查看: 867|回复: 2
【已出】push出个OVH帐户IE区。Gra地区KS-LE-1。硬盘内存V6中...
发表于 2025-2-19 15:12:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Subscription date
16 December 2024
Next payment date
16 March 2025
续费:9.99欧元的
# SSD 中奖。960G * 2
# 内存中奖。 32G
# V6 中奖
地区:
Region:Europe (France – Gravelines)
eu-west-gra
Zone:eu-west-gra-a
# 硬盘通电时间及写入量:
  1. Hard Disk Sentinel for LINUX console 0.19c.9986 (c) 2021 info@hdsentinel.com
  2. Start with -r [reportfile] to save data to report, -h for help
  3. Examining hard disk configuration ...
  4. HDD Device  0: /dev/sda
  5. HDD Model ID : INTEL SSDSC2KB960G8
  6. HDD Serial No: BTYF91650818960CGN
  7. HDD Revision : XCV10132
  8. HDD Size     : 915715 MB
  9. Interface    : S-ATA Gen3, 6 Gbps
  10. Temperature  : 28 °C
  11. Highest Temp.: 28 °C
  12. Health       : 98 %
  13. Performance  : 100 %
  14. Power on time: 1844 days, 3 hours
  15. Est. lifetime: more than 98 days
  16. Total written: 151.45 TB
  17.   The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
  18.   The health is determined by SSD specific S.M.A.R.T. attribute(s):  #233 Media Wearout Indicator
  19.     No actions needed.
  20. HDD Device  1: /dev/sdb
  21. HDD Model ID : INTEL SSDSC2KB960G8
  22. HDD Serial No: PHYF0084003C960CGN
  23. HDD Revision : XCV10132
  24. HDD Size     : 915715 MB
  25. Interface    : S-ATA Gen3, 6 Gbps
  26. Temperature  : 31 °C
  27. Highest Temp.: 31 °C
  28. Health       : 99 %
  29. Performance  : 100 %
  30. Power on time: 1536 days, 17 hours
  31. Est. lifetime: more than 282 days
  32. Total written: 59.01 TB
  33.   The status of the solid state disk is PERFECT. Problematic or weak sectors were not found.
  34.   The health is determined by SSD specific S.M.A.R.T. attribute(s):  #233 Media Wearout Indicator
  35.     No actions needed.
  1.                    This is the choice of Steins;Gate
  2.   CPU 型号              Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  3.   CPU 核心              合计 4 核心,8 线程
  4.   CPU 状态              当前主频 2461.550 MHz
  5.   内存大小              32004 MB (750 MB 已用)
  6.   交换分区              1023 MB (0 MB 已用)
  7.   第 1 块硬盘           通电 44259 小时,型号 INTEL SSDSC2KB960G8
  8.   第 2 块硬盘           通电 36881 小时,型号 INTEL SSDSC2KB960G8
  9.   硬盘大小              879.0 GB
  10.   服务器时间            2025-02-19 06:49:17
  11.   运行时间              0 days 0 hour 11 min
  12.   系统负载              0.20, 0.07, 0.02
  13.   虚拟化技术            No Virtualization Detected
  14.   IPv4 地址             37.187.xxx.xxx
  15.   IPv6 地址             2001:41d0:xxxx:xxxx
  16.   运营商                AS16276 OVH SAS
  17.   地理位置              FR, Hauts-de-France, Calais
  18.   操作系统              Ubuntu 24.10 oracular (x86_64)
  19.   系统内核              6.11.0-14-generic
  20.   TCP 加速              cubic
  21.   当前脚本版本          1.4.1.1
  22.    ATTENTION  检测到你服务器里有固态硬盘,建议使用 fio 代替 dd 进行测试
  23.               bash <(wget -qO- git.io/ceshi) -j
  24.   顺序写入 (1st)        427 MB/s
  25.   顺序写入 (2nd)        425 MB/s
  26.   顺序写入 (3rd)        426 MB/s
  27.   顺序写入 (4th)        426 MB/s
  28.   顺序写入 (5th)        425 MB/s
  29.   顺序写入 (avg)        425.7 MB/s
# 网络测速:
  3. #                     v2025-01-01                    #
  6. Wed Feb 19 06:50:00 UTC 2025
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 12 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  11. CPU cores  : 8 @ 2487.649 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.2 GiB
  15. Swap       : 1024.0 MiB
  16. Disk       : 878.5 GiB
  17. Distro     : Ubuntu 24.10
  18. Kernel     : 6.11.0-14-generic
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ✔ Online
  21. IPv6 Network Information:
  23. ISP        : OVH SAS
  24. ASN        : AS16276 OVH SAS
  25. Host       : OVH SAS
  26. Location   : Roubaix, Hauts-de-France (HDF)
  27. Country    : France
  28. iperf3 Network Speed Tests (IPv4):
  30. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  31. -----           | -----                     | ----            | ----            | ----
  32. Clouvider       | London, UK (10G)          | 287 Mbits/sec   | 939 Mbits/sec   | 3.82 ms
  33. Eranium         | Amsterdam, NL (100G)      | 285 Mbits/sec   | 938 Mbits/sec   | 9.58 ms
  34. Uztelecom       | Tashkent, UZ (10G)        | 228 Mbits/sec   | 572 Mbits/sec   | 105 ms
  35. Leaseweb        | Singapore, SG (10G)       | 89.8 Mbits/sec  | 520 Mbits/sec   | --
  36. Clouvider       | Los Angeles, CA, US (10G) | 164 Mbits/sec   | 466 Mbits/sec   | 133 ms
  37. Leaseweb        | NYC, NY, US (10G)         | 214 Mbits/sec   | 677 Mbits/sec   | 74.9 ms
  38. Edgoo           | Sao Paulo, BR (1G)        | 142 Mbits/sec   | 343 Mbits/sec   | 194 ms
  39. iperf3 Network Speed Tests (IPv6):
  40. ---------------------------------
  41. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  42. -----           | -----                     | ----            | ----            | ----
  43. Clouvider       | London, UK (10G)          | 917 Mbits/sec   | 911 Mbits/sec   | 3.81 ms
  44. Eranium         | Amsterdam, NL (100G)      | 830 Mbits/sec   | 924 Mbits/sec   | 9.47 ms
  45. Uztelecom       | Tashkent, UZ (10G)        | 646 Mbits/sec   | 307 Mbits/sec   | 105 ms
  46. Leaseweb        | Singapore, SG (10G)       | 596 Mbits/sec   | 523 Mbits/sec   | 165 ms
  47. Clouvider       | Los Angeles, CA, US (10G) | 732 Mbits/sec   | 176 Mbits/sec   | 133 ms
  48. Leaseweb        | NYC, NY, US (10G)         | 703 Mbits/sec   | busy            | 75.1 ms
  49. Edgoo           | Sao Paulo, BR (1G)        | 568 Mbits/sec   | 568 Mbits/sec   | 194 ms
  50. YABS completed in 5 min 50 sec
发表于 2025-2-19 17:53:13 | 只看该作者
怎么快就出了
GMT+8, 2026-4-22 07:18 , Processed in 0.058060 second(s), 9 queries , Gzip On, MemCache On.
