查看: 1266|回复: 9
[美国VPS] ccs 被挂马了,貌似是挖矿的
发表于 2025-5-27 10:48:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
畜生行为啊
  1. root@linux:~/sftp# ll
  2. total 3340
  3. drwxr-xr-x 2 root root    4096 May 27 01:47 ./
  4. drwx------ 8 root root    4096 May 27 02:31 ../
  5. -rwxrwxrwx 1 root root    3980 May 27 01:56 config.json*
  6. -rwxr-xr-x 1 root root     410 May 27 01:47 xmrig_wrapper.sh*
  7. -rwxrwxrwx 1 root root 3401080 Apr 27 06:36 xmrigx86*
XMRig mining software with watchdog wrapper
路径  /etc/systemd/system/xmrigx86.service
2025年5月27日 10:41 /root/sftp/xmrig_wrapper.sh: line 13: 28208 Killed "$SERVICE_PATH" >> "$LOG_FILE" 2>&1
XMRig Cleaner Service
路径  /etc/systemd/system/xmrig-cleaner.service
2025年5月27日 10:46 xmrig-cleaner.service: Failed with result 'exit-code
10:46 xmrig-cleaner.service: Main process exited, code=exited, status=203/EXEC
10:46 Started xmrig-cleaner.service - XMRig Cleaner Service.
10:46 xmrig-cleaner.service: Scheduled restart job, restart counter is at 320.
 楼主| 发表于 2025-5-27 10:49:06 | 只看该作者
  1. root@linux:~/sftp# cat  ~/sftp/config.json
  2. {
  3.     "api": {
  4.         "id": null,
  5.         "worker-id": null
  6.     },
  7.     "http": {
  8.         "enabled": false,
  9.         "host": "127.0.0.1",
  10.         "port": 0,
  11.         "access-token": null,
  12.         "restricted": true
  13.     },
  14.     "autosave": true,
  15.     "background": false,
  16.     "colors": false,
  17.     "title": true,
  18.     "randomx": {
  19.         "init": -1,
  20.         "init-avx2": 0,
  21.         "mode": "auto",
  22.         "1gb-pages": false,
  23.         "rdmsr": true,
  24.         "wrmsr": true,
  25.         "cache_qos": false,
  26.         "numa": true,
  27.         "scratchpad_prefetch_mode": 1
  28.     },
  29.     "cpu": {
  30.         "enabled": true,
  31.         "huge-pages": true,
  32.         "huge-pages-jit": false,
  33.         "hw-aes": null,
  34.         "priority": null,
  35.         "memory-pool": true,
  36.         "yield": true,
  37.         "asm": true,
  38.         "argon2-impl": null,
  39.         "argon2": [0, 1],
  40.         "cn": [
  41.             [1, 0],
  42.             [1, 1]
  43.         ],
  44.         "cn-heavy": [
  45.             [1, 0],
  46.             [1, 1]
  47.         ],
  48.         "cn-lite": [
  49.             [1, 0],
  50.             [1, 1]
  51.         ],
  52.         "cn-pico": [
  53.             [2, 0],
  54.             [2, 1]
  55.         ],
  56.         "cn/2": [
  57.             [1, 0],
  58.             [1, 1]
  59.         ],
  60.         "cn/gpu": [
  61.             [1, 0],
  62.             [1, 1]
  63.         ],
  64.         "cn/upx2": [
  65.             [2, 0],
  66.             [2, 1]
  67.         ],
  68.         "flex": [0, 1],
  69.         "ghostrider": [
  70.             [8, 0],
  71.             [8, 1]
  72.         ],
  73.         "panthera": [0, 1],
  74.         "rx": [0, 1],
  75.         "rx/wow": [0, 1],
  76.         "cn-lite/0": false,
  77.         "cn/0": false,
  78.         "rx/xeq": "rx/wow",
  79.         "rx/arq": "rx/wow",
  80.         "rx/keva": "rx/wow"
  81.     },
  82.     "log-file": null,
  83.     "donate-level": 0,
  84.     "donate-over-proxy": 1,
  85.     "pools": [
  86.         {
  87.             "algo": null,
  88.             "coin": null,
  89.             "url": "auto.c3pool.org:17777",
