查看: 1686|回复: 10
【已出】明盘出台IE区KS-LE-1,三中奖款
发表于 2024-12-24 17:06:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
OVH IE区PUSH出
中奖内容:
内存32G, SSD 800G*2, IPV6 上下G口
应该是带核显的,25端口应该也是开启的。
机房:法国GRA
到期时间:2025-01-19(续费9.9欧)
联系TG:@sunpma
总价:400
详细测试:
  1. root@SunPma:~# curl -sL yabs.sh | bash
  2. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  3. #              Yet-Another-Bench-Script              #
  4. #                     v2024-12-20                    #
  5. # https://github.com/masonr/yet-another-bench-script #
  6. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  7. Fri Dec 20 06:09:59 UTC 2024
  8. Basic System Information:
  9. ---------------------------------
  10. Uptime     : 0 days, 13 hours, 12 minutes
  11. Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  12. CPU cores  : 8 [url=home.php?mod=space&uid=175]@[/url] 2400.000 MHz
  13. AES-NI     : ✔ Enabled
  14. VM-x/AMD-V : ✔ Enabled
  15. RAM        : 31.2 GiB
  16. Swap       : 0.0 KiB
  17. Disk       : 1.4 TiB
  18. Distro     : Ubuntu 22.04.5 LTS
  19. Kernel     : 5.15.0-126-generic
  20. VM Type    : NONE
  21. IPv4/IPv6  : ✔ Online / ✔ Online
  22. IPv6 Network Information:
  23. ---------------------------------
  24. ISP        : OVH SAS
  25. ASN        : AS16276 OVH SAS
  26. Host       : OVH SAS
  27. Location   : Roubaix, Hauts-de-France (HDF)
  28. Country    : France
  29. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md2):
  30. ---------------------------------
  31. Block Size | 4k            (IOPS) | 64k           (IOPS)
  33. Read       | 203.12 MB/s  (50.7k) | 335.63 MB/s   (5.2k)
  34. Write      | 203.65 MB/s  (50.9k) | 337.39 MB/s   (5.2k)
  35. Total      | 406.77 MB/s (101.6k) | 673.02 MB/s  (10.5k)
  36.            |                      |
  37. Block Size | 512k          (IOPS) | 1m            (IOPS)
  38.   ------   | ---            ----  | ----           ----
  39. Read       | 377.33 MB/s    (736) | 358.13 MB/s    (349)
  40. Write      | 397.38 MB/s    (776) | 381.98 MB/s    (373)
  41. Total      | 774.71 MB/s   (1.5k) | 740.12 MB/s    (722)
  42. iperf3 Network Speed Tests (IPv4):
  43. ---------------------------------
  44. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  45. -----           | -----                     | ----            | ----            | ----
  46. Clouvider       | London, UK (10G)          | 287 Mbits/sec   | 940 Mbits/sec   | 3.94 ms
  47. Eranium         | Amsterdam, NL (100G)      | 286 Mbits/sec   | 939 Mbits/sec   | 9.85 ms
  48. Uztelecom       | Tashkent, UZ (10G)        | 178 Mbits/sec   | 236 Mbits/sec   | 98.3 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 123 Mbits/sec   | 580 Mbits/sec   | 137 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 253 Mbits/sec   | 615 Mbits/sec   | 76.0 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 155 Mbits/sec   | 454 Mbits/sec   | 183 ms
  52. iperf3 Network Speed Tests (IPv6):
  53. ---------------------------------
  54. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  55. -----           | -----                     | ----            | ----            | ----
  56. Clouvider       | London, UK (10G)          | 906 Mbits/sec   | 915 Mbits/sec   | 3.93 ms
  57. Eranium         | Amsterdam, NL (100G)      | 917 Mbits/sec   | 923 Mbits/sec   | 9.87 ms
  58. Leaseweb        | Singapore, SG (10G)       | 768 Mbits/sec   | 505 Mbits/sec   | 160 ms
  59. Clouvider       | Los Angeles, CA, US (10G) | 775 Mbits/sec   | 242 Mbits/sec   | 137 ms
  60. Leaseweb        | NYC, NY, US (10G)         | 843 Mbits/sec   | 631 Mbits/sec   | 76.0 ms
  61. Edgoo           | Sao Paulo, BR (1G)        | 760 Mbits/sec   | 266 Mbits/sec   | 183 ms
  62. Geekbench 6 Benchmark Test:
  63. ---------------------------------
  64. Test            | Value
  65. Single Core     | 733
  66. Multi Core      | 2601
  1.   CPU 型号              Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  2.   CPU 核心              合计 4 核心,8 线程
