查看: 979|回复: 1
亏本出 hosthatch NVMe 24 GB - T1 - A14 美国洛杉矶 (已出)
发表于 2025-4-14 19:23:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
配置: (已出完)
付款时间以及周期:下次付款将于2027 年 4 月 10 日到期,总额为200.00 美元。经过测试不太适合现在的项目跑,因此亏本出。
命盘:1200  改邮箱或者push出 (PUSH不包含PUSH费用)
yabs报告
  3. #                     v2025-01-01                    #
  6. Mon Apr 14 11:10:11 UTC 2025
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 17 minutes
  10. Processor  : AMD EPYC 7763 64-Core Processor
  11. CPU cores  : 6 [url=home.php?mod=space&uid=175]@[/url] 2450.000 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.3 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 366.6 GiB
  17. Distro     : Debian GNU/Linux 12 (bookworm)
  18. Kernel     : 6.1.0-21-amd64
  19. VM Type    : KVM
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : HostHatch
  24. ASN        : AS63473 HostHatch, LLC
  25. Host       : HostHatch LLC
  26. Location   : Los Angeles, California (CA)
  27. Country    : United States
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  32. Read       | 256.06 MB/s  (64.0k) | 2.69 GB/s    (42.0k)
  33. Write      | 256.74 MB/s  (64.1k) | 2.70 GB/s    (42.2k)
  34. Total      | 512.81 MB/s (128.2k) | 5.39 GB/s    (84.3k)
  38. Read       | 3.36 GB/s     (6.5k) | 3.50 GB/s     (3.4k)
  39. Write      | 3.53 GB/s     (6.9k) | 3.73 GB/s     (3.6k)
  40. Total      | 6.89 GB/s    (13.4k) | 7.24 GB/s     (7.0k)
  45. Clouvider       | London, UK (10G)          | 1.28 Gbits/sec  | 1.30 Gbits/sec  | --
  46. Eranium         | Amsterdam, NL (100G)      | 1.34 Gbits/sec  | 1.21 Gbits/sec  | --
  47. Uztelecom       | Tashkent, UZ (10G)        | 814 Mbits/sec   | 480 Mbits/sec   | --
  48. Leaseweb        | Singapore, SG (10G)       | 884 Mbits/sec   | 983 Mbits/sec   | --
  49. Clouvider       | Los Angeles, CA, US (10G) | 7.91 Gbits/sec  | 7.31 Gbits/sec  | --
  50. Leaseweb        | NYC, NY, US (10G)         | 3.02 Gbits/sec  | 2.96 Gbits/sec  | --
  51. Edgoo           | Sao Paulo, BR (1G)        | 1.12 Gbits/sec  | 1.05 Gbits/sec  | --
  52. Geekbench 6 Benchmark Test:
  53. ---------------------------------
  54. Test            | Value
  55.                 |
  56. Single Core     | 1527
  57. Multi Core      | 6483
  58. Full Test       | https://browser.geekbench.com/v6/cpu/11510902
  59. YABS completed in 10 min 31 sec
 楼主| 发表于 2025-4-14 19:24:05 | 只看该作者
IP质量报告
  1. ########################################################################
  2.                        IP质量体检报告:31.220.*.*
  3.                     bash <(curl -sL IP.Check.Place)
  4.                    https://github.com/xykt/IPQuality
  5.         报告时间:2025-04-14 19:10:34 CST  脚本版本:v2025-03-25
  6. ########################################################################
  7. 一、基础信息(Maxmind 数据库)
  8. 自治系统号:            AS63473
  9. 组织:                  HOSTHATCH
  10. 坐标:                  118°14′38″W, 34°3′16″N
  11. 地图:                  https://check.place/34.0544,-118.244,15,cn
  12. 城市:                  加州, 洛杉矶, 90060
  13. 使用地:                [US]美国, [NA]北美洲
  14. 注册地:                [DE]德国
  15. 时区:                  America/Los_Angeles
  16. IP类型:                 广播IP
  17. 二、IP类型属性
  18. 数据库:      IPinfo    ipregistry    ipapi     AbuseIPDB  IP2LOCATION
  19. 使用类型:     机房        机房        机房        机房        机房
  20. 公司类型:     机房        机房        机房
  21. 三、风险评分
  22. 风险等级:      极低         低       中等       高         极高
  23. SCAMALYTICS:                                   59|高风险
  24. ipapi:    0.00%|极低风险
  25. AbuseIPDB:    0|低风险
  26. IPQS:                        75|可疑IP
  27. Cloudflare:   0|低风险
  28. DB-IP:         |低风险
  29. 四、风险因子
  30. 库: IP2LOCATION ipapi ipregistry IPQS SCAMALYTICS ipdata IPinfo IPWHOIS
  31. 地区:    [US]    [US]    [US]    [US]    [US]    [US]    [US]    [US]
  32. 代理:     否      否      否      是      否      否      否      否
  33. Tor:      否      否      否      否      否      否      否      否
  34. 扶墙:      否      是      否      是      否      无      是      否
  35. 服务器:   是      是      是      无      否      否      是      是
  36. 滥用:     否      否      否      否      无      否      无      无
  37. 机器人:   否      否      无      否      否      无      无      无
  38. 五、流媒体及AI服务解锁检测
  39. 服务商:  TikTok   Disney+  Netflix 有图比  AmazonPV  Spotify  ChatGPT
  40. 状态:     解锁     屏蔽     解锁     解锁     解锁     屏蔽     解锁
  41. 地区:     [US]              [US]     [US]     [US]              [US]
  42. 方式:     原生              原生     原生     原生              原生
  43. 六、邮局连通性及黑名单检测
  44. 本地25端口:阻断
  45. IP地址黑名单数据库:  有效 439   正常 424   已标记 15   黑名单 0
  46. ========================================================================
  47. 今日IP检测量:1123;总检测量:182067。感谢使用xy系列脚本!
  48. 报告链接:https://Report.Check.Place/IP/1KQ83SZ3M.svg
GMT+8, 2026-5-2 06:58 , Processed in 0.066648 second(s), 9 queries , Gzip On, MemCache On.
