查看: 836|回复: 1
[美国VPS] 【融合怪】CLAW JP 年付7U
发表于 2025-1-12 21:49:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CPU 型号          : Intel(R) Xeon(R) Platinum
CPU 核心数        : 1
CPU 频率          : 2500.002 MHz
CPU 缓存          : L1: 32.00 KB / L2: 1.00 MB / L3: 33.00 MB
AES-NI指令集      : ✔ Enabled
VM-x/AMD-V支持    : ❌ Disabled
内存              : 196.98 MiB / 912.05 MiB
硬盘空间          : 1.79 GiB / 18.33 GiB
启动盘路径        : /dev/vda1
系统在线时间      : 0 days, 0 hour 15 min
系统              : Ubuntu 24.04.1 LTS (x86_64)
内核              : 6.8.0-51-generic
TCP加速方式       : cubic
虚拟化架构        : KVM
NAT类型           : Full Cone
IPV4 ASN          : AS45102 Alibaba (US) Technology Co., Ltd.
IPV4 位置         : Tokyo / Tokyo / JP
IPV6 ASN          : AS45102 Alibaba
IPV6 位置         : Tokyo / Tokyo / Japan
IPV6 子网掩码     : 128
1 线程测试(单核)得分:                 1047 Scores
单线程读测试:                5172.02 MB/s
单线程写测试:                5238.68 MB/s
100MB-4K Block                32.3 MB/s (7886 IOPS, 3.25s)                49.8 MB/s (12147 IOPS, 2.11s)
1GB-1M Block                232 MB/s (221 IOPS, 4.52s)                209 MB/s (199 IOPS, 5.01s)
Read       | 20.67 MB/s    (5.1k) | 96.31 MB/s    (1.5k)
Write      | 20.69 MB/s    (5.1k) | 96.82 MB/s    (1.5k)
Total      | 41.37 MB/s   (10.3k) | 193.14 MB/s   (3.0k)
Read       | 92.00 MB/s     (179) | 91.35 MB/s      (89)
Write      | 96.89 MB/s     (189) | 97.44 MB/s      (95)
Total      | 188.90 MB/s    (368) | 188.79 MB/s    (184)
以下为IPV4网络测试
Dazn:                                        Failed (Error: )
Disney+:                                No (IP Banned By Disney+ 1)
Netflix:                                Originals Only
有图比 Premium:                        Yes (Region: JP)
Amazon Prime Video:                        Yes (Region: JP)
Spotify Registration:                        No
OneTrust Region:                        JP [Tokyo]
iQyi Oversea Region:                        JP
Bing Region:                                JP (Risky)
有图比 CDN:                                Tokyo
Netflix Preferred CDN:                        Tokyo
Google Gemini:                                Yes (Region: JPN)
Wikipedia Editability:                        No
Google Play Store:                        Japan
Google Search CAPTCHA Free:                Yes
Steam Currency:                        JPY
---Forum---
Reddit:                                No
以下为IPV6网络测试
Dazn:                                        IPv6 Is Not Currently Supported
Disney+:                                IPv6 Is Not Currently Supported
Netflix:                                Yes (Region: SG)
Amazon Prime Video:                        IPv6 Is Not Currently Supported
TVBAnywhere+:                                IPv6 Is Not Currently Supported
iQyi Oversea Region:                        IPv6 Is Not Currently Supported
有图比 CDN:                                Tokyo
Netflix Preferred CDN:                        Osaka
ChatGPT:                                Failed (Network Connection)
Steam Currency:                        IPv6 Is Not Currently Supported
---Forum---
Reddit:                                IPv6 Is Not Currently Supported
-------------IP质量检测--基于oneclickvirt/securityCheck使用-------------
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
ipinfo数据库  [0] | scamalytics数据库 [1] | virustotal数据库   [2] | abuseipdb数据库   [3] | ip2location数据库    [4]
ip-api数据库  [5] | ipwhois数据库     [6] | ipregistry数据库   [7] | ipdata数据库      [8] | db-ip数据库          [9]