  3.   CPU 状态              当前主频 3099.947 MHz
  4.   内存大小              32002 MB (805 MB 已用)
  5.   第 1 块硬盘           通电 34674 小时,型号 INTEL SSDSC2BB800G6
  6.   第 2 块硬盘           通电 24299 小时,型号 INTEL SSDSC2BB800G6
  7.   硬盘大小              1536.0 GB
  8.   服务器时间            2024-12-24 08:50:45
  9.   运行时间              3 days 2 hour 44 min
  10.   系统负载              0.05, 0.07, 0.08
  11.   虚拟化技术            No Virtualization Detected
  12.   IPv4 地址             37.187.xxx.xxx
  13.   IPv6 地址             2001:41d0:xxxx:xxxx
  14.   运营商                AS16276 OVH SAS
  15.   地理位置              FR, Normandy, Saint-Étienne-du-Rouvray
  16.   操作系统              Ubuntu 24.04.1 noble (x86_64)
  17.   系统内核              6.8.0-51-generic
  18.   TCP 加速              bbr
  19.   当前脚本版本          1.4.1.1
  20.    ATTENTION  检测到你服务器里有固态硬盘,建议使用 fio 代替 dd 进行测试
  21.               bash <(wget -qO- git.io/ceshi) -j
  22.   顺序写入 (1st)        683 MB/s
  23.   顺序写入 (2nd)        688 MB/s
  24.   顺序写入 (3rd)        689 MB/s
  25.   顺序写入 (4th)        691 MB/s
  26.   顺序写入 (5th)        682 MB/s
  27.   顺序写入 (avg)        686.7 MB/s
  1. -------------------- A Bench.sh Script By Teddysun -------------------
  2. Version            : v2024-11-11
  3. Usage              : wget -qO- bench.sh | bash
  4. ----------------------------------------------------------------------
  5. CPU Model          : Intel(R) Xeon(R) CPU E3-1245 V2 [url=home.php?mod=space&uid=175]@[/url] 3.40GHz
  6. CPU Cores          : 8 [url=home.php?mod=space&uid=175]@[/url] 1643.422 MHz
  7. CPU Cache          : 8192 KB
  8. AES-NI             : ✓ Enabled
  9. VM-x/AMD-V         : ✓ Enabled
  10. Total Disk         : 0 (0 Used)
  11. Total Mem          : 31.2 GB (191.5 MB Used)
  12. System uptime      : 0 days, 0 hour 9 min
  13. Load average       : 0.24, 0.16, 0.08
  14. OS                 : Debian GNU/Linux 10
  15. Arch               : x86_64 (64 Bit)
  16. Kernel             : 6.1.51-mod-std
  17. TCP CC             : cubic
  18. Virtualization     : Dedicated
  19. IPv4/IPv6          : ✓ Online / ✓ Online
  20. Organization       : AS16276 OVH SAS
  21. Location           : Saint-Étienne-du-Rouvray / FR
  22. Region             : Normandy
  23. ----------------------------------------------------------------------
  24. Not enough space for I/O Speed test!
  25. ----------------------------------------------------------------------
  26. Node Name        Upload Speed      Download Speed      Latency
  27. Speedtest.net    918.55 Mbps       918.39 Mbps         5.01 ms
  28. Los Angeles, US  613.22 Mbps       486.91 Mbps         149.74 ms
  29. Dallas, US       778.03 Mbps       645.16 Mbps         111.50 ms
  30. Montreal, CA     207.77 Mbps       929.49 Mbps         85.63 ms
  31. Paris, FR        903.52 Mbps       927.84 Mbps         4.87 ms
  32. Amsterdam, NL    275.79 Mbps       938.18 Mbps         10.81 ms
  33. Shanghai, CN     2.71 Mbps         860.49 Mbps         271.15 ms
  34. Hong Kong, CN    104.71 Mbps       396.70 Mbps         259.63 ms
  35. Singapore, SG    94.82 Mbps        716.53 Mbps         170.22 ms
  36. Tokyo, JP        346.43 Mbps       805.62 Mbps         255.86 ms
  37. ----------------------------------------------------------------------
  38. Finished in        : 4 min 31 sec
  39. Timestamp          : 2024-12-19 16:02:00 UTC
  40. ----------------------------------------------------------------------
发表于 2024-12-24 17:08:44 | 只看该作者
到期时间是2025年1月19号吧...
 楼主| 发表于 2024-12-24 17:38:58 | 只看该作者
gongxifacai 发表于 2024-12-24 17:08
到期时间是2025年1月19号吧...
对的,对的,写错了~~
发表于 2024-12-24 17:40:57 | 只看该作者
好鸡,价格也不错,帮顶
发表于 2024-12-24 18:04:39 | 只看该作者
可惜没账号
发表于 2024-12-24 21:59:34 | 只看该作者
可惜没账号 不然就收了
发表于 2024-12-25 14:53:30 来自手机 | 只看该作者
少见 中硬盘基本见到都是960
 楼主| 发表于 2024-12-25 20:22:53 | 只看该作者
小俊哟 发表于 2024-12-24 21:59
可惜没账号 不然就收了
OVH好像可以改邮箱,免税号改邮箱加200
发表于 2024-12-25 20:40:58 来自手机 | 只看该作者
冲着硬盘重,好价
GMT+8, 2026-4-27 06:33 , Processed in 0.066769 second(s), 10 queries , Gzip On, MemCache On.
