查看: 1406|回复: 8
溢价100收claw 4刀 香港
发表于 2025-3-11 12:49:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ip段不限
要求yabs测试硬盘io 1m-block读写分别大于150MB/s
  1. curl -sL yabs.sh | bash -s -- -ig
发表于 2025-3-11 12:52:48 | 只看该作者
可惜有push费用
发表于 2025-3-11 12:58:10 | 只看该作者
两台都没达到楼主要求
1号
  3. #                     v2025-01-01                    #
  6. Tue Mar 11 04:54:15 AM UTC 2025
  7. Basic System Information:
  9. Uptime     : 2 days, 15 hours, 30 minutes
  10. Processor  : Intel(R) Xeon(R) Platinum
  11. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 2499.998 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ❌ Disabled
  14. RAM        : 1.8 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 39.7 GiB
  17. Distro     : Arch Linux
  18. Kernel     : 6.12.18-1-lts
  19. VM Type    : KVM
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : Alibaba (US) Technology Co., Ltd.
  24. ASN        : AS45102 Alibaba (US) Technology Co., Ltd.
  25. Host       : Alibaba.com LLC
  26. Location   : Hong Kong, Kowloon ()
  27. Country    : Hong Kong
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
  32. Read       | 20.65 MB/s    (5.1k) | 64.59 MB/s    (1.0k)
  33. Write      | 20.67 MB/s    (5.1k) | 64.99 MB/s    (1.0k)
  34. Total      | 41.32 MB/s   (10.3k) | 129.59 MB/s   (2.0k)
  38. Read       | 61.35 MB/s     (119) | 60.68 MB/s      (59)
  39. Write      | 64.55 MB/s     (126) | 64.95 MB/s      (63)
  40. Total      | 125.90 MB/s    (245) | 125.64 MB/s    (122)
2号
  3. #                     v2025-01-01                    #
  6. Tue Mar 11 04:54:28 AM UTC 2025
  9. Uptime     : 2 days, 15 hours, 29 minutes
  11. CPU cores  : 2 @ 2499.998 MHz
  14. RAM        : 1.8 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 39.7 GiB
  19. VM Type    : KVM
  32. Read       | 20.65 MB/s    (5.1k) | 64.67 MB/s    (1.0k)
  33. Write      | 20.67 MB/s    (5.1k) | 65.07 MB/s    (1.0k)
  34. Total      | 41.32 MB/s   (10.3k) | 129.74 MB/s   (2.0k)
  38. Read       | 61.83 MB/s     (120) | 60.84 MB/s      (59)
  39. Write      | 65.02 MB/s     (127) | 65.18 MB/s      (63)
  40. Total      | 126.86 MB/s    (247) | 126.02 MB/s    (122)
 楼主| 发表于 2025-3-11 15:28:22 | 只看该作者
Push费我另外出
发表于 2025-3-12 11:53:33 | 只看该作者
#                     v2025-01-01                    #
Wed Mar 12 03:52:10 UTC 2025
Uptime     : 10 days, 16 hours, 47 minutes
Processor  : Intel(R) Xeon(R) Platinum 8163 CPU @ 2.50GHz
CPU cores  : 2 @ 2500.008 MHz
AES-NI     : ✔ Enabled
RAM        : 1.9 GiB
Swap       : 0.0 KiB
Disk       : 39.3 GiB
Distro     : Debian GNU/Linux 12 (bookworm)
Kernel     : 6.1.0-31-cloud-amd64
VM Type    : KVM
IPv4/IPv6  : ✔ Online / ❌ Offline
IPv4 Network Information:
ISP        : Alibaba Cloud LLC
Host       : Alibaba Cloud - JP
Country    : Japan
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
Read       | 83.02 MB/s   (20.7k) | 364.52 MB/s   (5.6k)
Write      | 83.24 MB/s   (20.8k) | 366.44 MB/s   (5.7k)
Total      | 166.27 MB/s  (41.5k) | 730.96 MB/s  (11.4k)
Read       | 346.60 MB/s    (676) | 333.04 MB/s    (325)
Write      | 365.01 MB/s    (712) | 355.22 MB/s    (346)
Total      | 711.62 MB/s   (1.3k) | 688.26 MB/s    (671)
需要吗楼主
发表于 2025-3-12 12:12:52 来自手机 | 只看该作者
红桃老幺 发表于 2025-3-12 11:53
#              Yet-Another-Bench-Script       ...
你这个牛逼
 楼主| 发表于 2025-3-12 17:18:01 | 只看该作者
好鸡,可惜是日本
发表于 2025-3-12 17:38:49 | 只看该作者
这个怎么样,是月付8刀款的。
 楼主| 发表于 2025-3-12 18:16:19 | 只看该作者
pearce 发表于 2025-3-12 17:38
这个怎么样,是月付8刀款的。
8刀款io性能都不错的
GMT+8, 2026-4-18 22:56 , Processed in 0.062781 second(s), 10 queries , Gzip On, MemCache On.
