查看: 1127|回复: 2
是不是有些机房IP的小鸡会被限制无法访问某些网站呢?
发表于 2025-4-18 16:53:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近发现自己的ruvds小鸡无法访问有图比和x。Google搜索是正常的
ping网站都是通着的,问了半天ai也没排查出来原因。不知道怎么回事要怎么解决,恳求大佬帮忙
  1. root@debian:~# wget x.com
  2. --2025-04-18 16:46:20--  http://x.com/
  3. Resolving x.com (x.com)... 162.159.140.229
  4. Connecting to x.com (x.com)|162.159.140.229|:80... connected.
  5. HTTP request sent, awaiting response... 301 Moved Permanently
  6. Location: https://x.com/ [following]
  7. --2025-04-18 16:46:20--  https://x.com/
  8. Connecting to x.com (x.com)|162.159.140.229|:443... connected.
  1. root@debian:~# curl -v https://有图比.com
  2. * Rebuilt URL to: https://有图比.com/
  3. *   Trying 64.233.162.91...
  4. * TCP_NODELAY set
  5. * Connected to 有图比.com (64.233.162.91) port 443 (#0)
  6. * ALPN, offering h2
  7. * ALPN, offering http/1.1
  8. * Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPOR***56:!aNULL:!LOW:!RC4:@STRENGTH
  9. * successfully set certificate verify locations:
  10. *   CAfile: /etc/ssl/certs/ca-certificates.crt
  11.   CApath: /etc/ssl/certs
  12. * TLSv1.2 (OUT), TLS header, Certificate Status (22):
  13. * TLSv1.2 (OUT), TLS handshake, Client hello (1):
百度了一下ip的运营商:
JSC Mediasoft ekspert
发表于 2025-4-18 17:29:07 | 只看该作者
有没有可能是俄罗斯访问不了这两个网站
 楼主| 发表于 2025-4-19 15:26:59 | 只看该作者
edgeNAT 发表于 2025-4-18 17:29
有没有可能是俄罗斯访问不了这两个网站
确实被屏蔽了,而且屏蔽了不少网站,又用了台小鸡做中转用了。
奇怪的是同样是俄罗斯的gcore就没问题
GMT+8, 2026-4-17 00:36 , Processed in 0.069802 second(s), 9 queries , Gzip On, MemCache On.
