查看: 1441|回复: 6
[不限流量] 【已出】出个OVH KS-GAME-LE 特价中奖机
发表于 2025-2-15 16:11:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出个KS-GAME-LE  IE区账号push 法国GRA1机房
i7-4790K  32G  240G SSD   ipV4上下G口中奖  续费11.99欧
详细测试看下图 明盘 300出 自备IE区账号   左侧QQ 或 私信联系
debian@ns3036135:~$ wget -qO- yabs.sh | bash
#              Yet-Another-Bench-Script              #
#                     v2025-01-01                    #
# https://github.com/masonr/yet-another-bench-script #
Sat Feb 15 08:51:35 UTC 2025
Basic System Information:
Uptime     : 0 days, 2 hours, 11 minutes
Processor  : Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
CPU cores  : 8 @ 2792.960 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 31.2 GiB
Swap       : 512.0 MiB
Disk       : 218.5 GiB
Distro     : Debian GNU/Linux 12 (bookworm)
Kernel     : 6.1.0-31-amd64
VM Type    : NONE
IPv4/IPv6  : ✔ Online / ✔ Online
IPv6 Network Information:
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH
Country    : France
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3):
Read       | 126.99 MB/s  (31.7k) | 152.03 MB/s   (2.3k)
Write      | 127.32 MB/s  (31.8k) | 152.83 MB/s   (2.3k)
Total      | 254.32 MB/s  (63.5k) | 304.86 MB/s   (4.7k)
Read       | 168.80 MB/s    (329) | 168.63 MB/s    (164)
Write      | 177.77 MB/s    (347) | 179.87 MB/s    (175)
Total      | 346.57 MB/s    (676) | 348.50 MB/s    (339)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 931 Mbits/sec   | 940 Mbits/sec   | 3.78 ms
Eranium         | Amsterdam, NL (100G)      | 930 Mbits/sec   | 934 Mbits/sec   | 9.58 ms
Uztelecom       | Tashkent, UZ (10G)        | 758 Mbits/sec   | 429 Mbits/sec   | 105 ms
Leaseweb        | Singapore, SG (10G)       | 611 Mbits/sec   | 649 Mbits/sec   | 166 ms
Clouvider       | Los Angeles, CA, US (10G) | 108 Mbits/sec   | 314 Mbits/sec   | 135 ms
Leaseweb        | NYC, NY, US (10G)         | 822 Mbits/sec   | 673 Mbits/sec   | 77.7 ms
Edgoo           | Sao Paulo, BR (1G)        | 762 Mbits/sec   | 316 Mbits/sec   | 184 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 919 Mbits/sec   | 927 Mbits/sec   | 3.83 ms
Eranium         | Amsterdam, NL (100G)      | 917 Mbits/sec   | 924 Mbits/sec   | 9.55 ms
Uztelecom       | Tashkent, UZ (10G)        | 806 Mbits/sec   | busy            | 105 ms
Leaseweb        | Singapore, SG (10G)       | 177 Mbits/sec   | 520 Mbits/sec   | 166 ms
Clouvider       | Los Angeles, CA, US (10G) | 528 Mbits/sec   | 216 Mbits/sec   | 135 ms
Leaseweb        | NYC, NY, US (10G)         | 751 Mbits/sec   | 647 Mbits/sec   | 77.6 ms
Edgoo           | Sao Paulo, BR (1G)        | 737 Mbits/sec   | 268 Mbits/sec   | 184 ms
Geekbench 6 Benchmark Test:
Test            | Value
Single Core     | 1512
Multi Core      | 4885
Full Test       | https://browser.geekbench.com/v6/cpu/10550645
发表于 2025-2-15 16:15:07 | 只看该作者
得使用
  1. curl -sL yabs.sh | bash
这个脚本进行测试,对ipv4和ipv6分别测试,才知道是不是ipv4和ipv6都是上行1G
 楼主| 发表于 2025-2-15 16:46:30 | 只看该作者
yhsiao 发表于 2025-2-15 16:15
得使用这个脚本进行测试,对ipv4和ipv6分别测试,才知道是不是ipv4和ipv6都是上行1G ...
已更新
发表于 2025-2-15 17:05:58 来自手机 | 只看该作者
是v4 上下g口吗
 楼主| 发表于 2025-2-15 17:07:28 | 只看该作者
我看好像是 V4 V6都是G口
 楼主| 发表于 2025-2-19 11:49:26 | 只看该作者
顶一下 有需要联系
GMT+8, 2026-5-1 13:39 , Processed in 0.066895 second(s), 10 queries , Gzip On, MemCache On.
