]
  |-screen -R trojan
  |   `-bash
  |       `-trojan-go
  |           `-8*[{trojan-go}]
  |-screen -R mihomo
  |   `-bash
  |       `-mihomo -d ./
  |           `-8*[{mihomo}]
  |-snapd
  |   `-9*[{snapd}]
  |-sshd -D
  |   `-sshd
  |       `-sshd
  |           `-bash
  |               `-sudo -i
  |                   `-bash
  |                       `-pstree -a
  |-systemd --user
  |   `-(sd-pam)
  |-systemd-journal
  |-systemd-logind
  |-systemd-network
  |-systemd-resolve
  |-systemd-timesyn
  |   `-{systemd-timesyn}
  |-systemd-udevd
  |-unattended-upgr /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
  |   `-{unattended-upgr}
  `-updater
      `-8*[{updater}]
发表于 2025-7-2 18:20:27 来自手机 | 只看该作者
你的脚本有问题 或许是dd脚本出问题
发表于 2025-7-2 19:49:26 | 只看该作者
那还不重装系统等ban号吗
发表于 2025-7-2 19:51:17 | 只看该作者
不用查,直接去控制台后台看占用率,包准
GMT+8, 2026-4-13 17:19 , Processed in 0.068284 second(s), 11 queries , Gzip On, MemCache On.
