查看: 912|回复: 2
已出NETCUP 美东G95 ,月租6.25o
发表于 2025-6-28 22:22:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Processor
AMD EPYC™ 7702  实际上开的是9634CPU ,和G11一样的U
CPU cores
4 dedicated
Main memory DDR4 ECC
8 GB
Server location
Manassas, USA
Hard disk:
320 GB SSD (instead of 160 GB)
Network traffic
On average, 1 Gbps bandwidth is available at least, assuming the root server disposes of a 2.5 Gbps network interface card. If more than 120 TB traffic is used within a month and, in addition, if more than 1 Gbps bandwidth is continuously used over a period of more than 60 minutes on average, the network connection of the root server can be limited to a minimum of 200 Mbps so that other customers do not have any disadvantages.
Local Block Storage
Yes, expandable with Local Block Storage up to max. 8 TB
小半年没回论坛了, 出个机, 200口令,给转移码。
私信或者以下联系方式去掉“=”。
发表于 2025-6-29 07:47:52 来自手机 | 只看该作者
这个应该会变成常规款,后面大概率每个月都会有。
发表于 2025-6-29 11:42:29 | 只看该作者
这款是美东因为u不够导致7703变9634,算是卡bug款,后期估计只会有德国了
GMT+8, 2026-4-13 23:59 , Processed in 0.063033 second(s), 10 queries , Gzip On, MemCache On.
