查看: 1684|回复: 15
[美国VPS] 出OVH KS-LE-B\KS-LE-2 闪购、黑五
发表于 2024-12-17 22:03:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
KS-LE-B
E3-1270 v6
32G ECC DDR4
2*1920 NVME
网络标配,使用OVH机器,测试过波兰V6、法国V4/V6来拉可以G口上传
1.6W小时   7200小时   盘还算新
法国机房
续费9.9o
1400出
KS-LE-2  黑五款
E3-1231v3
32 GB ECC 1333 MHz
2×1.92 TB SSD SATA
网络V6中奖上下G口
法国机房
续费17.99o  首月是15.99*2  api买的不知道是不是都这样
400出
以上OVH均ie区 push出
nocix 3800X 64G 480*2 SSD 5IP  1Gbps  续费40u     150出
PM联系
---------------------------------------------------------------------------------------KS-LE-B
root@ns3061357:~# curl -sL https://yabs.sh | bash
#              Yet-Another-Bench-Script              #
#                     v2024-12-20                    #
# https://github.com/masonr/yet-another-bench-script #
Sat Dec 21 07:42:19 UTC 2024
Basic System Information:
Uptime     : 3 days, 17 hours, 43 minutes
Processor  : Intel(R) Xeon(R) CPU E3-1230 v6 @ 3.50GHz
CPU cores  : 8 @ 3625.804 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 31.0 GiB
Swap       : 1024.0 MiB
Disk       : 1.7 TiB
Distro     : Debian GNU/Linux 12 (bookworm)
Kernel     : 6.1.0-28-amd64
VM Type    : NONE
IPv4/IPv6  : ✔ Online / ✔ Online
IPv6 Network Information:
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH
Country    : France
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3):
Read       | 570.67 MB/s (142.6k) | 1.23 GB/s    (19.2k)
Write      | 572.18 MB/s (143.0k) | 1.23 GB/s    (19.3k)
Total      | 1.14 GB/s   (285.7k) | 2.47 GB/s    (38.6k)
Read       | 1.23 GB/s     (2.4k) | 1.27 GB/s     (1.2k)
Write      | 1.29 GB/s     (2.5k) | 1.36 GB/s     (1.3k)
Total      | 2.52 GB/s     (4.9k) | 2.63 GB/s     (2.5k)
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 291 Mbits/sec   | 941 Mbits/sec   | 4.04 ms
Eranium         | Amsterdam, NL (100G)      | 290 Mbits/sec   | 939 Mbits/sec   | 9.91 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 102 ms
Leaseweb        | Singapore, SG (10G)       | 247 Mbits/sec   | 629 Mbits/sec   | 160 ms
Clouvider       | Los Angeles, CA, US (10G) | 250 Mbits/sec   | 656 Mbits/sec   | 136 ms
Leaseweb        | NYC, NY, US (10G)         | 252 Mbits/sec   | 737 Mbits/sec   | 77.5 ms
Edgoo           | Sao Paulo, BR (1G)        | 242 Mbits/sec   | 414 Mbits/sec   | 223 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 287 Mbits/sec   | 928 Mbits/sec   | 4.16 ms
Eranium         | Amsterdam, NL (100G)      | 286 Mbits/sec   | 926 Mbits/sec   | 9.87 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | 725 Mbits/sec   | 102 ms
Leaseweb        | Singapore, SG (10G)       | 245 Mbits/sec   | 626 Mbits/sec   | 160 ms
Clouvider       | Los Angeles, CA, US (10G) | 245 Mbits/sec   | 685 Mbits/sec   | 136 ms
Leaseweb        | NYC, NY, US (10G)         | 271 Mbits/sec   | 730 Mbits/sec   | 77.5 ms
Edgoo           | Sao Paulo, BR (1G)        | 226 Mbits/sec   | 401 Mbits/sec   | 223 ms