  90.             "user": "88LDNGE7BiYaSVHqDGuew1i6mvX4ufhrB7g1C5YaNCSPcUzG3aVTuTaKw25yrfcu88YrSoQDyUYCifKkfU4zYPSd75YP8Ah",
  91.             "pass": "x",
  92.             "rig-id": null,
  93.             "nicehash": false,
  94.             "keepalive": true,
  95.             "enabled": true,
  96.             "tls": false,
  97.             "sni": false,
  98.             "tls-fingerprint": null,
  99.             "daemon": false,
  100.             "socks5": null,
  101.             "self-select": null,
  102.             "submit-to-origin": false
  103.         }
  104.     ],
  105.     "retries": 5,
  106.     "retry-pause": 5,
  107.     "print-time": 60,
  108.     "dmi": true,
  109.     "syslog": false,
  110.     "tls": {
  111.         "enabled": false,
  112.         "protocols": null,
  113.         "cert": null,
  114.         "cert_key": null,
  115.         "ciphers": null,
  116.         "ciphersuites": null,
  117.         "dhparam": null
  118.     },
  119.     "dns": {
  120.         "ipv6": false,
  121.         "ttl": 30
  122.     },
  123.     "user-agent": null,
  124.     "verbose": 0,
  125.     "watch": true,
  126.     "rebench-algo": false,
  127.     "bench-algo-time": 20,
  128.     "algo-min-time": 0,
  129.     "algo-perf": {
  130.         "cn/0": 66.65614478114477,
  131.         "cn/1": 37.40281571758773,
  132.         "cn/2": 37.40281571758773,
  133.         "cn/r": 37.40281571758773,
  134.         "cn/fast": 74.80563143517546,
  135.         "cn/half": 74.80563143517546,
  136.         "cn/xao": 37.40281571758773,
  137.         "cn/rto": 37.40281571758773,
  138.         "cn/rwz": 49.87042095678363,
  139.         "cn/zls": 49.87042095678363,
  140.         "cn/double": 18.701407858793864,
  141.         "cn/ccx": 133.31228956228955,
  142.         "cn-lite/0": 151.00882723833544,
  143.         "cn-lite/1": 151.00882723833544,
  144.         "cn-heavy/xhv": 52.072375341889334,
  145.         "cn-pico": 1396.842105263158,
  146.         "cn-pico/tlo": 1396.842105263158,
  147.         "cn/gpu": 14.73063973063973,
  148.         "rx/0": 109.0182047774387,
  149.         "rx/arq": 456.74594822142706,
  150.         "rx/xeq": 456.74594822142706,
  151.         "rx/graft": 106.18817091138708,
  152.         "rx/sfx": 109.0182047774387,
  153.         "panthera": 712.3013785120488,
  154.         "argon2/chukwav2": 1057.678139143248,
  155.         "kawpow": -1.0,
  156.         "ghostrider": 93.36557670066239,
  157.         "flex": 100.65208245687842
  158.     },
  159.     "pause-on-battery": false,
  160.     "pause-on-active": false
  161. }
发表于 2025-5-27 10:52:27 | 只看该作者
是不是没有把 qemu-guest-agent 停掉
 楼主| 发表于 2025-5-27 10:52:47 | 只看该作者
目前先把这俩服务禁用了,保留现场瞅瞅
发表于 2025-5-27 10:57:48 | 只看该作者
我的开不了机了。。。
 楼主| 发表于 2025-5-27 10:59:50 | 只看该作者
的确是启动的。我来停掉卸载了这个服务。 等这阵风头过去了,重装一下系统。
发表于 2025-5-27 10:59:52 | 只看该作者
我的DD过系统 应该不会被挂马吧
 楼主| 发表于 2025-5-27 11:03:02 | 只看该作者
估计你们的机器也有这些病毒挖矿任务
还有一个  /usr/lib/systemd/system/quotaoff.service  可能是毒? 已经停了卸载了。
发表于 2025-5-27 11:13:06 | 只看该作者
QQ云 发表于 2025-5-27 10:57
我的开不了机了。。。
我的也无法开机了
然后回复是
  1. 感谢您在我们全面调查此事期间的耐心等待。感谢您的理解。
  2. 正如我们之前的电子邮件中所述,一个事件影响了 ColoCloud 平台。该问题目前已得到完全缓解;但是,您的 VPS 所在的一小部分服务器因该事件而遭受了数据丢失。
  3. 我们已经重新创建了您的 VPS,并已将新的访问详情发送给您。请尽快查看。
  4. ColoCloud 团队正在努力确保所有客户都能完全恢复,我们真诚感谢您给予我们为您服务的机会。如果您有任何疑问或需要进一步的帮助,请随时联系我们。我们随时准备为您提供帮助。
  5. Shane W,
  6. Chicagovps.net
果然是一键重建。。。。  发表于 2025-5-27 11:32
GMT+8, 2026-4-20 09:39 , Processed in 0.069357 second(s), 14 queries , Gzip On, MemCache On.