ipapiis数据库 [A] | ipapicom数据库    [B] | bigdatacloud数据库 [C] | cheervision数据库 [D] | ipqualityscore数据库 [E]
IPV4:
安全得分:
声誉(越高越好): 0 [2]
信任得分(越高越好): 0 [8]
扶墙得分(越低越好): 100 [8]
代理得分(越低越好): 100 [8]
社区投票-无害: 0 [2]
社区投票-恶意: 0 [2]
威胁得分(越低越好): 100 [8]
欺诈得分(越低越好): 93 [E] 13 [1]
滥用得分(越低越好): 0 [3]
ASN滥用得分(越低越好): 0.0011 (Low) [A]
公司滥用得分(越低越好): 0.0008 (Low) [A]
威胁级别: low [9 B]
黑名单记录统计有多少黑名单网站有记录):
无害记录数: 0 [2]  恶意记录数: 0 [2]  可疑记录数: 0 [2]  无记录数: 94 [2]
安全信息:
使用类型: hosting - high probability [C] DataCenter/WebHosting/Transit [3] hosting [0 7 9 A]
公司类型: hosting [0 7 A]
是否云提供商: Yes [7 D]
是否数据中心: No [8] Yes [0 1 5 6 A C]
是否移动设备: No [5 A C] Yes [E]
是否代理: Yes [E] No [0 1 4 5 6 7 8 9 A B C D]
是否扶墙: No [0 1 6 7 C D] Yes [A E]
是否Tor: No [0 1 3 6 7 8 A B C D E]
是否Tor出口: No [1 7 D]
是否网络爬虫: No [9 A B E]
是否匿名: No [1 6 7 8 D]
是否攻击者: No [7 8 D]
是否滥用者: No [7 8 A C D E]
是否威胁: No [7 8 C D]
是否中继: No [0 7 8 C D]
是否Bogon: No [7 8 A C D]
是否机器人: No [E]
DNS-黑名单: 314(Total_Check) 0(Clean) 3(Blacklisted) 17(Other)
IPV6:
安全得分:
欺诈得分(越低越好): 13 [1]
滥用得分(越低越好): 0 [3]
公司滥用得分(越低越好): 0 (Very Low) [A]
威胁级别: low [B]
安全信息:
使用类型: hosting [A] DataCenter/WebHosting/Transit [3]
公司类型: hosting [A]
是否云提供商: Yes [D]
是否数据中心: Yes [1 A]
是否移动设备: No [A]
是否代理: No [1 A B D]
是否扶墙: No [1 A D]
是否TorExit: No [1 D]
是否Tor出口: No [1 D]
是否网络爬虫: No [A B]
是否匿名: No [1 D]
是否攻击者: No [D]
是否滥用者: No [A D]
是否威胁: No [D]
是否中继: No [D]
是否Bogon: No [A D]
DNS-黑名单: 314(Total_Check) 0(Clean) 0(Blacklisted) 314(Other)
Google搜索可行性:YES
-------------邮件端口检测--基于oneclickvirt/portchecker开源-------------
Platform  SMTP  SMTPS POP3  POP3S IMAP  IMAPS
LocalPort ✔     ✔     ✔     ✔     ✔     ✔
北京电信 219.141.140.10  电信163    [普通线路]
北京移动 221.179.155.161 移动CMI    [普通线路]
上海电信 202.96.209.133  电信163    [普通线路]
上海移动 211.136.112.200 移动CMI    [普通线路]
广州电信 58.60.188.222   电信163    [普通线路]
成都电信 61.139.2.69     电信163    [普通线路]
准确线路自行查看详细路由,本测试结果仅作参考
广州电信 58.60.188.222
3.48 ms         * DOD
3.07 ms         * 日本 东京都 东京
3.59 ms         * [BBIXINTLNET] 日本 东京都 东京
56.41 ms         AS17676 [BBTEC] 中国 北京 softbank.jp
57.03 ms         AS4134 [CHINANET-BB] 中国 北京 www.chinatelecom.com.cn 电信
59.33 ms         AS4134 [CHINANET-BB] 中国 北京 www.chinatelecom.com.cn 电信
* ms         AS4134 中国 广东 深圳 福田区 www.chinatelecom.com.cn 电信
广州联通 210.21.196.6
广州移动 120.196.165.24
2.80 ms         * DOD
53.98 ms         * 日本 东京都 东京
2.88 ms         * [BBIXINTLNET] 日本 东京都 东京
3.55 ms         AS17676 [BBTEC] 日本 东京都 东京 softbank.jp
60.22 ms         AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com
116.05 ms         AS9808 [CMNET] 中国 广东 广州 I-C chinamobileltd.com 移动
162.76 ms         AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
63.76 ms         AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
68.41 ms         AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
67.31 ms         AS56040 [APNIC-AP] 中国 广东 深圳 gd.10086.cn 移动
Speedtest.net         194.61 Mbps         196.63 Mbps         2.44          0.0%
日本东京         194.61 Mbps         194.85 Mbps         3.55          0.0%
中国香港         40.98 Mbps         206.52 Mbps         51.79          0.0%
联通WuXi         46.61 Mbps         224.83 Mbps         252.21          0.4%
电信Suzhou5G         213.81 Mbps         17.70 Mbps         43.09          NULL
电信Zhenjiang5G         62.20 Mbps         30.10 Mbps         46.96          NULL
总共花费      : 8 分 30 秒
时间          : Sun Jan 12 13:44:51 UTC 2025
 楼主| 发表于 2025-1-12 21:51:27 | 只看该作者
电信 移动线路还可以,解锁不太好 据说国际线路,可以当出口机器拉全球
GMT+8, 2026-5-1 23:30 , Processed in 0.061154 second(s), 10 queries , Gzip On, MemCache On.
