查看: 1015|回复: 0
HostHatch 4C32G日本大鸡性能网络测试,国内10G跑满G口
发表于 2025-1-4 13:45:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
bench
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2024-11-11
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : AMD EPYC 7J13 64-Core Processor
  6. CPU Cores          : 4 [url=home.php?mod=space&uid=175]@[/url] 2450.074 MHz
  7. CPU Cache          : 512 KB
  8. AES-NI             : ✓ Enabled
  9. VM-x/AMD-V         : ✓ Enabled
  10. Total Disk         : 376.4 GB (11.1 GB Used)
  11. Total Mem          : 31.1 GB (927.6 MB Used)
  12. Total Swap         : 4.0 GB (0 Used)
  13. System uptime      : 0 days, 10 hour 30 min
  14. Load average       : 0.00, 0.00, 0.00
  15. OS                 : Rocky Linux release 9.5 (Blue Onyx)
  16. Arch               : x86_64 (64 Bit)
  17. Kernel             : 5.14.0-503.19.1.el9_5.x86_64
  18. TCP CC             : cubic
  19. Virtualization     : KVM
  20. IPv4/IPv6          : ✓ Online / ✗ Offline
  21. Organization       : AS63473 HostHatch, LLC
  22. Location           : Tokyo / JP
  23. Region             : Tokyo
  24. ----------------------------------------------------------------------
  25. I/O Speed(1st run) : 767 MB/s
  26. I/O Speed(2nd run) : 1.1 GB/s
  27. I/O Speed(3rd run) : 974 MB/s
  28. I/O Speed(average) : 955.8 MB/s
  29. ----------------------------------------------------------------------
  30. Node Name        Upload Speed      Download Speed      Latency
  31. Speedtest.net    11578.40 Mbps     11685.07 Mbps       0.44 ms
  32. Los Angeles, US  873.24 Mbps       5690.14 Mbps        102.96 ms
  33. Dallas, US       667.07 Mbps       5192.15 Mbps        132.40 ms
  34. Montreal, CA     112.18 Mbps       849.80 Mbps         144.42 ms
  35. Paris, FR        487.26 Mbps       4354.10 Mbps        233.16 ms
  36. Amsterdam, NL    413.26 Mbps       2898.73 Mbps        208.47 ms
  37. Shanghai, CN     1081.82 Mbps      4811.31 Mbps        73.57 ms
  38. Hong Kong, CN    2051.06 Mbps      6832.87 Mbps        43.24 ms
  39. Singapore, SG    425.44 Mbps       1670.46 Mbps        78.41 ms
  40. Tokyo, JP        11730.44 Mbps     9301.03 Mbps        1.28 ms
  41. ----------------------------------------------------------------------
  42. Finished in        : 4 min 47 sec
  43. Timestamp          : 2025-01-04 13:17:03 CST
  44. ----------------------------------------------------------------------
yabs
  3. #                     v2025-01-01                    #
  6. Sat Jan  4 13:17:36 CST 2025
  7. Basic System Information:
  9. Uptime     : 0 days, 10 hours, 35 minutes
  10. Processor  : AMD EPYC 7J13 64-Core Processor
  11. CPU cores  : 4 [url=home.php?mod=space&uid=175]@[/url] 2450.074 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.1 GiB
  15. Swap       : 4.0 GiB
  16. Disk       : 372.4 GiB
  17. Distro     : Rocky Linux 9.5 (Blue Onyx)
  18. Kernel     : 5.14.0-503.19.1.el9_5.x86_64
  19. VM Type    : KVM
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : Deeraj Kumar Singh
  24. ASN        : AS63473 HostHatch, LLC
  25. Location   : Tokyo, Tokyo (13)
  26. Country    : Japan
  27. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1):
  28. ---------------------------------
  29. Block Size | 4k            (IOPS) | 64k           (IOPS)
  30.   ------   | ---            ----  | ----           ----
  31. Read       | 50.12 MB/s   (12.5k) | 635.18 MB/s   (9.9k)
  32. Write      | 50.20 MB/s   (12.5k) | 638.52 MB/s   (9.9k)
