查看: 1588|回复: 18
[交易VPS] 260+剩余价值出ovh.ie法国续费13.99o v4v6上下g口
发表于 2025-6-28 18:37:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ie区push,先款或你付中介费。
仅支持微信、qq、支付宝付款。
论坛 微信 qq 沟通。
next payment 1 September 2025
服务器型号: KS-LE-1
数据中心: rbx2
网口速率: 1000 Mbps
实际处理器: E3-1245v2
每个处理器的核心数: 4
每个处理器的线程数: 8
内存大小: 32768 MB
磁盘组:
描述: 2 X Disk SSD 480 GB, JBOD
磁盘类型: SSD
磁盘数量: 2
  3. #                     v2025-04-20                    #
  6. Thu Jun 26 17:53:53 CST 2025
  7. Basic System Information:
  9. Uptime     : 60 days, 18 hours, 32 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  11. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 3800.000 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.2 GiB
  15. Swap       : 2.0 GiB
  16. Disk       : 892.9 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-33-amd64
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH SAS
  26. Location   : Roubaix, Hauts-de-France (HDF)
  27. Country    : France
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md2):
  32. Read       | 268.61 MB/s  (67.1k) | 417.66 MB/s   (6.5k)
  33. Write      | 269.32 MB/s  (67.3k) | 419.85 MB/s   (6.5k)
  34. Total      | 537.93 MB/s (134.4k) | 837.52 MB/s  (13.0k)
  38. Read       | 412.78 MB/s    (806) | 431.27 MB/s    (421)
  39. Write      | 434.71 MB/s    (849) | 459.99 MB/s    (449)
  40. Total      | 847.50 MB/s   (1.6k) | 891.26 MB/s    (870)
  45. Clouvider       | London, UK (10G)          | 925 Mbits/sec   | 931 Mbits/sec   | 4.57 ms
  46. Eranium         | Amsterdam, NL (100G)      | 924 Mbits/sec   | 932 Mbits/sec   | 9.78 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 844 Mbits/sec   | 354 Mbits/sec   | 101 ms
  48. Leaseweb        | Singapore, SG (10G)       | 793 Mbits/sec   | 494 Mbits/sec   | 167 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 634 Mbits/sec   | 432 Mbits/sec   | 140 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 859 Mbits/sec   | 554 Mbits/sec   | 83.3 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 741 Mbits/sec   | 274 Mbits/sec   | 219 ms
  52. iperf3 Network Speed Tests (IPv6):
  53. ---------------------------------
  54. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  55. -----           | -----                     | ----            | ----            | ----
  56. Clouvider       | London, UK (10G)          | 886 Mbits/sec   | 790 Mbits/sec   | 4.64 ms
  57. Eranium         | Amsterdam, NL (100G)      | 886 Mbits/sec   | 880 Mbits/sec   | 9.91 ms
  58. Uztelecom       | Tashkent, UZ (10G)        | 740 Mbits/sec   | busy            | 101 ms
  59. Leaseweb        | Singapore, SG (10G)       | 685 Mbits/sec   | 215 Mbits/sec   | --
  60. Clouvider       | Los Angeles, CA, US (10G) | 601 Mbits/sec   | 228 Mbits/sec   | 140 ms
  61. Leaseweb        | NYC, NY, US (10G)         | 807 Mbits/sec   | 241 Mbits/sec   | 83.3 ms
  62. Edgoo           | Sao Paulo, BR (1G)        | 638 Mbits/sec   | 196 Mbits/sec   | 219 ms
  63. Geekbench 6 Benchmark Test:
  64. ---------------------------------
  65. Test            | Value
  66.                 |
  67. Single Core     | 677
  68. Multi Core      | 2423
  69. Full Test       | https://browser.geekbench.com/v6/cpu/12605451
  70. YABS completed in 17 min 19 sec
发表于 2025-7-2 19:33:13 | 只看该作者
这个CPU很弱  内存大多都是 64G  续费还这么贵 直接丢了把
 楼主| 发表于 2025-6-28 21:21:48 | 只看该作者
(っ´ω`c)
 楼主| 发表于 2025-6-29 13:12:40 | 只看该作者
( ´•̥̥̥ω•̥̥̥` )
 楼主| 发表于 2025-7-1 00:30:09 | 只看该作者
(っ´ω`c)
发表于 2025-7-1 04:18:26 | 只看该作者
牛哇,这鸡居然还有v4的G口
 楼主| 发表于 2025-7-1 16:07:29 | 只看该作者
ฅ^•ﻌ•^ฅ
 楼主| 发表于 2025-7-1 20:56:15 | 只看该作者
▼・ᴥ・▼
 楼主| 发表于 2025-7-2 14:46:06 | 只看该作者
(๑´ڡ`๑)
发表于 2025-7-2 15:11:46 来自手机 | 只看该作者
hz g口  netcup  2.5g口
 楼主| 发表于 2025-7-2 19:19:06 | 只看该作者
hkbbdx 发表于 2025-7-2 15:11
hz g口  netcup  2.5g口
hz的月付得到两倍以上,netcup限制总流量。ovh算是最便宜得真不限量g口大厂。
GMT+8, 2025-12-23 23:51 , Processed in 0.081596 second(s), 10 queries , Gzip On, MemCache On.
