查看: 1053|回复: 3
【已出ksleb】cpu中奖v6/有核显/v4v6rev g口/4t hdd硬盘/德国....
发表于 2025-4-30 13:09:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
当下载盘绝了。代数高cpu跑分也高,ddr4内存。
同等的nvme 450x2的ks-le-b,要价最低500难收,最高1500的都有,,这个没有nvme,明盘只要320,pm
#              Yet-Another-Bench-Script              #
#                     v2025-04-20                    #
# https://github.com/masonr/yet-another-bench-script #
Wed Apr 30 04:50:33 UTC 2025
Basic System Information:
Uptime     : 0 days, 0 hours, 2 minutes
Processor  : Intel(R) Xeon(R) CPU E3-1245 v6 @ 3.70GHz
CPU cores  : 8 @ 900.278 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 31.0 GiB
Swap       : 512.0 MiB
Disk       : 1.8 TiB
Distro     : Debian GNU/Linux 11 (bullseye)
Kernel     : 5.10.0-34-amd64
VM Type    : NONE
IPv4/IPv6  : ✔ Online / ✔ Online
IPv6 Network Information:
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH GmbH
Country    : Germany
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3):
Read       | 1859.00 KB/s    (214) | 31.56 MB/s     (180)
Write      | 1899.00 KB/s    (224) | 28.09 MB/s     (188)
Total      | 3.75 MB/s      (438) | 59.65 MB/s     (368)
Read       | 38.10 MB/s      (74) | 51.26 MB/s      (50)
Write      | 40.29 MB/s      (78) | 54.77 MB/s      (53)
Total      | 78.39 MB/s     (152) | 106.04 MB/s    (103)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 296 Mbits/sec   | 712 Mbits/sec   | 15.7 ms
Eranium         | Amsterdam, NL (100G)      | 296 Mbits/sec   | 938 Mbits/sec   | 11.1 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | 880 Mbits/sec   | 94.5 ms
Leaseweb        | Singapore, SG (10G)       | 225 Mbits/sec   | 693 Mbits/sec   | 166 ms
Clouvider       | Los Angeles, CA, US (10G) | 252 Mbits/sec   | 847 Mbits/sec   | 148 ms
Leaseweb        | NYC, NY, US (10G)         | 257 Mbits/sec   | 820 Mbits/sec   | 82.6 ms
Edgoo           | Sao Paulo, BR (1G)        | 221 Mbits/sec   | 753 Mbits/sec   | 194 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 292 Mbits/sec   | 898 Mbits/sec   | 13.5 ms
Eranium         | Amsterdam, NL (100G)      | 292 Mbits/sec   | 925 Mbits/sec   | 11.3 ms
Uztelecom       | Tashkent, UZ (10G)        | 277 Mbits/sec   | 850 Mbits/sec   | 95.7 ms
Leaseweb        | Singapore, SG (10G)       | 237 Mbits/sec   | 683 Mbits/sec   | 166 ms
Clouvider       | Los Angeles, CA, US (10G) | 250 Mbits/sec   | 828 Mbits/sec   | 148 ms
Leaseweb        | NYC, NY, US (10G)         | 267 Mbits/sec   | 825 Mbits/sec   | 82.8 ms
Edgoo           | Sao Paulo, BR (1G)        | 243 Mbits/sec   | 771 Mbits/sec   | 194 ms
Running GB6 benchmark test... *cue elevator music*
Geekbench 6 Benchmark Test:
Test            | Value
Single Core     | 1549
Multi Core      | 5228
Full Test       | https://browser.geekbench.com/v6/cpu/11749104
YABS completed in 14 min 41 sec
 楼主| 发表于 2025-4-30 15:20:00 | 只看该作者
此帖仅作者可见
发表于 2025-4-30 15:53:59 | 只看该作者
此帖仅作者可见
发表于 2025-4-30 22:55:57 来自手机 | 只看该作者
此帖仅作者可见
GMT+8, 2026-4-16 02:39 , Processed in 0.070645 second(s), 9 queries , Gzip On, MemCache On.
