查看: 707|回复: 8
[不限流量] 再送一台小鸡
发表于 2025-1-10 23:33:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CPU AMD Epyc 7351p - 16c/32t - 2.4 GHz/2.9 GHz
RAM 128 GB ECC 2400 MHz
Data disks 2×500 GB SSD NVMe
下载10G 上传500Mbps
1月24日到期
给root密码,免费送的后续不在提供任何服务
已送 @gjq 看私信
Processor  : AMD EPYC 7351P 16-Core Processor
CPU cores  : 32 @ 1196.904 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 125.8 GiB
Swap       : 1024.0 MiB
Disk       : 935.1 GiB
Distro     : Debian GNU/Linux 11 (bullseye)
Kernel     : 5.10.0-33-amd64
VM Type    : NONE
IPv4/IPv6  : ✔ Online / ✔ Online
IPv6 Network Information:
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH
Country    : France
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
Read       | 595.50 MB/s (148.8k) | 1.70 GB/s    (26.5k)
Write      | 597.07 MB/s (149.2k) | 1.70 GB/s    (26.7k)
Total      | 1.19 GB/s   (298.1k) | 3.41 GB/s    (53.2k)
Read       | 2.08 GB/s     (4.0k) | 2.30 GB/s     (2.2k)
Write      | 2.19 GB/s     (4.2k) | 2.46 GB/s     (2.4k)
Total      | 4.27 GB/s     (8.3k) | 4.77 GB/s     (4.6k)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 486 Mbits/sec   | 9.20 Gbits/sec  | 4.43 ms
Eranium         | Amsterdam, NL (100G)      | 485 Mbits/sec   | 8.43 Gbits/sec  | 8.58 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | 1.67 Gbits/sec  | 103 ms
Leaseweb        | Singapore, SG (10G)       | 358 Mbits/sec   | 587 Mbits/sec   | 215 ms
Clouvider       | Los Angeles, CA, US (10G) | busy            | busy            | 135 ms
Leaseweb        | NYC, NY, US (10G)         | 461 Mbits/sec   | 2.37 Gbits/sec  | 75.7 ms
Edgoo           | Sao Paulo, BR (1G)        | 392 Mbits/sec   | 676 Mbits/sec   | 221 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | busy            | busy            | 4.42 ms
Eranium         | Amsterdam, NL (100G)      | 478 Mbits/sec   | 8.49 Gbits/sec  | 8.59 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | 1.46 Gbits/sec  | 103 ms
Leaseweb        | Singapore, SG (10G)       | 397 Mbits/sec   | 792 Mbits/sec   | 215 ms
Leaseweb        | NYC, NY, US (10G)         | 436 Mbits/sec   | 2.49 Gbits/sec  | 75.4 ms
Edgoo           | Sao Paulo, BR (1G)        | 391 Mbits/sec   | 643 Mbits/sec   | 221 ms
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 832
Multi Core      | 11988
Full Test       | https://browser.geekbench.com/v5/cpu/23250545
 楼主| 发表于 2025-1-10 23:35:27 | 只看该作者
就你了
发表于 2025-1-10 23:36:56 | 只看该作者
好的,谢谢佬
发表于 2025-1-10 23:45:58 | 只看该作者
收到了,已经在玩弄了,谢谢佬
发表于 2025-1-11 01:08:49 | 只看该作者
这不是KS6吗
GMT+8, 2025-12-22 18:09 , Processed in 0.061440 second(s), 10 queries , Gzip On, MemCache On.
