查看: 1135|回复: 7
[美国VPS] HH 斯德哥尔摩250G强制迁移?
发表于 2025-5-3 23:47:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Dear Customer,
We would like to invite you to move your Storage VM with the IP address [176.126.84.74] to our new RAID-10 based plans.
The new plans come with much better performance and redundancy, along with a 20GB NVMe disk for the OS, as most modern operating systems do not perform great on spinning disks.
Due to the size of Storage VMs, an automated migration is not possible. However we can offer you the following options:
We will create for you a new VM with identical specifications and a new IP address. Both your old/current and new VMs will remain online for 14 days. We will shut down the old VM after this, or earlier if you inform us that you have moved over the data. At this time, we can move over your old IP address to the new VM, if that is needed.
We can remove your current VM, and create a new one with identical specifications with the same IP address. In this case you will need to restore the data from your own backups.
Please let us know how you wish to proceed as soon as possible. We look forward to providing you a much improved upgrade at no additional cost.
Best Regards,
Ivan T
HostHatch Support
刚付完款就整这出,套餐不可能换,不该套餐的话我都没找你们停机的问题呢
发表于 2025-5-4 03:02:22 来自手机 | 只看该作者
这是邀请,不是强制,你可以回邮件拒绝更改迁移到新的VM 虚拟机
发表于 2025-5-4 03:13:01 | 只看该作者
这款是512mb内存,年17刀款?
 楼主| 发表于 2025-5-4 05:03:41 | 只看该作者
已经改了,本来不想换IP的,和他说了,但是也换了,送了20G的NVMe,就是手动分盘和装系统费劲
 楼主| 发表于 2025-5-4 13:46:18 | 只看该作者
自然卷的气质 发表于 2025-5-4 03:13
这款是512mb内存,年17刀款?
15刀的年付斯德哥尔摩
发表于 2025-5-4 14:53:03 | 只看该作者
hosthatch的这种纯粹是免费升级还好吧。
发表于 2025-5-4 15:00:32 | 只看该作者
yuhao2348632 发表于 2025-5-4 13:46
15刀的年付斯德哥尔摩
不想麻烦,你出给我来玩?
发表于 2025-5-4 16:24:52 | 只看该作者
15刀的年付斯德哥尔摩
我的就是这款,用了五年,节前还是扔了!
176.126.XX.XXX
GMT+8, 2026-5-1 14:51 , Processed in 0.059781 second(s), 11 queries , Gzip On, MemCache On.
