查看: 795|回复: 0
[疑问] 一个视频上传的奇怪问题
发表于 2025-2-11 12:37:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一个9:16的视频,A上传到sp.hydee.cn平台,所有用户看这个视频都发现,这个视频在预览和播放的时候被拉伸变形了。
A将这个视频发送到sp.hydee.cn的技术人员,技术人员上传到sp.hydee.cn的时候却都是正常的,技术人员说可能跟网速有关。
PS C:\Users\Telegramr> D:\ffmpeg\bin\ffmpeg.exe -i E:\a.mp4
ffmpeg version 2024-11-25-git-04ce01df0b-full_build-www.gyan.dev Copyright (c) 2000-2024 the FFmpeg developers
  built with gcc 14.2.0 (Rev1, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libaribcaption --enable-libdav1d --enable-libdavs2 --enable-libopenjpeg --enable-libquirc --enable-libuavs3d --enable-libxevd --enable-libzvbi --enable-libqrencode --enable-librav1e --enable-libsvtav1 --enable-libvvenc --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxeve --enable-libxvid --enable-libaom --enable-libjxl --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-dxva2 --enable-d3d11va --enable-d3d12va --enable-ffnvcodec --enable-libvpl --enable-nvdec --enable-nvenc --enable-vaapi --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libcodec2 --enable-libilbc --enable-libgsm --enable-liblc3 --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      59. 47.101 / 59. 47.101
  libavcodec     61. 25.103 / 61. 25.103
  libavformat    61.  9.100 / 61.  9.100
  libavdevice    61.  4.100 / 61.  4.100
  libavfilter    10.  6.101 / 10.  6.101
  libswscale      8. 12.100 /  8. 12.100
  libswresample   5.  4.100 /  5.  4.100
  libpostproc    58.  4.100 / 58.  4.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 000002213dca8380] Unknown cover type: 0x1.
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\a.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    creation_time   : 2022-09-30T21:54:22.000000Z
    Hw              : 1
    bitRate         : 6000000
    maxrate         : 6000000
    te_is_reencode  : 1
    encoder         : Lavf58.76.100
  Duration: 00:05:48.88, start: 0.000000, bitrate: 4626 kb/s
  Stream #0:0[0x1](und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709, progressive), 1080x1920 [SAR 1:1 DAR 9:16], 4478 kb/s, 25 fps, 25 tbr, 1000k tbn (default)
    Metadata:
      handler_name    : VideoHandler
      vendor_id       : [0][0][0][0]
  Stream #0:1[0x2](und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 145 kb/s (default)
    Metadata:
      handler_name    : SoundHandler
根据DeepSeek的方法进行了检测,得出以下几点
1、视频元素据没有问题
2、网站平台没有进行编码转换
3、video标签参数是object-fit: contain;  /* 保持比例,不拉伸 */
现在不知道问题出在哪里了,有这方面经验的大佬吗?指点一下,谢谢了。
GMT+8, 2026-4-19 08:43 , Processed in 0.060462 second(s), 10 queries , Gzip On, MemCache On.