Geekbench 6 Benchmark Test:
Test            | Value
Single Core     | 1449
Multi Core      | 4984
Full Test       | https://browser.geekbench.com/v6/cpu/9536750
YABS completed in 12 min 14 sec
-----------------------------------------------------------------------------------------KS-LE-2
root@ns3369160:~# curl -sL https://yabs.sh | bash
#                     v2024-12-20                    #
Sat Dec 21 07:42:17 UTC 2024
Uptime     : 3 days, 17 hours, 41 minutes
Processor  : Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz
CPU cores  : 8 @ 2494.308 MHz
AES-NI     : ✔ Enabled
RAM        : 31.3 GiB
Swap       : 1024.0 MiB
Disk       : 1.7 TiB
VM Type    : NONE
ISP        : OVH SAS
Host       : OVH SAS
Country    : France
Read       | 225.05 MB/s  (56.2k) | 239.40 MB/s   (3.7k)
Write      | 225.65 MB/s  (56.4k) | 240.66 MB/s   (3.7k)
Total      | 450.70 MB/s (112.6k) | 480.06 MB/s   (7.5k)
Read       | 300.86 MB/s    (587) | 317.02 MB/s    (309)
Write      | 316.85 MB/s    (618) | 338.13 MB/s    (330)
Total      | 617.71 MB/s   (1.2k) | 655.15 MB/s    (639)
Clouvider       | London, UK (10G)          | 287 Mbits/sec   | 941 Mbits/sec   | 3.76 ms
Eranium         | Amsterdam, NL (100G)      | 286 Mbits/sec   | 937 Mbits/sec   | 9.89 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 98.2 ms
Leaseweb        | Singapore, SG (10G)       | 98.0 Mbits/sec  | 507 Mbits/sec   | 160 ms
Clouvider       | Los Angeles, CA, US (10G) | busy            | 153 Mbits/sec   | 136 ms
Leaseweb        | NYC, NY, US (10G)         | 255 Mbits/sec   | 656 Mbits/sec   | 74.7 ms
Edgoo           | Sao Paulo, BR (1G)        | 159 Mbits/sec   | 245 Mbits/sec   | 209 ms
Clouvider       | London, UK (10G)          | 888 Mbits/sec   | 891 Mbits/sec   | 3.77 ms
Eranium         | Amsterdam, NL (100G)      | 806 Mbits/sec   | 923 Mbits/sec   | 9.84 ms
Uztelecom       | Tashkent, UZ (10G)        | 384 Mbits/sec   | 189 Mbits/sec   | 98.1 ms
Leaseweb        | Singapore, SG (10G)       | 189 Mbits/sec   | 474 Mbits/sec   | 161 ms
Clouvider       | Los Angeles, CA, US (10G) | 439 Mbits/sec   | 494 Mbits/sec   | 136 ms
Leaseweb        | NYC, NY, US (10G)         | 354 Mbits/sec   | 646 Mbits/sec   | --
Edgoo           | Sao Paulo, BR (1G)        | 357 Mbits/sec   | 179 Mbits/sec   | 209 ms
Test            | Value
Single Core     | 1315
Multi Core      | 4352
Full Test       | https://browser.geekbench.com/v6/cpu/9536760
YABS completed in 13 min 7 sec
发表于 2024-12-17 22:15:07 来自手机 | 只看该作者
好机,建议10000
发表于 2024-12-19 09:31:06 | 只看该作者
机器不错, 建议5w块钱
发表于 2024-12-17 22:06:12 | 只看该作者
好机!楼下说要了
发表于 2024-12-17 22:23:58 | 只看该作者
要是美国机房的机器就好了
发表于 2024-12-17 22:41:33 | 只看该作者
好机!楼下说要了
发表于 2024-12-19 01:37:31 来自手机 | 只看该作者
好机,迪迦说要了,让你去奥尔特星云找他
GMT+8, 2026-4-19 11:09 , Processed in 0.064805 second(s), 11 queries , Gzip On, MemCache On.