  33. Total      | 100.32 MB/s  (25.0k) | 1.27 GB/s    (19.9k)
  34.            |                      |
  35. Block Size | 512k          (IOPS) | 1m            (IOPS)
  36.   ------   | ---            ----  | ----           ----
  37. Read       | 1.28 GB/s     (2.5k) | 1.28 GB/s     (1.2k)
  38. Write      | 1.35 GB/s     (2.6k) | 1.36 GB/s     (1.3k)
  39. Total      | 2.63 GB/s     (5.1k) | 2.64 GB/s     (2.5k)
  40. iperf3 Network Speed Tests (IPv4):
  42. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  43. -----           | -----                     | ----            | ----            | ----
  44. Clouvider       | London, UK (10G)          | 798 Mbits/sec   | 85.4 Mbits/sec  | 205 ms
  45. Eranium         | Amsterdam, NL (100G)      | 811 Mbits/sec   | 877 Mbits/sec   | 251 ms
  46. Uztelecom       | Tashkent, UZ (10G)        | busy            | 74.9 Mbits/sec  | 538 ms
  47. Leaseweb        | Singapore, SG (10G)       | 2.42 Gbits/sec  | 3.28 Gbits/sec  | 68.0 ms
  48. Clouvider       | Los Angeles, CA, US (10G) | 948 Mbits/sec   | 1.63 Gbits/sec  | 98.1 ms
  49. Leaseweb        | NYC, NY, US (10G)         | 905 Mbits/sec   | 1.27 Gbits/sec  | 176 ms
  50. Edgoo           | Sao Paulo, BR (1G)        | 656 Mbits/sec   | 676 Mbits/sec   | 271 ms
  51. Geekbench 6 Benchmark Test:
  52. ---------------------------------
  53. Test            | Value
  54.                 |
  55. Single Core     | 1149
  56. Multi Core      | 2541
  57. Full Test       | https://browser.geekbench.com/v6/cpu/9757116
  58. YABS completed in 13 min 20 sec
backtrace
  1. 国家: JP 城市: Tokyo 服务商: AS63473 HostHatch, LLC
  2. 北京电信 219.141.140.10  电信163  [普通线路]
  3. 北京联通 202.106.195.68  联通4837 [普通线路]
  4. 北京移动 221.179.155.161 移动CMI  [普通线路]
  5. 上海电信 202.96.209.133  电信163  [普通线路]
  6. 上海联通 210.22.97.1     联通4837 [普通线路]
  7. 上海移动 211.136.112.200 移动CMI  [普通线路]
  8. 广州电信 58.60.188.222   电信163  [普通线路]
  9. 广州移动 120.196.165.24  移动CMI  [普通线路]
  10. 成都电信 61.139.2.69     电信163  [普通线路]
  11. 成都联通 119.6.6.6       联通4837 [普通线路]
  12. 成都移动 211.137.96.205  移动CMI  [普通线路]
speedtest
  1. ------------------------ 多功能 自更新 测速脚本 ------------------------
  2. Version               : v2024-04-25
  3. Usage                 : bash <(curl -sL bash.icu/speedtest)
  4. GitHub                : https://github.com/i-abc/speedtest
  5. ------------------------------------------------------------------------
  6. 大陆三网+教育网 IPv4 多线程测速,v2024-03-15
  7. ------------------------------------------------------------------------
  8. 测速节点            下载/Mbps      上传/Mbps      延迟/ms      抖动/ms
  9. 最近的测速点        5915.04 Mbps   11127.21 Mbps  0.51 ms      0.13 ms
  10. 电信 江苏苏州       1254.84 Mbps   181.09 Mbps    271.41 ms    280.80 ms
  11. 电信 浙江杭州       1197.66 Mbps   1575.24 Mbps   47.62 ms     0.13 ms
  12. 电信 浙江宁波 5G    1047.70 Mbps   1054.98 Mbps   40.32 ms     1.16 ms
  13. 电信 江苏镇江 5G    125.95 Mbps    545.20 Mbps    87.38 ms     6.08 ms
  14. 电信 江苏南京 5G    85.68 Mbps     793.68 Mbps    39.37 ms     0.30 ms
  15. 移动 四川成都       2135.24 Mbps   769.31 Mbps    95.22 ms     0.05 ms
  16. 联通 江苏无锡       2986.64 Mbps   874.84 Mbps    62.68 ms     0.35 ms
  17. 测速次数过多,暂时被限制,请过一段时间后再进行测试
  18. ------------------------------------------------------------------------
  19. 系统时间:2025-01-04 15:21:43 CST
  20. 北京时间: 2025-01-04 15:21:43 CST
  21. ------------------------------------------------------------------------
GMT+8, 2026-4-23 20:13 , Processed in 0.058183 second(s), 9 queries , Gzip On, MemCache On.
