查看: 728|回复: 2
joplin笔记软件不兼容搜狗拼音,打出来的字会消失
发表于 2025-4-3 14:23:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在joplin用搜狗拼音打字,打完字切换到其他笔记,再切回来,句子后面会有几个字消失了,这是多么灾难性的事情。
这是我在b站发的视频,演示这个bug
https://www.bilibili.com/video/BV1WtZ2YWEhV/?vd_source=915292db556bc06d012edbe33452df41
同时我也在joplin反馈
https://discourse.joplinapp.org/t/text-loss-issue-in-joplin-notes/44694/9
以下是我在那边论坛发的内容:
I use the Sogou Pinyin input method to enter a piece of text without adding punctuation at the end. Regardless of whether it is full-width or half-width punctuation or numbers, switching to another note and switching back will cause the previously entered content to disappear.
我用搜狗拼音输入法,输入完一段文字,没在后面加标点符号,不论是全角还是半角标点,或者数字,切换到其他笔记再切换回来,刚才输入的内容就会消失
1.Sogou Pinyin Input Method: Chinese + Full-width Punctuation. No problem.
搜狗拼音输入法:中文+全角标点。没问题
text:中文后面跟着全角标点句号。
2.Sogou Pinyin Input Method: Chinese + Half-width Punctuation. No problem.
搜狗拼音输入法:中文+半角标点。没问题
text:中文后面跟着半角标点句号.
3.Sogou Pinyin Input Method: Chinese + Numbers. No problem.
搜狗拼音输入法:中文+数字。没问题
text:中文后面跟着数字2
4.Windows EN-US Input Method: Entering English, No problem.
windows的EN-US输入法:输入英文,没问题。
text:english mode
5.Sogou Pinyin Input Method: English, entered in Sogou Pinyin's English mode. No problem.
搜狗拼音输入法:英文,以搜狗拼音的英文模式输入。没问题
text:sougou pinyin
6.Sogou Pinyin Input Method: Chinese. Switching to another note and switching back will cause the text to disappear.
搜狗拼音输入法:中文。切换到其他笔记再切换回来,文字会消失(画横线是消失的部分)
text:搜狗拼音打中文后面不加标点符号和数字
7.Sogou Pinyin Input Method: English, entered in Sogou Pinyin's Chinese mode by pressing Enter or Shift. Switching to another note and switching back will cause the text to disappear.
搜狗拼音输入法:英文,以搜狗拼音的中文模式输入,按enter或者shift输入英文。切换到其他笔记再切换回来,文字会消失(画横线是消失的部分)。
text:hello
So, it is an incompatibility issue between Joplin and the Sogou Pinyin input method that causes text loss when switching notes. So far, I have only found this issue in Joplin; other software like Word, Evernote, and Notepad.exe does not have this problem.
所以,是joplin不兼容搜狗拼音输入法导致切换笔记导致文字消失的问题。目前我只发现joplin有这样的问题,其他软件word,Evernote,notepad.exe等等都没有这样的问题。
发表于 2025-4-3 14:32:38 | 只看该作者
有没有可能是搜狗不兼容joplin,试过其他输入法吗?
发表于 2025-4-3 14:31:05 | 只看该作者
我去,这么不作为。我也在用joplin
GMT+8, 2026-4-25 13:55 , Processed in 0.058578 second(s), 11 queries , Gzip On, MemCache On.
