查看: 546|回复: 2
出 2023 年黑五版 SYS-LE-1 (2×1.92 TB SSD NVMe)
发表于 2024-12-24 12:53:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
SYS-LE-1
CPU
Intel Xeon E3-1230v6 - 4c/8t - 3.5 GHz/3.9 GHz
RAM
32 GB 2133 MHz
Data disks
2×1.92 TB SSD NVMe
Soft RAID
Next payment date
1 January 2025
€29.99/month
200出
#              Yet-Another-Bench-Script              #
#                     v2024-12-20                    #
# https://github.com/masonr/yet-another-bench-script #
Mon Dec 23 06:41:49 UTC 2024
Basic System Information:
Uptime     : 0 days, 0 hours, 15 minutes
Processor  : Intel(R) Xeon(R) CPU E3-1230 v6 @ 3.50GHz
CPU cores  : 8 @ 800.000 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 31.0 GiB
Swap       : 1024.0 MiB
Disk       : 1.7 TiB
Distro     : Debian GNU/Linux 12 (bookworm)
Kernel     : 6.1.0-28-amd64
VM Type    : NONE
IPv4/IPv6  : ✔ Online / ✔ Online
IPv6 Network Information:
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH SAS
Country    : France
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
Read       | 571.14 MB/s (142.7k) | 1.22 GB/s    (19.1k)
Write      | 572.65 MB/s (143.1k) | 1.23 GB/s    (19.2k)
Total      | 1.14 GB/s   (285.9k) | 2.46 GB/s    (38.4k)
Read       | 1.22 GB/s     (2.3k) | 1.26 GB/s     (1.2k)
Write      | 1.29 GB/s     (2.5k) | 1.35 GB/s     (1.3k)
Total      | 2.52 GB/s     (4.9k) | 2.62 GB/s     (2.5k)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 262 Mbits/sec   | busy            | 4.02 ms
Eranium         | Amsterdam, NL (100G)      | 262 Mbits/sec   | 939 Mbits/sec   | 9.79 ms
Uztelecom       | Tashkent, UZ (10G)        | 220 Mbits/sec   | 831 Mbits/sec   | 103 ms
Leaseweb        | Singapore, SG (10G)       | 220 Mbits/sec   | 410 Mbits/sec   | 161 ms
Clouvider       | Los Angeles, CA, US (10G) | 221 Mbits/sec   | 646 Mbits/sec   | 136 ms
Leaseweb        | NYC, NY, US (10G)         | 244 Mbits/sec   | 808 Mbits/sec   | 75.2 ms
Edgoo           | Sao Paulo, BR (1G)        | 219 Mbits/sec   | 595 Mbits/sec   | 215 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 258 Mbits/sec   | busy            | 4.10 ms
Eranium         | Amsterdam, NL (100G)      | 257 Mbits/sec   | 925 Mbits/sec   | 9.76 ms
Uztelecom       | Tashkent, UZ (10G)        | 225 Mbits/sec   | 826 Mbits/sec   | 103 ms
Leaseweb        | Singapore, SG (10G)       | 221 Mbits/sec   | 660 Mbits/sec   | 161 ms
Clouvider       | Los Angeles, CA, US (10G) | 222 Mbits/sec   | 692 Mbits/sec   | 136 ms
Leaseweb        | NYC, NY, US (10G)         | 224 Mbits/sec   | 804 Mbits/sec   | 74.9 ms
Edgoo           | Sao Paulo, BR (1G)        | 209 Mbits/sec   | 598 Mbits/sec   | 215 ms
Geekbench 6 Benchmark Test:
Test            | Value
Single Core     | 1464
Multi Core      | 5039
发表于 2024-12-24 20:17:03 | 只看该作者
可惜口子太小
GMT+8, 2026-4-25 18:26 , Processed in 0.065665 second(s), 10 queries , Gzip On, MemCache On.
